    MMM-Navigate cannot be installed
    26 Posts 2 Posters 5.5k Views 2 Watching
      sdetweil @Klaleu
      @Klaleu said in MMM-Navigate cannot be installed:
      and sent the results to you.
      where? I am not the module author. I don’t see a text message here from you
      and I didn’t give you my email
      edit: sorry, I found it, burried in other messages,
      very weird… SO, try this
      npm uninstall @electron/rebuild
      then , to see if this is fixed by having the postinstall script reinstall it…
      cd modules/MMM-Navigate
      ./postinstall
      this approach was copied from me, so I am confused why it is failing
      • K
        Klaleu
        Dear Sam,
        I ran the following commands:
        This was the result:
        klaus@raspberrypi:~ $ cd ~/MagicMirror
        klaus@raspberrypi:~/MagicMirror $ npm uninstall @electron/rebuild
        up to date in 19s
        216 packages are looking for funding
        run npm fund for details
        klaus@raspberrypi:~/MagicMirror $ npm fund
        magicmirror@2.27.0
        ├── https://patreon.com/biodiscus
        │ └── ansis@2.3.0
        ├─┬ https://opencollective.com/eslint
        │ │ └── eslint@8.57.0, @eslint/eslintrc@2.1.4, eslint-scope@7.2.2, eslint-visito r-keys@3.4.3, espree@9.6.1
        │ ├── https://github.com/sponsors/nzakas
        │ │ └── @humanwhocodes/module-importer@1.0.1
        │ ├── https://github.com/sponsors/epoberezkin
        │ │ └── ajv@6.12.6, ajv@8.12.0
        │ └── https://github.com/sponsors/feross
        │ └── run-parallel@1.2.0, queue-microtask@1.2.3, buffer@5.7.1, base64-js@1.5 .1, ieee754@1.2.1, safe-buffer@5.2.1, run-series@1.1.9
        ├── https://www.buymeacoffee.com/systeminfo
        │ └── systeminformation@5.22.7
        ├─┬ https://github.com/sindresorhus/eslint-plugin-unicorn?sponsor=1
        │ │ └── eslint-plugin-unicorn@51.0.1
        │ ├── https://github.com/sponsors/sibiraj-s
        │ │ └── ci-info@4.0.0, ci-info@3.9.0
        │ └─┬ https://opencollective.com/core-js
        │ │ └── core-js-compat@3.37.0
        │ └── https://opencollective.com/browserslist
        │ └── browserslist@4.23.0, caniuse-lite@1.0.30001612, update-browserslist- db@1.0.13
        ├── https://github.com/sponsors/typicode
        │ └── husky@9.0.11
        ├─┬ https://opencollective.com/lint-staged
        │ │ └── lint-staged@15.2.2
        │ ├── https://github.com/chalk/chalk?sponsor=1
        │ │ └── chalk@5.3.0, chalk@4.1.2
        │ ├─┬ https://github.com/sindresorhus/execa?sponsor=1
        │ │ │ └── execa@8.0.1, execa@5.1.1
        │ │ └── https://github.com/sponsors/isaacs
        │ │ └── signal-exit@4.1.0, glob@8.1.0, rimraf@3.0.2
        │ └── https://github.com/chalk/wrap-ansi?sponsor=1
        │ └── wrap-ansi@9.0.0, wrap-ansi@7.0.0
        ├── https://github.com/prettier/prettier?sponsor=1
        │ └── prettier@3.2.5
        ├── https://opencollective.com/sinon
        │ └── sinon@17.0.1
        ├─┬ https://opencollective.com/stylelint
        │ │ └── stylelint@16.4.0
        │ ├── https://github.com/sponsors/csstools
        │ │ └── @csstools/css-parser-algorithms@2.6.1, @csstools/css-tokenizer@2.2.4, @csstools/media-query-list-parser@2.1.9, @csstools/selector-specificity@3.0.3
        │ ├── https://github.com/sponsors/wooorm
        │ │ └── @dual-bundle/import-meta-resolve@4.0.0, mathml-tag-names@2.1.3
        │ ├── https://github.com/sponsors/d-fischer
        │ │ └── cosmiconfig@9.0.0
        │ └─┬ https://opencollective.com/postcss/
        │ │ └── postcss@8.4.38, postcss-safe-parser@7.0.0
        │ └── https://github.com/sponsors/ai
        │ └── nanoid@3.3.7
        ├── https://github.com/sponsors/malept
        │ └── @malept/cross-spawn-promise@2.0.0
        ├─┬ https://github.com/sindresorhus/got?sponsor=1
        │ │ └── got@11.8.6
        │ └── https://github.com/sindresorhus/is?sponsor=1
        │ └── @sindresorhus/is@4.6.0
        ├── https://github.com/sponsors/ljharb
