    MMM-Navigate cannot be installed
    26 Posts 2 Posters 2.9k Views 2 Watching
    • K Offline
      Klaleu
      I installed MMM-Navigate according to the description on https://github.com/Ax-LED/MMM-Navigate. Unfortunately, there are error messages that, as a “non-programmer”, give me no clues as to how to fix it. Here is the LOG file of the installation:
      0 verbose cli /usr/local/bin/node /usr/local/bin/npm
      1 info using npm@10.1.0
      2 info using node@v20.8.0
      3 timing npm:load:whichnode Completed in 9ms
      4 timing config:load:defaults Completed in 6ms
      5 timing config:load:file:/usr/local/lib/node_modules/npm/npmrc Completed in 2ms
      6 timing config:load:builtin Completed in 3ms
      7 timing config:load:cli Completed in 10ms
      8 timing config:load:env Completed in 0ms
      9 timing config:load:file:/home/klaus/MagicMirror/modules/MMM-Navigate/.npmrc Completed in 0ms
      10 timing config:load:project Completed in 16ms
      11 timing config:load:file:/home/klaus/.npmrc Completed in 0ms
      12 timing config:load:user Completed in 0ms
      13 timing config:load:file:/usr/local/etc/npmrc Completed in 1ms
      14 timing config:load:global Completed in 1ms
      15 timing config:load:setEnvs Completed in 8ms
      16 timing config:load Completed in 51ms
      17 timing npm:load:configload Completed in 51ms
      18 timing config:load:flatten Completed in 15ms
      19 timing npm:load:mkdirpcache Completed in 2ms
      20 timing npm:load:mkdirplogs Completed in 1ms
      21 verbose title npm install
      22 verbose argv “install”
      23 timing npm:load:setTitle Completed in 2ms
      24 timing npm:load:display Completed in 8ms
      25 verbose logfile logs-max:10 dir:/home/klaus/.npm/_logs/2024-06-12T12_09_51_699Z-
      26 verbose logfile /home/klaus/.npm/_logs/2024-06-12T12_09_51_699Z-debug-0.log
      27 timing npm:load:logFile Completed in 40ms
      28 timing npm:load:timers Completed in 1ms
      29 timing npm:load:configScope Completed in 0ms
      30 timing npm:load Completed in 201ms
      31 timing arborist:ctor Completed in 8ms
      32 silly logfile start cleaning logs, removing 2 files
      33 timing arborist:ctor Completed in 0ms
      34 silly logfile done cleaning log files
      35 timing idealTree:init Completed in 98ms
      36 timing idealTree:userRequests Completed in 2ms
      37 silly idealTree buildDeps
      38 silly fetch manifest onoff@latest
      39 http fetch GET 200 https://registry.npmjs.org/onoff 1321ms (cache revalidated)
      40 silly placeDep ROOT onoff@6.0.3 OK for: MagicMirror-Module-Navigate@1.6.0 want: latest
      41 silly fetch manifest epoll@^4.0.1
      42 silly fetch manifest lodash.debounce@^4.0.8
      43 http fetch GET 200 https://registry.npmjs.org/lodash.debounce 247ms (cache revalidated)
      44 http fetch GET 200 https://registry.npmjs.org/epoll 1028ms (cache revalidated)
      45 timing idealTree:#root Completed in 2418ms
      46 silly placeDep ROOT epoll@4.0.2 OK for: onoff@6.0.3 want: ^4.0.1
      47 silly fetch manifest bindings@^1.5.0
      48 silly fetch manifest nan@^2.17.0
      49 silly placeDep ROOT lodash.debounce@4.0.8 OK for: onoff@6.0.3 want: ^4.0.8
      50 http fetch GET 200 https://registry.npmjs.org/nan 162ms (cache revalidated)
      51 http fetch GET 200 https://registry.npmjs.org/bindings 465ms (cache revalidated)
      52 timing idealTree:node_modules/onoff Completed in 496ms
      53 silly placeDep ROOT bindings@1.5.0 OK for: epoll@4.0.2 want: ^1.5.0
      54 silly fetch manifest file-uri-to-path@1.0.0
      55 silly placeDep ROOT nan@2.20.0 OK for: epoll@4.0.2 want: ^2.17.0
      56 http fetch GET 200 https://registry.npmjs.org/file-uri-to-path 148ms (cache revalidated)
      57 timing idealTree:node_modules/epoll Completed in 168ms
      58 silly placeDep ROOT file-uri-to-path@1.0.0 OK for: bindings@1.5.0 want: 1.0.0
      59 timing idealTree:node_modules/bindings Completed in 15ms
      60 timing idealTree:node_modules/file-uri-to-path Completed in 1ms
      61 timing idealTree:node_modules/lodash.debounce Completed in 0ms
      62 timing idealTree:node_modules/nan Completed in 0ms
      63 timing idealTree:buildDeps Completed in 3103ms
      64 timing idealTree:fixDepFlags Completed in 2ms
      65 timing idealTree Completed in 3221ms
      66 timing reify:loadTrees Completed in 3227ms
      67 timing reify:diffTrees Completed in 4ms
      68 silly reify moves {}
      69 timing reify:retireShallow Completed in 4ms
      70 timing reify:createSparse Completed in 9ms
      71 timing reify:loadBundles Completed in 0ms
      72 silly audit bulk request {
      72 silly audit onoff: [ ‘6.0.3’ ],
      72 silly audit epoll: [ ‘4.0.2’ ],
      72 silly audit ‘lodash.debounce’: [ ‘4.0.8’ ],
      72 silly audit bindings: [ ‘1.5.0’ ],
      72 silly audit nan: [ ‘2.20.0’ ],
      72 silly audit ‘file-uri-to-path’: [ ‘1.0.0’ ]
      72 silly audit }
      73 timing reifyNode:node_modules/bindings Completed in 278ms
      74 timing reifyNode:node_modules/lodash.debounce Completed in 284ms
      75 timing reifyNode:node_modules/file-uri-to-path Completed in 299ms
      76 timing reifyNode:node_modules/epoll Completed in 384ms
      77 timing reifyNode:node_modules/onoff Completed in 397ms
      78 timing reifyNode:node_modules/nan Completed in 417ms
      79 timing reify:unpack Completed in 419ms
      80 timing reify:unretire Completed in 0ms
      81 timing build:queue Completed in 5ms
      82 info run epoll@4.0.2 install node_modules/epoll node-gyp rebuild
      83 http fetch POST 200 https://registry.npmjs.org/-/npm/v1/security/advisories/bulk 572ms
      84 timing auditReport:getReport Completed in 584ms
      85 silly audit report {}
      86 timing auditReport:init Completed in 0ms
      87 timing reify:audit Completed in 591ms
      88 info run epoll@4.0.2 install { code: 0, signal: null }
      89 timing build:run:install:node_modules/epoll Completed in 15212ms
      90 timing build:run:install Completed in 15213ms
      91 timing build:deps Completed in 15223ms
      92 timing build Completed in 15223ms
      93 timing reify:build Completed in 15224ms
      94 timing reify:trash Completed in 0ms
      95 timing reify:save Completed in 34ms
      96 timing reify Completed in 19054ms
      97 timing command:install Completed in 19108ms
      98 verbose stack Error: command failed
      98 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:53:27)
      98 verbose stack at ChildProcess.emit (node:events:514:28)
      98 verbose stack at maybeClose (node:internal/child_process:1105:16)
      98 verbose stack at ChildProcess._handle.onexit (node:internal/child_process:305:5)
      99 verbose pkgid MagicMirror-Module-Navigate@1.6.0
      100 verbose cwd /home/klaus/MagicMirror/modules/MMM-Navigate
      101 verbose Linux 6.1.21-v8+
      102 verbose node v20.8.0
      103 verbose npm v10.1.0
      104 error code 126
      105 error path /home/klaus/MagicMirror/modules/MMM-Navigate
      106 error command failed
      107 error command sh -c ./postinstall
      108 verbose exit 126
      109 timing npm Completed in 20828ms
      110 verbose code 126
      111 error A complete log of this run can be found in: /home/klaus/.npm/_logs/2024-06-12T12_09_51_699Z-debug-0.log
      Any tips on what I can and must do to ensure an error-free installation would be greatly appreciated.
      • K Offline
        Klaleu
        Hello Sam,
        Thank you for continuing to try to solve the problem.
        I have carried out:
        rm -rf node_modules
        npm run install-mm
        and after that:
        cd modules/MMM-Navigate
        ./postinstall
        without problems.
        Last I did:
        npm start
        This is the result:
        klaus@raspberrypi:~ $ cd ~/MagicMirror
        klaus@raspberrypi:~/MagicMirror $ npm start
        magicmirror@2.27.0 start
        [2024-06-17 11:35:52.232] [LOG] Starting MagicMirror: v2.27.0
        [2024-06-17 11:35:52.333] [LOG] Loading config …
        [2024-06-17 11:35:52.344] [LOG] config template file not exists, no envsubst
        [2024-06-17 11:35:52.354] [LOG] Loading module helpers …
        [2024-06-17 11:35:52.360] [LOG] No helper found for module: alert.
        [2024-06-17 11:35:53.076] [LOG] Initializing new module helper …
        [2024-06-17 11:35:53.078] [LOG] Module helper loaded: updatenotification
        [2024-06-17 11:35:53.080] [LOG] No helper found for module: MMM-pages.
        [2024-06-17 11:35:53.081] [LOG] No helper found for module: clock.
        [2024-06-17 11:35:53.466] [LOG] Initializing new module helper …
        [2024-06-17 11:35:53.472] [LOG] Module helper loaded: calendar
        [2024-06-17 11:35:54.236] [LOG] Initializing new module helper …
        [2024-06-17 11:35:54.241] [LOG] Module helper loaded: MMM-DWD-Pollen
        [2024-06-17 11:35:54.242] [LOG] No helper found for module: compliments.
        [2024-06-17 11:35:54.243] [LOG] No helper found for module: weather.
        [2024-06-17 11:35:54.275] [LOG] Initializing new module helper …
        [2024-06-17 11:35:54.275] [LOG] Module helper loaded: MMM-birthdays
        [2024-06-17 11:35:54.720] [LOG] Initializing new module helper …
        [2024-06-17 11:35:54.723] [LOG] Module helper loaded: MMM-Rest
        [2024-06-17 11:35:54.725] [LOG] No helper found for module: MMM-Globe.
        [2024-06-17 11:35:54.725] [LOG] No helper found for module: MMM-RAIN-MAP.
        [2024-06-17 11:35:54.893] [LOG] Initializing new module helper …
        [2024-06-17 11:35:54.893] [LOG] Module helper loaded: newsfeed
        [2024-06-17 11:35:54.893] [LOG] All module helpers loaded.
        [2024-06-17 11:35:54.909] [LOG] Starting server on port 8080 …
        [2024-06-17 11:35:57.767] [ERROR] Whoops! There was an uncaught exception…
        [2024-06-17 11:35:57.823] [ERROR] Error: listen EADDRINUSE: address already in use ::1:8080
        at Server.setupListenHandle [as _listen2] (node:net:1872:16)
        at listenInCluster (node:net:1920:12)
        at GetAddrInfoReqWrap.doListen [as callback] (node:net:2069:7)
        at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:109:8) {
        code: ‘EADDRINUSE’,
        errno: -98,
        syscall: ‘listen’,
        address: ‘::1’,
        port: 8080
        [2024-06-17 11:35:57.850] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [2024-06-17 11:35:57.862] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
        [2024-06-17 11:36:07.657] [INFO] System information:
        SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.2; raspberry: [object Object]; virtual: false
        OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v8+
        VERSIONS: electron: 29.3.1; used node: 20.9.0; installed node: 20.8.0; npm: 10.1.0; pm2: 5.3.1
        OTHER: timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
        The internet connection was stabile, it can’t be the reason for the problem.
        I hope you can interpret the result and have a suggestion on how to proceed.
