    MMM-Navigate cannot be installed
    26 Posts 2 Posters 3.1k Views 2 Watching
      sdetweil @Klaleu
      @Klaleu said in MMM-Navigate cannot be installed:
      error command failed
      107 error command sh -c ./postinstall
      there is a postinstall script
      can you try to run it
      in the module folder do
      ./postinstall
      if it says commabd not found or permission denied, then do
      chmod +x postinstall
      and try it again
      • K Offline
        Klaleu
        Dear Sam,
        Many thanks for the quick response. I tried to implement your suggestions, unfortunately without success. But as a non-programmer, I’m not sure whether I did everything right and whether I understood you correctly. Here is a section of my screen. I hope you recognize my mistake and can help me further:
        klaus@raspberrypi:~/MagicMirror/modules/MMM-Navigate $ ./postinstall
        ./postinstall: line 8: …/…/node_modules/.bin/electron-rebuild: Permission deni ed
        klaus@raspberrypi:~/MagicMirror/modules/MMM-Navigate $ chmod +x postinstall
        klaus@raspberrypi:~/MagicMirror/modules/MMM-Navigate $ npm install
        MagicMirror-Module-Navigate@1.6.0 postinstall
        ./postinstall
        ./postinstall: line 8: …/…/node_modules/.bin/electron-rebuild: Permission denied
        npm ERR! code 126
        npm ERR! path /home/klaus/MagicMirror/modules/MMM-Navigate
        npm ERR! command failed
        npm ERR! command sh -c ./postinstall
        npm ERR! A complete log of this run can be found in: /home/klaus/.npm/_logs/2024-06-13T09_49_42_926Z-debug-0.log
        Klaus
          sdetweil @Klaleu
          hm…
          have you ever used sudo for any npm command for MagicMirror? please don’t
          can you do this and show results
          ls -laF node_modules/.bin/electron-rebuild
          • K Offline
            Klaleu
            Hello Sam,
            Thank you for your suggestion to solve the problem. I deleted the old installation of MMM-Navigate by deleting the MMM-Navigate folder in the /MagicMirror/modules/. I then carried out electron-rebuild, unfortunately the following reinstallation of MMM-Navigate resulted in the same errors . Here is a section of my screen.
            klaus@raspberrypi:~/MagicMirror $ ls -laF node_modules/.bin/electron-rebuild
            lrwxrwxrwx 1 klaus klaus 34 Jun 12 11:38 node_modules/.bin/electron-rebuild -> . ./electron-rebuild/lib/src/cli.js
            klaus@raspberrypi:~/MagicMirror $ cd ~/MagicMirror/modules/
            klaus@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/Ax-LED/MMM-Navigate
            Cloning into ‘MMM-Navigate’…
            remote: Enumerating objects: 122, done.
            remote: Counting objects: 100% (45/45), done.
            remote: Compressing objects: 100% (28/28), done.
            remote: Total 122 (delta 24), reused 32 (delta 17), pack-reused 77
            Receiving objects: 100% (122/122), 442.08 KiB | 449.00 KiB/s, done.
            Resolving deltas: 100% (63/63), done.
            klaus@raspberrypi:~/MagicMirror/modules $ cd MMM-Navigate
            ./postinstall
            npm ERR! code 126
            npm ERR! A complete log of this run can be found in: /home/klaus/.npm/_logs/2024-06-13T13_55_36_051Z-debug-0.log
            Do you have any suggestions as to what I can try to get an error-free installation?
            For information - I use:
            • Raspberry Pi 4
            • Raspbian GNU/Linux Version 11
            • Modules: alert, updatenotification, MMM-Pages, clock, calendar, MMM-DWD-Pollen, complements, weather, MMM-birthdays, MMM-Rest, MMM-Globe, MMM-RAIN-MAP, newsfeed
            Klaus
              sdetweil @Klaleu
              @Klaleu but the problem is outside the mmm-navigate folder
              please provide the information i asked for
              • K Offline
                Klaleu
                Hello Sam,
                I forgot to answer the question. Your question was: Have you ever used sudo for any npm command for MagicMirror? As far as I can remember, I ran the following commands: and <sudo npm install -g pm2>. If that is the problem, how can I solve it to be able to install MMM-Navigate.
                PS I installed over ten modules for my Magic Mirror and none of them had any problems.
                  sdetweil @Klaleu
                  @Klaleu I asked you to do
                  ls -laF ~/MagicMirror/node_modules/.bin/electron-rebuild
                  • K Offline
                    Klaleu
                    Hello Sam,
                    Yes, I did it. For the result please see the LOG file in my answer of Jun 13, 2024, 4:41 PM.
                    I hope I followed your instructions correctly.
                    Thank you for your efforts.
                    Klaus
                      sdetweil @Klaleu
                      @Klaleu log file where?
                      • K Offline
                        Klaleu
                        I mean this excerpt from the LOG_file (see my answer of Jun 13, 2024, 4:41 PM):
                        ./postinstall
                        npm ERR! code 126
                        You can see I did “electron-rebuild” and after that I tried to install MMM-Navigate without any success.
                        I you need the hole LOG-File, or is the excerpt sufficient?
                        Greatings Klaus
