Problem with MMM-PhoneDetect
6 Posts 3 Posters 318 Views 3 Watching
    Manino
    I did the install of the MMM-PhoneDetect but can’t get it to work. Does anyone know what do to? There seem to be no conection between my phone and the module. It’s a grey dot on the screen that is supposed to be green. When I did the log check I get this:
    m@raspberrypi:~ $ pm2 logs
    /home/m/.pm2/pm2.log last 15 lines:
    PM2        | 2024-06-16T14:23:34: PM2 log: App [MagicMirror:0] starting in -fork mode-
    PM2        | 2024-06-16T14:23:34: PM2 log: App [MagicMirror:0] online
    PM2        | 2024-06-16T14:39:28: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
    PM2        | 2024-06-16T14:39:28: PM2 log: Stopping app:MagicMirror id:0
    PM2        | 2024-06-16T14:39:29: PM2 error: Error: kill EPERM
    PM2        | 2024-06-16T14:39:29: PM2 log: pid=859 msg=failed to kill - retrying in 100ms
    PM2        | 2024-06-16T14:39:29: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
    PM2        | 2024-06-16T14:39:30: PM2 log: pid=859 msg=process killed
    PM2        | 2024-06-16T14:39:30: PM2 log: App [MagicMirror:0] starting in -fork mode-
    PM2        | 2024-06-16T14:39:30: PM2 log: App [MagicMirror:0] online
    /home/m/.pm2/logs/MagicMirror-error.log last 15 lines:
    0|MagicMir | [1193:0616/142444.467634:ERROR:atom_cache.cc(229)] Add WM_CHANGE_STATE to kAtomsToCache
    0|MagicMir | [2024-06-16 14:39:29.388] [ERROR] MMM-PhoneDetect: Error performing nmap scan: Command failed: sudo nmap -sn 192.168.1.0/24
    0|MagicMir |
    0|MagicMir | [2024-06-16 14:39:29.400] [ERROR] (node:1193) UnhandledPromiseRejectionWarning: Error: Command failed: sudo nmap -sn 192.168.1.0/24
    0|MagicMir |
    0|MagicMir |     at ChildProcess.exithandler (node:child_process:422:12)
    0|MagicMir |     at ChildProcess.emit (node:events:514:28)
    0|MagicMir |     at maybeClose (node:internal/child_process:1105:16)
    0|MagicMir |     at Socket.<anonymous> (node:internal/child_process:457:11)
    0|MagicMir |     at Socket.emit (node:events:514:28)
    0|MagicMir |     at Pipe.<anonymous> (node:net:337:12)
    0|MagicMir | (Use `electron --trace-warnings ...` to show where the warning was created)
    0|MagicMir | [2024-06-16 14:39:29.401] [ERROR] (node:1193) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
    0|MagicMir | /home/manino/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
    0|MagicMir | [3682:0616/144334.609151:ERROR:atom_cache.cc(229)] Add WM_CHANGE_STATE to kAtomsToCache
    /home/m/.pm2/logs/MagicMirror-out.log last 15 lines:
    0|MagicMir | [2024-06-16 15:09:17.175] [LOG]   MMM-PhoneDetect: Mirror turned off.
    0|MagicMir | [2024-06-16 15:09:17.915] [LOG]   MMM-PhoneDetect: Turning off the mirror...
    0|MagicMir | [2024-06-16 15:09:17.942] [LOG]   MMM-PhoneDetect: Mirror turned off.
    0|MagicMir | [2024-06-16 15:09:22.384] [LOG]   MMM-PhoneDetect: Turning off the mirror...
    0|MagicMir | [2024-06-16 15:09:22.439] [LOG]   MMM-PhoneDetect: Mirror turned off.
    0|MagicMir | [2024-06-16 15:09:23.045] [LOG]   MMM-PhoneDetect: Turning off the mirror...
    S 1 Reply Last reply Jun 30, 2024, 11:06 AM Reply Quote 0
      sdetweil @Manino
      @Manino did you install the nmap program?
      P 1 Reply Last reply Jul 7, 2024, 3:56 PM Reply Quote 0
        plainbroke @sdetweil
        Can I hide this module ?
        It would be great to use and I think instead of the shut down monitor, I can us pm2 stop all and pm2 start mm to shut off display, like I do in my crontab. I leave the monitor on all the time as a night light basically very little light come of it cause I use a black background and the toolbar is set to small with a black background. What do you think can this be made to work…?
        S 1 Reply Last reply Jul 7, 2024, 4:05 PM Reply Quote 0
          sdetweil @plainbroke
          @plainbroke hide what module?
          P 1 Reply Last reply Jul 8, 2024, 10:23 PM Reply Quote 0
            MMM-PhoneDetect, I just want to use it to turn the screen off and on if one of is home. My dogs ignore MM anyways.
            S 1 Reply Last reply Jul 8, 2024, 10:54 PM Reply Quote 0
              @plainbroke maybe, add
              hiddenOnStartup:true,
              after module:
