    MMM-Navigate cannot be installed
    26 Posts 2 Posters 5.3k Views 2 Watching
    • K Offline
      Klaleu
      Hello Sam,
      I forgot to answer the question. Your question was: Have you ever used sudo for any npm command for MagicMirror? As far as I can remember, I ran the following commands: and <sudo npm install -g pm2>. If that is the problem, how can I solve it to be able to install MMM-Navigate.
      PS I installed over ten modules for my Magic Mirror and none of them had any problems.
        sdetweil @Klaleu
        @Klaleu I asked you to do
        ls -laF ~/MagicMirror/node_modules/.bin/electron-rebuild
        • K Offline
          Klaleu
          Hello Sam,
          Yes, I did it. For the result please see the LOG file in my answer of Jun 13, 2024, 4:41 PM.
          I hope I followed your instructions correctly.
          Thank you for your efforts.
          Klaus
            sdetweil @Klaleu
            @Klaleu log file where?
            • K Offline
              Klaleu
              I mean this excerpt from the LOG_file (see my answer of Jun 13, 2024, 4:41 PM):
              klaus@raspberrypi:~/MagicMirror $ ls -laF node_modules/.bin/electron-rebuild
              lrwxrwxrwx 1 klaus klaus 34 Jun 12 11:38 node_modules/.bin/electron-rebuild -> . ./electron-rebuild/lib/src/cli.js
              klaus@raspberrypi:~/MagicMirror $ cd ~/MagicMirror/modules/
              klaus@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/Ax-LED/MMM-Navigate
              Cloning into ‘MMM-Navigate’…
              remote: Enumerating objects: 122, done.
              remote: Counting objects: 100% (45/45), done.
              remote: Compressing objects: 100% (28/28), done.
              remote: Total 122 (delta 24), reused 32 (delta 17), pack-reused 77
              Receiving objects: 100% (122/122), 442.08 KiB | 449.00 KiB/s, done.
              Resolving deltas: 100% (63/63), done.
              klaus@raspberrypi:~/MagicMirror/modules $ cd MMM-Navigate
              klaus@raspberrypi:~/MagicMirror/modules/MMM-Navigate $ npm install
              MagicMirror-Module-Navigate@1.6.0 postinstall
              ./postinstall
              ./postinstall: line 8: …/…/node_modules/.bin/electron-rebuild: Permission denied
              npm ERR! code 126
              npm ERR! path /home/klaus/MagicMirror/modules/MMM-Navigate
              npm ERR! command failed
              npm ERR! command sh -c ./postinstall
              You can see I did “electron-rebuild” and after that I tried to install MMM-Navigate without any success.
              I you need the hole LOG-File, or is the excerpt sufficient?
              Greatings Klaus
                sdetweil @Klaleu
                @Klaleu I need you to execute the command I listed, now
                and show it’s results
                I need to determine what the permission problem is exactly before I can tell you how to resolve it
                • K Offline
                  Klaleu
                  Hello Sam,
                  You wrote: " I need you to execute the command I listed, now and show it’s results"
                  Now I’m a little bit confused. I executed severel commands you asked my for and dokumented the results.
                  Please write to me exactly what I need to do to provide you with the information to isolate the problem. Unfortunately, I’m just a layman and can’t get any further in this case on my own and need help from experienced programmers.
                  Thank you.
                  Klaus
                    sdetweil @Klaleu
                    @Klaleu see here
                    https://forum.magicmirror.builders/post/118270
                    and here
                    https://forum.magicmirror.builders/post/118252
                    • K Offline
                      Klaleu
                      Dear Sam,
                      Yes, I have already executed these commands:
                      and
                      ls -laF node_modules/.bin/electron-rebuild-
                      and sent the results to you.
                      Please tell me what I did wrong so that the results were not meaningful for you.
                      A nice Weekend for you.
