    MMM-Scenes2
    31 Posts 4 Posters 11.4k Views 4 Watching
      Babene1 Project Sponsor
      I have the same problem, after about 1 hour there is no change of modules.
      I also want a constant change of MMM-iframeReload and MMM-iframeReload2 module
      MagicMirror Version 2.27, Rapsberry PI 4 – 4 GB
      My Config:
      /* MagicMirror² Config Sample
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
       * see https://docs.magicmirror.builders/configuration/introduction.html
       * and https://docs.magicmirror.builders/modules/configuration.html
       * You can use environment variables using a `config.js.template` file instead of `config.js`
       * which will be converted to `config.js` while starting. For more information
       * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
      let config = {
      	address: "0.0.0.0",	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.178.249", "192.168.178.49"], // Set [] to allow all IP addresses
      	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
      	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
      	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
      	language: "de",
      	locale: "de-DE",
      	timeFormat: 24,
      	units: "metric",
      	electronOptions: {
      		webPreferences: {
      		  webviewTag: true,
      			module: "alert",
      			module: "clock",
      			position: "top_left"
      		// https://github.com/TheBogueRat/MMM-iFrameReload
      		module: 'MMM-iFrameReload',
      		position: 'top_left',	// This can be any of the regions.
      		classes: "SEITE_ZWEI",
      		//header: 'Rezept des Tages',
      				url: http://test/Anzeigetafeln/Anzeige1.html,
      				width: "1900px", // Optional. Default: 100%
      				height: "1080px", //Optional. Default: 100px
      				refreshInterval: 100
      			module: 'MMM-iFrameReload2',
      			classes: "Welcome SEITE_EINS",
      					url: http://test/Anzeigetafeln/Logo.html,
      					refreshInterval: 3600
      				// https://github.com/MMRIZE/MMM-Scenes2
      				module: "MMM-Scenes2",
      				position: "bottom_bar",
      					life: 1000 * 10,
      					activeIndicator: ' ',
      					inactiveIndicator: ' ',
      					scenario: [
      						{ // First scene definition
      							exit: ["SEITE_ZWEI"],
      							enter: ["SEITE_EINS"],
      							life: 1000 * 10,
      						  { // Second scene definition
      							exit: ["SEITE_EINS"],
      							enter: ["SEITE_ZWEI"],
      							life: 1000 * 45,
      			// https://github.com/Jopyth/MMM-Remote-Control
      			module: 'MMM-Remote-Control',
      			// position: 'bottom_left',
      				customCommand: {
      					//monitorStatusCommand: 'rm -rf .config/Electron',
      					monitorStatusCommand: '~pi/restartBrowsercache.sh'
      				},  // Optional, See "Using Custom Commands" below
      				showModuleApiMenu: false, // Optional, Enable the Module Controls menu
      				secureEndpoints: true, // Optional, See API/README.md
      				// uncomment any of the lines below if you're gonna use it
      				customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
      				// apiKey: "", // Optional, See API/README.md for details
      				// classes: {} // Optional, See "Custom Classes" below
      I insert the line in my mm.sh:
      export ELECTRON_DISABLE_GPU=1
      pm2 Log:
      [1965:0521/220109.925300:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
      [1965:0521/220109.925398:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
      uname -a
      Linux raspberryanzeige1 6.1.0-rpi8-rpi-v8 #1 SMP PREEMPT Debian 1:6.1.73-1+rpt1 (2024-01-25) aarch64 GNU/Linux
      file /bin/bash
      /bin/bash: ELF 64-bit LSB pie executable, ARM aarch64, version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-aarch64.so.1, BuildID[sha1]=198ac6b0cc01bf774c5746a36a6fd31dead9bda5, for GNU/Linux 3.7.0, stripped
      Does anyone have any idea what I can do? Thanks
      M 1 Reply Last reply
        MMRIZE @Babene1
        @Babene1
        I researched about that error message.
        The error messages seemed not to be the module or logic issue but the GPU/System issue. (Usually in -nix machines about graphic drivers.)