        Greetings
        Klaus
          sdetweil @Klaleu
          @Klaleu said in MMM-Navigate cannot be installed:
          there is a postinstall script
          can you try to run it
          in the module folder do
          ./postinstall
          if it says commabd not found or permission denied, then do
          chmod +x postinstall
          and try it again
          • K Offline
            Klaleu
            Dear Sam,
            Many thanks for the quick response. I tried to implement your suggestions, unfortunately without success. But as a non-programmer, I’m not sure whether I did everything right and whether I understood you correctly. Here is a section of my screen. I hope you recognize my mistake and can help me further:
            klaus@raspberrypi:~/MagicMirror/modules/MMM-Navigate $ ./postinstall
            ./postinstall: line 8: …/…/node_modules/.bin/electron-rebuild: Permission deni ed
            klaus@raspberrypi:~/MagicMirror/modules/MMM-Navigate $ chmod +x postinstall
            klaus@raspberrypi:~/MagicMirror/modules/MMM-Navigate $ npm install
            MagicMirror-Module-Navigate@1.6.0 postinstall
            ./postinstall
            ./postinstall: line 8: …/…/node_modules/.bin/electron-rebuild: Permission denied
            npm ERR! code 126
            npm ERR! path /home/klaus/MagicMirror/modules/MMM-Navigate
            npm ERR! command failed
            npm ERR! command sh -c ./postinstall
            npm ERR! A complete log of this run can be found in: /home/klaus/.npm/_logs/2024-06-13T09_49_42_926Z-debug-0.log
            Klaus
              sdetweil @Klaleu
              hm…
              have you ever used sudo for any npm command for MagicMirror? please don’t
              can you do this and show results
              ls -laF node_modules/.bin/electron-rebuild
              • K Offline
                Klaleu
                Hello Sam,
                Thank you for your suggestion to solve the problem. I deleted the old installation of MMM-Navigate by deleting the MMM-Navigate folder in the /MagicMirror/modules/. I then carried out electron-rebuild, unfortunately the following reinstallation of MMM-Navigate resulted in the same errors . Here is a section of my screen.
                klaus@raspberrypi:~/MagicMirror $ ls -laF node_modules/.bin/electron-rebuild
                lrwxrwxrwx 1 klaus klaus 34 Jun 12 11:38 node_modules/.bin/electron-rebuild -> . ./electron-rebuild/lib/src/cli.js
                klaus@raspberrypi:~/MagicMirror $ cd ~/MagicMirror/modules/
                klaus@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/Ax-LED/MMM-Navigate
                Cloning into ‘MMM-Navigate’…
                remote: Enumerating objects: 122, done.
                remote: Counting objects: 100% (45/45), done.
                remote: Compressing objects: 100% (28/28), done.
                remote: Total 122 (delta 24), reused 32 (delta 17), pack-reused 77
                Receiving objects: 100% (122/122), 442.08 KiB | 449.00 KiB/s, done.
                Resolving deltas: 100% (63/63), done.
                klaus@raspberrypi:~/MagicMirror/modules $ cd MMM-Navigate
                ./postinstall
                npm ERR! code 126
                npm ERR! A complete log of this run can be found in: /home/klaus/.npm/_logs/2024-06-13T13_55_36_051Z-debug-0.log
                Do you have any suggestions as to what I can try to get an error-free installation?
                For information - I use:
                • Raspberry Pi 4
                • Raspbian GNU/Linux Version 11
                • Modules: alert, updatenotification, MMM-Pages, clock, calendar, MMM-DWD-Pollen, complements, weather, MMM-birthdays, MMM-Rest, MMM-Globe, MMM-RAIN-MAP, newsfeed
                Klaus
                  sdetweil @Klaleu
                  @Klaleu but the problem is outside the mmm-navigate folder
                  please provide the information i asked for
                  • K Offline
                    Klaleu
                    Hello Sam,
                    I forgot to answer the question. Your question was: Have you ever used sudo for any npm command for MagicMirror? As far as I can remember, I ran the following commands: and <sudo npm install -g pm2>. If that is the problem, how can I solve it to be able to install MMM-Navigate.
                    PS I installed over ten modules for my Magic Mirror and none of them had any problems.
                      sdetweil @Klaleu
                      @Klaleu I asked you to do
                      ls -laF ~/MagicMirror/node_modules/.bin/electron-rebuild
                      • K Offline
                        Klaleu
                        Hello Sam,
                        Yes, I did it. For the result please see the LOG file in my answer of Jun 13, 2024, 4:41 PM.
                        I hope I followed your instructions correctly.
                        Thank you for your efforts.
                        Klaus
                          sdetweil @Klaleu
                          @Klaleu log file where?