                      Klaus
                        sdetweil @Klaleu
                        @Klaleu said in MMM-Navigate cannot be installed:
                        where? I am not the module author. I don’t see a text message here from you
                        and I didn’t give you my email
                        edit: sorry, I found it, burried in other messages,
                        very weird… SO, try this
                        npm uninstall @electron/rebuild
                        then , to see if this is fixed by having the postinstall script reinstall it…
                        cd modules/MMM-Navigate
                        ./postinstall
                        this approach was copied from me, so I am confused why it is failing
                        • K Offline
                          Klaleu
                          Dear Sam,
                          This was the result:
                          klaus@raspberrypi:~ $ cd ~/MagicMirror
                          klaus@raspberrypi:~/MagicMirror $ npm uninstall @electron/rebuild
                          up to date in 19s
                          216 packages are looking for funding
                          run npm fund for details
                          klaus@raspberrypi:~/MagicMirror $ npm fund
                          magicmirror@2.27.0
                          ├── https://patreon.com/biodiscus
                          │ └── ansis@2.3.0
                          ├─┬ https://opencollective.com/eslint
                          │ │ └── eslint@8.57.0, @eslint/eslintrc@2.1.4, eslint-scope@7.2.2, eslint-visito r-keys@3.4.3, espree@9.6.1
                          │ ├── https://github.com/sponsors/nzakas
                          │ │ └── @humanwhocodes/module-importer@1.0.1
                          │ ├── https://github.com/sponsors/epoberezkin
                          │ │ └── ajv@6.12.6, ajv@8.12.0
                          │ └── https://github.com/sponsors/feross
                          │ └── run-parallel@1.2.0, queue-microtask@1.2.3, buffer@5.7.1, base64-js@1.5 .1, ieee754@1.2.1, safe-buffer@5.2.1, run-series@1.1.9
                          ├── https://www.buymeacoffee.com/systeminfo
                          │ └── systeminformation@5.22.7
                          ├─┬ https://github.com/sindresorhus/eslint-plugin-unicorn?sponsor=1
                          │ │ └── eslint-plugin-unicorn@51.0.1
                          │ ├── https://github.com/sponsors/sibiraj-s
                          │ │ └── ci-info@4.0.0, ci-info@3.9.0
                          │ └─┬ https://opencollective.com/core-js
                          │ │ └── core-js-compat@3.37.0
                          │ └── https://opencollective.com/browserslist
                          │ └── browserslist@4.23.0, caniuse-lite@1.0.30001612, update-browserslist- db@1.0.13
                          ├── https://github.com/sponsors/typicode
                          │ └── husky@9.0.11
                          ├─┬ https://opencollective.com/lint-staged
                          │ │ └── lint-staged@15.2.2
                          │ ├── https://github.com/chalk/chalk?sponsor=1
                          │ │ └── chalk@5.3.0, chalk@4.1.2
                          │ ├─┬ https://github.com/sindresorhus/execa?sponsor=1
                          │ │ │ └── execa@8.0.1, execa@5.1.1
                          │ │ └── https://github.com/sponsors/isaacs
                          │ │ └── signal-exit@4.1.0, glob@8.1.0, rimraf@3.0.2
                          │ └── https://github.com/chalk/wrap-ansi?sponsor=1
                          │ └── wrap-ansi@9.0.0, wrap-ansi@7.0.0
                          ├── https://github.com/prettier/prettier?sponsor=1
                          │ └── prettier@3.2.5
                          ├── https://opencollective.com/sinon
                          │ └── sinon@17.0.1
                          ├─┬ https://opencollective.com/stylelint
                          │ │ └── stylelint@16.4.0
                          │ ├── https://github.com/sponsors/csstools
                          │ │ └── @csstools/css-parser-algorithms@2.6.1, @csstools/css-tokenizer@2.2.4, @csstools/media-query-list-parser@2.1.9, @csstools/selector-specificity@3.0.3
