    MMM-2Day-NOAA-Forecast stopped working, stuck on "loading"
    7 Posts 4 Posters 1.9k Views 4 Watching
    • L
      leonids
      MMM-2Day-NOAA-Forecast worked for a very long time, but now quit.
      Displays “Loading” forever. Restart, reboot, reinstall does not help. Looked at logs and see this:
      [20.03.2024 08:54.18.076] [ERROR] Failed to retrieve repo info for MMM-2Day-NOAA-Forecast: Error: Command failed: cd /home/leonid/MagicMirror/modules/MMM-2Day-NOAA-Forecast &&
      git fetch -n --dry-run
      fatal: unable to access ‘https://github.com/jinserk/MMM-2Day-NOAA-Forecast/’: Could not resolve host: github.com
      Other modules work fine, only MMM-2Day-NOAA-Forecast fails
      Please help to fix it !
      Thank you
      S karsten13K 2 Replies Last reply
        sdetweil @leonids
        @leonids those messages are from the updatenotification module.
        nothing to do with weather
        • L
          leonids
          any other logs/messages I should look for?
            sdetweil @leonids
            @leonids according to the code, it puts out messages in the same place if it encounters an error
            • karsten13K
              karsten13 @leonids
              @leonids said in MMM-2Day-NOAA-Forecast stopped working, stuck on "loading":
              looks like you have network problems
              BKeyportB 1 Reply Last reply
              • BKeyportB
                BKeyport Module Developer @karsten13
                @karsten13
                That would be my guess too - DNS issues at the bare minimum (It’s always DNS)
                • L
                  leonids
                  I gave up on MMM-2Day-NOAA-Forecast and switched to another module - MMM-3Day-Forecast.
                  Seems to work fine for now