        │ └── string.prototype.matchall@4.0.11, call-bind@1.0.7, function-bind@1.1.2, define-data-property@1.1.4, has-property-descriptors@1.0.2, define-properties@1. 2.1, es-abstract@1.23.3, array-buffer-byte-length@1.0.1, arraybuffer.prototype.s lice@1.0.3, available-typed-arrays@1.0.7, data-view-buffer@1.0.1, data-view-byte -length@1.0.1, data-view-byte-offset@1.0.0, es-to-primitive@1.2.1, is-date-objec t@1.0.5, is-symbol@1.0.4, function.prototype.name@1.1.6, functions-have-names@1. 2.3, get-symbol-description@1.0.2, globalthis@1.0.3, has-proto@1.0.3, is-array-b uffer@3.0.4, is-callable@1.2.7, is-data-view@1.0.1, is-negative-zero@2.0.3, is-r egex@1.1.4, is-shared-array-buffer@1.0.3, is-string@1.0.7, is-typed-array@1.1.13 , is-weakref@1.0.2, object-inspect@1.13.1, object.assign@4.1.5, safe-array-conca t@1.1.2, safe-regex-test@1.0.3, string.prototype.trim@1.2.9, string.prototype.tr imend@1.0.8, string.prototype.trimstart@1.0.8, typed-array-byte-length@1.0.1, ty ped-array-byte-offset@1.0.2, typed-array-length@1.0.6, unbox-primitive@1.0.2, ha s-bigints@1.0.2, which-boxed-primitive@1.0.2, is-bigint@1.0.4, is-boolean-object @1.1.2, is-number-object@1.0.7, which-typed-array@1.1.15, has-tostringtag@1.0.2, get-intrinsic@1.2.4, gopd@1.0.1, has-symbols@1.0.3, regexp.prototype.flags@1.5. 2, side-channel@1.0.6, minimist@1.2.8, qs@6.11.0, resolve@1.22.8, is-core-module @2.13.1, supports-preserve-symlinks-flag@1.0.0, array-includes@3.1.8, array.prot otype.findlastindex@1.2.5, array.prototype.flat@1.3.2, array.prototype.flatmap@1 .3.2, object.fromentries@2.0.8, object.values@1.2.0
        ├─┬ https://ko-fi.com/killymxi
        │ │ └── @selderee/plugin-htmlparser2@0.11.0, selderee@0.11.0, parseley@0.12.1, l eac@0.6.0, peberminta@0.9.0
        │ └─┬ https://github.com/fb55/domhandler?sponsor=1
        │ │ └── domhandler@5.0.3
        │ └── https://github.com/sponsors/fb55
        │ └── domelementtype@2.3.0
        ├─┬ https://github.com/cheeriojs/dom-serializer?sponsor=1
        │ │ └── dom-serializer@2.0.0
        │ └── https://github.com/fb55/entities?sponsor=1
        │ └── entities@4.5.0
        ├─┬ https://github.com/fb55/htmlparser2?sponsor=1
        │ │ └── htmlparser2@8.0.2
        │ └── https://github.com/fb55/domutils?sponsor=1
        │ └── domutils@3.1.0
        ├── https://github.com/sponsors/broofa
        │ └── uuid@9.0.1
        ├── https://github.com/sponsors/RubenVerborgh
        │ └── follow-redirects@1.15.6
        ├─┬ https://paulmillr.com/funding/
        │ │ └── chokidar@3.6.0
        │ └── https://github.com/sponsors/jonschlinkert
        │ └── picomatch@2.3.1, picomatch@4.0.2
        ├── https://opencollective.com/typescript-eslint
        │ └── @typescript-eslint/utils@5.62.0, @typescript-eslint/scope-manager@5.62.0 , @typescript-eslint/visitor-keys@5.62.0, @typescript-eslint/types@5.62.0, @type script-eslint/typescript-estree@5.62.0
        ├── https://github.com/sponsors/ota-meshi
        │ └── jsonc-eslint-parser@2.4.0
        ├── https://github.com/fisker/git-hooks-list?sponsor=1
        │ └── git-hooks-list@1.0.3
        ├── https://opencollective.com/babel
        │ └── @babel/core@7.24.4
        ├── https://github.com/chalk/supports-color?sponsor=1
        │ └── supports-color@8.1.1
        ├── https://github.com/sponsors/dubzzz
        │ └── pure-rand@6.1.0
        ├── https://github.com/sindresorhus/emittery?sponsor=1
        │ └── emittery@0.13.1
        └── https://github.com/inikulin/parse5?sponsor=1
        └── parse5@7.1.2
        After that I executed these commands:
        ./postinstall
        klaus@raspberrypi:~/MagicMirror $ cd modules/MMM-Navigate
        klaus@raspberrypi:~/MagicMirror/modules/MMM-Navigate $ ./postinstall
        ./postinstall: line 8: …/…/node_modules/.bin/electron-rebuild: Permission denied
        and and postinstall is not carried out.
        I hope you can interpret the results.
        Klaus
          sdetweil @Klaleu
          @Klaleu no idea.
          never run npm audit or npm fund
          • K
            Klaleu
            Ok.
            What would you do now if you were me? I only see one option: reinstalling the basic configuration of the Magic Mirror and then installing MMM-Navigate as the first module. Maybe a module I’ve already installed is causing access to be denied. What do you think?
            First of all, thank you very much for taking the time to help me.