                          │ ├── https://github.com/sponsors/wooorm
                          │ │ └── @dual-bundle/import-meta-resolve@4.0.0, mathml-tag-names@2.1.3
                          │ ├── https://github.com/sponsors/d-fischer
                          │ │ └── cosmiconfig@9.0.0
                          │ └─┬ https://opencollective.com/postcss/
                          │ │ └── postcss@8.4.38, postcss-safe-parser@7.0.0
                          │ └── https://github.com/sponsors/ai
                          │ └── nanoid@3.3.7
                          ├── https://github.com/sponsors/malept
                          │ └── @malept/cross-spawn-promise@2.0.0
                          ├─┬ https://github.com/sindresorhus/got?sponsor=1
                          │ │ └── got@11.8.6
                          │ └── https://github.com/sindresorhus/is?sponsor=1
                          │ └── @sindresorhus/is@4.6.0
                          ├── https://github.com/sponsors/ljharb
                          │ └── string.prototype.matchall@4.0.11, call-bind@1.0.7, function-bind@1.1.2, define-data-property@1.1.4, has-property-descriptors@1.0.2, define-properties@1. 2.1, es-abstract@1.23.3, array-buffer-byte-length@1.0.1, arraybuffer.prototype.s lice@1.0.3, available-typed-arrays@1.0.7, data-view-buffer@1.0.1, data-view-byte -length@1.0.1, data-view-byte-offset@1.0.0, es-to-primitive@1.2.1, is-date-objec t@1.0.5, is-symbol@1.0.4, function.prototype.name@1.1.6, functions-have-names@1. 2.3, get-symbol-description@1.0.2, globalthis@1.0.3, has-proto@1.0.3, is-array-b uffer@3.0.4, is-callable@1.2.7, is-data-view@1.0.1, is-negative-zero@2.0.3, is-r egex@1.1.4, is-shared-array-buffer@1.0.3, is-string@1.0.7, is-typed-array@1.1.13 , is-weakref@1.0.2, object-inspect@1.13.1, object.assign@4.1.5, safe-array-conca t@1.1.2, safe-regex-test@1.0.3, string.prototype.trim@1.2.9, string.prototype.tr imend@1.0.8, string.prototype.trimstart@1.0.8, typed-array-byte-length@1.0.1, ty ped-array-byte-offset@1.0.2, typed-array-length@1.0.6, unbox-primitive@1.0.2, ha s-bigints@1.0.2, which-boxed-primitive@1.0.2, is-bigint@1.0.4, is-boolean-object @1.1.2, is-number-object@1.0.7, which-typed-array@1.1.15, has-tostringtag@1.0.2, get-intrinsic@1.2.4, gopd@1.0.1, has-symbols@1.0.3, regexp.prototype.flags@1.5. 2, side-channel@1.0.6, minimist@1.2.8, qs@6.11.0, resolve@1.22.8, is-core-module @2.13.1, supports-preserve-symlinks-flag@1.0.0, array-includes@3.1.8, array.prot otype.findlastindex@1.2.5, array.prototype.flat@1.3.2, array.prototype.flatmap@1 .3.2, object.fromentries@2.0.8, object.values@1.2.0
                          ├─┬ https://ko-fi.com/killymxi
                          │ │ └── @selderee/plugin-htmlparser2@0.11.0, selderee@0.11.0, parseley@0.12.1, l eac@0.6.0, peberminta@0.9.0
                          │ └─┬ https://github.com/fb55/domhandler?sponsor=1
                          │ │ └── domhandler@5.0.3
                          │ └── https://github.com/sponsors/fb55
                          │ └── domelementtype@2.3.0
                          ├─┬ https://github.com/cheeriojs/dom-serializer?sponsor=1
                          │ │ └── dom-serializer@2.0.0
                          │ └── https://github.com/fb55/entities?sponsor=1
                          │ └── entities@4.5.0
                          ├─┬ https://github.com/fb55/htmlparser2?sponsor=1
                          │ │ └── htmlparser2@8.0.2
                          │ └── https://github.com/fb55/domutils?sponsor=1
                          │ └── domutils@3.1.0
                          ├── https://github.com/sponsors/broofa
                          │ └── uuid@9.0.1
                          ├── https://github.com/sponsors/RubenVerborgh
                          │ └── follow-redirects@1.15.6
                          ├─┬ https://paulmillr.com/funding/
                          │ │ └── chokidar@3.6.0
                          │ └── https://github.com/sponsors/jonschlinkert
                          │ └── picomatch@2.3.1, picomatch@4.0.2
                          ├── https://opencollective.com/typescript-eslint
                          │ └── @typescript-eslint/utils@5.62.0, @typescript-eslint/scope-manager@5.62.0 , @typescript-eslint/visitor-keys@5.62.0, @typescript-eslint/types@5.62.0, @type script-eslint/typescript-estree@5.62.0
                          ├── https://github.com/sponsors/ota-meshi
                          │ └── jsonc-eslint-parser@2.4.0
                          ├── https://github.com/fisker/git-hooks-list?sponsor=1
                          │ └── git-hooks-list@1.0.3
                          ├── https://opencollective.com/babel
                          │ └── @babel/core@7.24.4
                          ├── https://github.com/chalk/supports-color?sponsor=1
                          │ └── supports-color@8.1.1
                          ├── https://github.com/sponsors/dubzzz
                          │ └── pure-rand@6.1.0
                          ├── https://github.com/sindresorhus/emittery?sponsor=1
                          │ └── emittery@0.13.1
                          └── https://github.com/inikulin/parse5?sponsor=1
                          └── parse5@7.1.2
                          After that I executed these commands:
                          ./postinstall
                          klaus@raspberrypi:~/MagicMirror $ cd modules/MMM-Navigate
                          klaus@raspberrypi:~/MagicMirror/modules/MMM-Navigate $ ./postinstall
                          and and postinstall is not carried out.
                          I hope you can interpret the results.
                          Klaus
                            sdetweil @Klaleu
                            @Klaleu no idea.
                            never run npm audit or npm fund
                            • K Offline
                              Klaleu
                              Ok.
                              What would you do now if you were me? I only see one option: reinstalling the basic configuration of the Magic Mirror and then installing MMM-Navigate as the first module. Maybe a module I’ve already installed is causing access to be denied. What do you think?
                              First of all, thank you very much for taking the time to help me.
                              Klaus
                                sdetweil @Klaleu
                                @Klaleu let’s try this
                                rm -rf node_modules
                                npm run install-mm
                                then
                                ./postinstall
                                then
                                cd  ~/MagicMirror
                                npm start
                                • K Offline
                                  Klaleu
                                  Hello Sam,
                                  Thank you for continuing to try to solve the problem.
                                  I have carried out:
                                  rm -rf node_modules
                                  npm run install-mm
                                  and after that:
                                  ./postinstall
                                  without problems.
                                  Last I did:
                                  npm start
                                  This is the result:
                                  klaus@raspberrypi:~/MagicMirror $ npm start
                                  magicmirror@2.27.0 start
                                  [2024-06-17 11:35:52.232] [LOG] Starting MagicMirror: v2.27.0
                                  [2024-06-17 11:35:52.333] [LOG] Loading config …
                                  [2024-06-17 11:35:52.344] [LOG] config template file not exists, no envsubst
                                  [2024-06-17 11:35:52.354] [LOG] Loading module helpers …
                                  [2024-06-17 11:35:52.360] [LOG] No helper found for module: alert.
                                  [2024-06-17 11:35:53.076] [LOG] Initializing new module helper …
                                  [2024-06-17 11:35:53.078] [LOG] Module helper loaded: updatenotification
                                  [2024-06-17 11:35:53.080] [LOG] No helper found for module: MMM-pages.
                                  [2024-06-17 11:35:53.081] [LOG] No helper found for module: clock.
