    MagicMirror/node_modules/electron/dist/electron exited with signal SIGBUS
    Scheduled Pinned Locked Moved Solved Bug Hunt
    10 Posts 3 Posters 3.5k Views 3 Watching
    • F Offline
      frustrated
      Mirror has been running for months. Yesterday, 5-16-24, my magic mirror quit. I did a sudo shutdown and then a restart, now i get the following message MagicMirror/node_modules/electron/dist/electron exited with signal SIGBUS
      Need help on how to fix, please.
        sdetweil @frustrated
        @frustrated SO much fun…
        SO… lets try to reinstall electron
        BUT it leans towards an sd card problem…
        rm -rf node_modules/electron
        npm install electron@22.3.4
        then
        npm start
        and see what we get
        kusselinK 1 Reply Last reply Reply Quote 0
          @frustrated can you show more of the output
          • F Offline
            frustrated
            Thanks for the note, this is whaat I see on the mirror
            spudz@raspberrypi:~ $ cd MagicMirror
            spudz@raspberrypi:~/MagicMirror $ npm run start
            magicmirror@2.23.0 start
            /home/spudz/MagicMirror/node_modules/electron/dist/electron exited with signal SIGBUS
              then
              npm start
              and see what we get
              • F Offline
                frustrated
                Got your note, thanks. Here is what I did / happened.
                spudz@raspberrypi:~/MagicMirror $ rm -rf node_modules/electron
                spudz@raspberrypi:~/MagicMirror $ npm install electron@22.3.4
                added 1 package, and audited 785 packages in 40s
                139 packages are looking for funding
                run npm fund for details
                13 vulnerabilities (10 moderate, 2 high, 1 critical)
                To address issues that do not require attention, run:
                npm audit fix
                To address all issues (including breaking changes), run:
                npm audit fix --force
                Run npm audit for details.
                spudz@raspberrypi:~/MagicMirror $ npm audit fix --force
                npm WARN using --force Recommended protections disabled.
                npm WARN audit Updating node-ical to 0.18.0, which is a SemVer major change.
                added 1 package, removed 12 packages, changed 42 packages, and audited 774 packages in 2m
                140 packages are looking for funding
                found 0 vulnerabilities
                Will shutdown and restart, hope3fully this will fix…
                Thank You
                  @frustrated did you try it before reboot? MM is just an app… don’t need to reboot to test it
                  • F Offline
                    frustrated
                    it works !!!
                    Thank you so much.
                    I did do a reboot just to be sure everything updates.
                    Thanks again
                      @frustrated said in MagicMirror/node_modules/electron/dist/electron exited with signal SIGBUS:
                      yes, for sure… but did it work BEFORE rebooting??
                      anyhow…
                      you also have a backup of your mm, right?
                      if not, see
                      https://github.com/sdetweil/MagicMirror-backup-restore
                      and can be versioned with git …
                      • kusselinK Offline
                        kusselin @sdetweil
                        @sdetweil said in MagicMirror/node_modules/electron/dist/electron exited with signal SIGBUS:
                        then
                        npm start
                        and see what we get
                        root@magicmirror-test:/opt/magicmirror# npm start
                        > magicmirror@2.31.0 start
                        > npm run start:x11
                        Hi Sam, I can't get enough of this...
                        This message with Elektron has something to do with the displaying, doesn't it?
                        why are these error messages suddenly appearing in Proxmox with LXC containers?
                        Look....these are now the latest error messages after installing your tips..:
                        > magicmirror@2.31.0 start:x11
                        [0414/064255.384679:FATAL:electron_main_delegate.cc(299)] Running as root without --no-sandbox is not supported. See https://crbug.com/638180.
                        /opt/magicmirror/node_modules/electron/dist/electron exited with signal SIGTRAP
                          sdetweil @kusselin
                          @kusselin you cannot run electron from root user without additional parameters
                          you should logon as a normal user