            Klaus
              sdetweil @Klaleu
              @Klaleu let’s try this
              rm -rf node_modules
              npm run install-mm
              then
              ./postinstall
              then
              cd  ~/MagicMirror
              npm start
              • K
                Klaleu
                Hello Sam,
                Thank you for continuing to try to solve the problem.
                I have carried out:
                rm -rf node_modules
                npm run install-mm
                and after that:
                ./postinstall
                without problems.
                Last I did:
                npm start
                This is the result:
                klaus@raspberrypi:~/MagicMirror $ npm start
                magicmirror@2.27.0 start
                [2024-06-17 11:35:52.232] [LOG] Starting MagicMirror: v2.27.0
                [2024-06-17 11:35:52.333] [LOG] Loading config …
                [2024-06-17 11:35:52.344] [LOG] config template file not exists, no envsubst
                [2024-06-17 11:35:52.354] [LOG] Loading module helpers …
                [2024-06-17 11:35:52.360] [LOG] No helper found for module: alert.
                [2024-06-17 11:35:53.076] [LOG] Initializing new module helper …
                [2024-06-17 11:35:53.078] [LOG] Module helper loaded: updatenotification
                [2024-06-17 11:35:53.080] [LOG] No helper found for module: MMM-pages.
                [2024-06-17 11:35:53.081] [LOG] No helper found for module: clock.
                [2024-06-17 11:35:53.466] [LOG] Initializing new module helper …
                [2024-06-17 11:35:53.472] [LOG] Module helper loaded: calendar
                [2024-06-17 11:35:54.236] [LOG] Initializing new module helper …
                [2024-06-17 11:35:54.241] [LOG] Module helper loaded: MMM-DWD-Pollen
                [2024-06-17 11:35:54.242] [LOG] No helper found for module: compliments.
                [2024-06-17 11:35:54.243] [LOG] No helper found for module: weather.
                [2024-06-17 11:35:54.275] [LOG] Initializing new module helper …
                [2024-06-17 11:35:54.275] [LOG] Module helper loaded: MMM-birthdays
                [2024-06-17 11:35:54.720] [LOG] Initializing new module helper …
                [2024-06-17 11:35:54.723] [LOG] Module helper loaded: MMM-Rest
                [2024-06-17 11:35:54.725] [LOG] No helper found for module: MMM-Globe.
                [2024-06-17 11:35:54.725] [LOG] No helper found for module: MMM-RAIN-MAP.
                [2024-06-17 11:35:54.893] [LOG] Initializing new module helper …
                [2024-06-17 11:35:54.893] [LOG] Module helper loaded: newsfeed
                [2024-06-17 11:35:54.893] [LOG] All module helpers loaded.
                [2024-06-17 11:35:54.909] [LOG] Starting server on port 8080 …
                [2024-06-17 11:35:57.767] [ERROR] Whoops! There was an uncaught exception…
                [2024-06-17 11:35:57.823] [ERROR] Error: listen EADDRINUSE: address already in use ::1:8080
                at Server.setupListenHandle [as _listen2] (node:net:1872:16)
                at listenInCluster (node:net:1920:12)
                at GetAddrInfoReqWrap.doListen [as callback] (node:net:2069:7)
                at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:109:8) {
                code: ‘EADDRINUSE’,
                errno: -98,
                syscall: ‘listen’,
                address: ‘::1’,
                port: 8080
                [2024-06-17 11:35:57.850] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                [2024-06-17 11:35:57.862] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                [2024-06-17 11:36:07.657] [INFO] System information:
                SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.2; raspberry: [object Object]; virtual: false
                OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v8+
                VERSIONS: electron: 29.3.1; used node: 20.9.0; installed node: 20.8.0; npm: 10.1.0; pm2: 5.3.1
                OTHER: timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                The internet connection was stabile, it can’t be the reason for the problem.
                I hope you can interpret the result and have a suggestion on how to proceed.
                Greetings
                Klaus
                  sdetweil @Klaleu
                  @Klaleu sorry, I forgot to tell you to stop MagicMirror under pm2
                  but as the postinstall ran
                  do
                  pm2 restart all
                  • K
                    Klaleu
                    Dear Sam,
                    Thank you very much for your help.
                    After I did the following:
                    pm2 stop mm
                    and
                    pm2 restart all
                    The new installation of MMM-Navigate ran without errors or problems.
                    And after I added the code in the Modules array in the config/config.js, MMM-Navigate worked.
                    Thank you again for your help and for the time you sacrificed.
                    Klaus
                      sdetweil @Klaleu
                      @Klaleu fantastic!
                      thanks for the feedback
                      • K
                        Klaleu
                        Dear Sam,
                        That was my first contact in the MagicMirror Forum and thanks to your help it was a complete success.
                        My problem is now solved. Who moves the point from unresolved to resolved?
                        Greetings
                        Klaus
                          sdetweil @Klaleu
                          @Klaleu you do. find the message which gives the best answer, click the 3 dots in the lower right and select the option
                          Mark this post …
                          • K Klaleu has marked this topic as solved on