                                  [2024-06-17 11:35:53.466] [LOG] Initializing new module helper …
                                  [2024-06-17 11:35:53.472] [LOG] Module helper loaded: calendar
                                  [2024-06-17 11:35:54.236] [LOG] Initializing new module helper …
                                  [2024-06-17 11:35:54.241] [LOG] Module helper loaded: MMM-DWD-Pollen
                                  [2024-06-17 11:35:54.242] [LOG] No helper found for module: compliments.
                                  [2024-06-17 11:35:54.243] [LOG] No helper found for module: weather.
                                  [2024-06-17 11:35:54.275] [LOG] Initializing new module helper …
                                  [2024-06-17 11:35:54.275] [LOG] Module helper loaded: MMM-birthdays
                                  [2024-06-17 11:35:54.720] [LOG] Initializing new module helper …
                                  [2024-06-17 11:35:54.723] [LOG] Module helper loaded: MMM-Rest
                                  [2024-06-17 11:35:54.725] [LOG] No helper found for module: MMM-Globe.
                                  [2024-06-17 11:35:54.725] [LOG] No helper found for module: MMM-RAIN-MAP.
                                  [2024-06-17 11:35:54.893] [LOG] Initializing new module helper …
                                  [2024-06-17 11:35:54.893] [LOG] Module helper loaded: newsfeed
                                  [2024-06-17 11:35:54.893] [LOG] All module helpers loaded.
                                  [2024-06-17 11:35:54.909] [LOG] Starting server on port 8080 …
                                  [2024-06-17 11:35:57.767] [ERROR] Whoops! There was an uncaught exception…
                                  [2024-06-17 11:35:57.823] [ERROR] Error: listen EADDRINUSE: address already in use ::1:8080
                                  at Server.setupListenHandle [as _listen2] (node:net:1872:16)
                                  at listenInCluster (node:net:1920:12)
                                  at GetAddrInfoReqWrap.doListen [as callback] (node:net:2069:7)
                                  at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:109:8) {
                                  code: ‘EADDRINUSE’,
                                  errno: -98,
                                  syscall: ‘listen’,
                                  address: ‘::1’,
                                  port: 8080
                                  [2024-06-17 11:35:57.850] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                  [2024-06-17 11:35:57.862] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                                  [2024-06-17 11:36:07.657] [INFO] System information:
                                  SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.2; raspberry: [object Object]; virtual: false
                                  OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v8+
                                  VERSIONS: electron: 29.3.1; used node: 20.9.0; installed node: 20.8.0; npm: 10.1.0; pm2: 5.3.1
                                  OTHER: timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                                  The internet connection was stabile, it can’t be the reason for the problem.
                                  I hope you can interpret the result and have a suggestion on how to proceed.
                                  Greetings
                                  Klaus
                                    sdetweil @Klaleu
                                    @Klaleu sorry, I forgot to tell you to stop MagicMirror under pm2
                                    but as the postinstall ran
                                    do
                                    pm2 restart all
                                    • K Offline
                                      Klaleu
                                      Dear Sam,
                                      Thank you very much for your help.
                                      After I did the following:
                                      pm2 stop mm
                                      and
                                      pm2 restart all
                                      The new installation of MMM-Navigate ran without errors or problems.
                                      And after I added the code in the Modules array in the config/config.js, MMM-Navigate worked.
                                      Thank you again for your help and for the time you sacrificed.
                                      Klaus
                                        sdetweil @Klaleu
                                        @Klaleu fantastic!
                                        thanks for the feedback
                                        • K Offline
                                          Klaleu
                                          Dear Sam,
                                          That was my first contact in the MagicMirror Forum and thanks to your help it was a complete success.
                                          My problem is now solved. Who moves the point from unresolved to resolved?
                                          Greetings
                                          Klaus
                                            sdetweil @Klaleu
                                            @Klaleu you do. find the message which gives the best answer, click the 3 dots in the lower right and select the option
                                            Mark this post …
                                            • K Klaleu has marked this topic as solved on