        However, I’m not sure the error message is related to your symptom actually. There is a chance these two things could be independent.
        What I suggest for the test is;
        • use simpler animation effects or no animation.
        • give a longer life for the scene.
        • Remove all other 3rd party modules, except default modules (clock, …)
        If it helps, we can progress from it anyhow.
        But if not; I think I rarely have things to do.
        B 1 Reply Last reply
          Babene1 Project Sponsor @MMRIZE
          @MMRIZE
          Thank you for your answer, I agree with you, I also think that the error message has nothing to do with the problem.
          Error message is written to the log after the start and the freezing of the module happens after about 1 hour.
          I used the default animation, unfortunately I don’t know how to remove the animation completely.
          Have also removed the MMM remote control module.
          So there are only three modules left, MMM-Scenes2, MMM-iFrameReload and MMM-iFrameReload2
          I switched off WLan-power Save and deactivated IPV6.
          No improvement, no improvement.
          Next tests will be longer times and I will use a different browser.
          Other test scenarios ?
          M 2 Replies Last reply
            MMRIZE @Babene1
            @Babene1
            To disable animation, you can set animation: null in defaultEnter definition or each scene role definition.
            /* example for default behaviour */
            defaultEnter: {
              animation: null,
              duration: 1000,
              gap: 0,
            /* example for each scene definition */
            scenario: [
                enter: {
                  role: "role1",
                  animation: null,
            I’m suspecting Chrome’s memory leaks. These factors may cause memory leaks.
            • improper handling timer
            • CSS transition/Animation
            I’ll modify some code to confirm to clear out garbage timer. Wait a little.
            By the way, can you test the default clock module instead of MMM-iFrame Things? (To make things clearer)
              MMRIZE @Babene1
              @Babene1
              It’s been updated, but I’m not expecting much. Because timers are rarely used in my code(only two), I don’t think that was the cause of the problem. Anyway, I fixed it so that when the timer is used, it is turned off as soon as possible.
                ric
                I have switched to MMM-Carousel and experimented with it. It ran for a few days without any problems. Then I installed more modules and customised my configuration. And now the problem is occurring again. The last scene hangs at some point, so I was afraid it might be this one: MMM-BackgroundSlideshow. However, you are not using this, so it is unlikely to be due to this.
                My next steps:
                1. disable MMM-BackgroundSlideshow.
                2. completely reinstall everything and only install the modules I want to have at the end and then not change anything else. Let’s see if I will be successful.
                  MMRIZE @ric
                  @ric
                  Chrome(Chromium) is notorious for memory leaks. On Transition/Animation, this kind of error is often reported in some environments (+ some GPU driver issues). Sometimes, a newer version looks like it solves this issue, but the issue returns in subsequent versions again.
                  If you have more memory, this symptom seems relieving, but not absolutely.
                  R 1 Reply Last reply
                    Result of my test:
                    • ListenpunktUsing “external_broqwser=firefox” no improvement, after about 1 hour no changes from the modul.
                    • ListenpunktWith “animation: null”, no improvement, after about 1 hour no changes from the modul.
                    • ListenpunktWith default clock and calendar, no problem (test run about 2,5 hours)
                    Next test, with just an iframe module and the MMM-Simple Logo module. This module combination could be a solution for me
                      MMRIZE @Babene1
                      @Babene1
                      Do you mean iFrame related module may have the issue?
                        ric @MMRIZE
                        @MMRIZE
                        do i understand correctly that the Transition/Animation, could be to blame? So I would have to switch off the transitions for the two modules (MMM-BackgroundSlideshow und MMM-Carousel).
                        I’ll test it like this
                          MMRIZE @ric
                          @ric
                          Yes, you should try adding one / removing one for all combinations. It would be a very tedious task and requires persistence.
                            @MMRIZE
                            Yes, I think the problem is due to the “MMM-iFrameReload” module. I’m now using the module “MMM-SmartWebDisplay” so far no problem :-)
                              MMRIZE @Babene1
                              @Babene1
                              Congrat. Happy to hear that. (Mine is not guilty! :D)
