    MMM-RTSPtoWeb fresh install
    6 Posts 2 Posters 1.3k Views 2 Watching
      sforza
      Hi all,
      I had this working on an ancient Rpi2B last year and was extremely happy with it, used to monitor my kids sleeping (or not). Surely stream was low res and the pi was getting hot while doing this, but it just worked and it was awesome.
      That Pi died so I moved to a Pi4B 4GB I had lying around, just did a fresh installation of 64bit Raspberry Pi OS and Magic Mirror, and this RTSPtoWeb module is unfortunately not working, which I expected somehow, it’s two years since last update of the code.
      Of course the RPi2B was running an older RPI OS version, likely was Buster or Bullseye, can’t really remember, surely 32bit.
      I have RTSPtoWeb - WebRTC Home Assistant module running on a separate NUC and all is good. Exact same instance I used on the RPi2B.
      Error log below. Not sure if easily solvable or related to the deep changes across major version upgrades. Any ideas would be greatly appreciated. Let me know for any additional input required please.
      Original developer @shbatm does not seem to be connecting since long ago as per his forum stats. My appreciation for your work here, it was beautiful while it worked.
      Thanks a ton in advance!
      sforza@rpi4:~/MagicMirror $ uname -a
      Linux rpi4 6.6.28+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.28-1+rpt1 (2024-04-22) aarch64 GNU/Linux
      https://github.com/shbatm/MMM-RTSPtoWeb
      sforza@rpi4:~/MagicMirror $ npm run start
      magicmirror@2.27.0 start
      [2024-05-30 14:57:40.824] [LOG] Starting MagicMirror: v2.27.0
      [2024-05-30 14:57:40.910] [LOG] Loading config …
      [2024-05-30 14:57:40.915] [LOG] config template file not exists, no envsubst
      [2024-05-30 14:57:40.927] [LOG] Loading module helpers …
      [2024-05-30 14:57:40.930] [LOG] No helper found for module: alert.
      [2024-05-30 14:57:41.462] [LOG] Initializing new module helper …
      [2024-05-30 14:57:41.465] [LOG] Module helper loaded: updatenotification
      [2024-05-30 14:57:41.466] [LOG] No helper found for module: clock.
      [2024-05-30 14:57:41.796] [LOG] Initializing new module helper …
      [2024-05-30 14:57:41.797] [LOG] Module helper loaded: calendar
      [2024-05-30 14:57:41.802] [LOG] No helper found for module: weather.
      [2024-05-30 14:57:42.005] [LOG] Initializing new module helper …
      [2024-05-30 14:57:42.008] [LOG] Module helper loaded: newsfeed
      [2024-05-30 14:57:42.012] [LOG] Initializing new module helper …
      [2024-05-30 14:57:42.013] [LOG] Module helper loaded: mmm-systemtemperature
      [2024-05-30 14:57:43.886] [ERROR] (node:5145) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘node-fetch’
      Require stack:
      • /home/sforza/MagicMirror/modules/MMM-RTSPtoWeb/node_helper.js
      • /home/sforza/MagicMirror/js/app.js
      • /home/sforza/MagicMirror/js/electron.js
        at Module._resolveFilename (node:internal/modules/cjs/loader:1055:15)
        at s._resolveFilename (node:electron/js2c/browser_init:2:115476)
        at Module._resolveFilename (/home/sforza/MagicMirror/node_modules/module-alias/index.js:49:29)
        at Module._load (node:internal/modules/cjs/loader:908:27)
        at c._load (node:electron/js2c/node_init:2:13672)
        at Module.require (node:internal/modules/cjs/loader:1122:19)
        at require (node:internal/modules/helpers:130:18)
        at Object. (/home/sforza/MagicMirror/modules/MMM-RTSPtoWeb/node_helper.js:2:15)
        at Module._compile (node:internal/modules/cjs/loader:1256:14)
        at Module._extensions…js (node:internal/modules/cjs/loader:1311:10)
        at Module.load (node:internal/modules/cjs/loader:1098:32)
        at Module._load (node:internal/modules/cjs/loader:945:12)
        at loadModule (/home/sforza/MagicMirror/js/app.js:183:19)
        (Use electron --trace-warnings ... to show where the warning was created)
        [2024-05-30 14:57:43.916] [ERROR] (node:5145) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
        [5265:0530/145747.981108:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
        [5265:0530/145747.981646:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
        [5265:0530/145747.982116:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
        [5265:0530/145747.982482:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
        [5265:0530/145747.983029:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
        [5265:0530/145747.983441:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
        [5265:0530/145747.984014:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
        [5265:0530/145747.984499:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
        [5265:0530/145747.985053:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
        [5265:0530/145747.986087:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
        [5265:0530/145747.989123:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
        [5265:0530/145747.989407:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
        [5265:0530/145747.990198:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
        [5265:0530/145747.990576:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
        [5265:0530/145747.999511:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
        [5265:0530/145747.999992:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
        [5265:0530/145748.000610:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
        [5265:0530/145748.001291:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
        [5265:0530/145748.007640:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
        [5265:0530/145748.012479:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
        [5265:0530/145748.016622:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
        [5265:0530/145748.019573:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
        [5265:0530/145748.023712:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
        [5265:0530/145748.025404:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
        [5265:0530/145748.026450:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
        [5265:0530/145748.027096:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
        [5265:0530/145748.028094:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
        [5265:0530/145748.030385:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
        [2024-05-30 14:57:48.589] [INFO] System information:
      SYSTEM: manufacturer: ; model: ; raspberry: undefined; virtual: false
      OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.28+rpt-rpi-v8
      VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 22.2.0; npm: 10.7.0; pm2: 5.3.1
      OTHER: timeZone: Europe/Madrid; ELECTRON_ENABLE_GPU: undefined
      ^C/home/sforza/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
        sdetweil @sforza
        @sforza said in MMM-RTSPtoWeb fresh install:
        Require stack:
        yes, this is an older module that is missing a library we removed
        see this for instructions on how to fix
        note there are 4 or 5 libraries that could be the cause… the error message identifies which…
        this particular library needs a version number added
        so,
        npm install node-fetch@2
        in the affected module folder
          sforza @sdetweil
          @sdetweil thanks a ton for the super fast response! I’m in bed now and turned off the computer already, will surely try tomorrow! If it was not 1:30 am here and waking up early tomorrow I’d try right now! Knowing there is hope to fix it got me really excited!
            sforza @sforza
            It works!!! I could not be happier :D
            Thanks a ton - especially for the accurate instructions.
            Yes I was able to identify the error line quite clearly. However, could you please explain how did you convert “node-fetch” to “node-fetch@2” as the missing module? - other than experience of course?
            Thanks again!
              sdetweil @sforza
              @sforza just experience
                sforza @sdetweil
                @sdetweil thanks for sharing it then!
