MMM-OpenWeatherMapForecast 3.0 API calls and freeze issue
21 Posts 5 Posters 1.7k Views 5 Watching
    jfields
    I have been using MMM-OpenWeatherMapForecast for a few months without issue. I have showDailyForecast in one section with maxHourliesToShow set to 24. I also have 4 different daily update sections, including the same location as the showDailyForecast updates. So 5 calls/sections total. The daily updates pull every 12 hours and the hourly pulls every hour.
    I upgraded my MMM-OpenWeatherMapForecast configs to 3.0 onecall a couple weeks ago. I also recently updated that module, the magicmirror base, and the Raspberry Pi software around the same time. I’m having a hard time pinning down the root cause. I’ve since renamed my MagicMirror folder and redownloaded in case I made a mistake somewhere else.
    I recently found that my hourly weather was not updating. Looking at it further, it appears to have gone stale around July 2nd, I found this on the 5th or 6th. When I logged into my Raspberry Pi 4, I took the regular OS updates that were waiting, rebooted, and restarted the Magic Mirror software and configured modules. I assumed something was hung and needed a reboot I then noticed an unusually high number of calls going to onecall_30. My normal amount is 60-70 calls per day but I was close to 1,000 by late afternoon.
    A lot of troubleshooting later I’ve found that having the hourly and daily calls running at the same time causes the system to slowly freeze up. Having more than one call/section enabled causes an unusually high number of calls to go out. Having just the showDailyForecast section enabled runs fine and registers one call in the openweathermap usage logs per attempt. Having this hourly plus one of the daily calls running results in 8 calls per attempt. Having three sections enabled results in 27 calls, 4 sections enabled results in 64 calls, and having all five sections running results in 100-152 calls. These counts are recorded at startup; I don’t have the data on refresh rates.
    When I have more than one instance of the weather call in my config, I get an unusual number of calls being recorded at https://home.openweathermap.org/statistics/onecall_30. If I have the hourly instance and any daily instance enabled at the same time, it seems like each new API call bogs the system down more. It’s evident in the clock. I start seeing time update every 2 seconds, then every 3-4, then more. Eventually my calendar wouldn’t display, flashing briefly for a moment before going away again - maybe it was trying to refresh and not getting through? Having more daily instances enabled along with the hourly causes it degrade faster. Eventually it just stops updating and appears frozen. When it gets to this point, the openweathermap statistics stops bumping like the calls are never going out.
    config.js
    			module: "alert",
    			module: "updatenotification",
    			position: "top_bar"
    			module: "clock",
    			timeFormat: 12
    			header: "Calendar",
    				fetchInterval: 3600000 * 12, // 12 hours
    				customEvents: [{keyword: 'Birthday', symbol: 'birthday-cake', color: 'Gold'}, {keyword: 'Anniversary', symbol: 'fas fa-solid fa-face-kiss-wink-heart', color: 'Red'}],
    				coloredText: true,
    				coloredSymbol: true,
    						symbol: "calendar-check",
    						url: "https://calendar.google.com/calendar/ical/myhashnumber%40group.calendar.google.com/private-mycalendarnumber/basic.ics"
    						url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
    			module: "MMM-OpenWeatherMapForecast",
    			header: "Kent, WA",
    				apikey: "myapikey",
    				latitude: "47.394788",
    				longitude: "-122.214061",
    				updateInterval: 15,  // 720 = 12 hrs
    				requestDelay: 500,  // ms
    				units: "imperial",
    				showCurrentConditions: false,
    				showSummary: false,
    				showForecastTableColumnHeaderIcons: false,
    				showHourlyForecast: false,
    				maxDailiesToShow: 5,
    				concise: false,
    				iconset: "4c",
    				forecastLayout: "table"
    			header: "Dade City, FL",
    				apikey: "myapikey",
    				latitude: "28.32506",
    				longitude: "-82.30354",
    				updateInterval: 30,  // 12 hrs
    				requestDelay: 4500,  // ms
    				colored: false,
    				units: "imperial",
    				showSummary: false,
    			header: "Lawndale, CA",
    				apikey: "myapikey",
    				latitude: "33.90011",
    				longitude: "-118.35854",
    				updateInterval: 60,  // 720 = 12 hrs
    				requestDelay: 3500,  // ms
    				colored: false,
    				units: "imperial",
    				showSummary: false,
    			header: "Toulouse",
    				apikey: "myapikey",
    				latitude: "43.6033738",
    				longitude: "1.4307561",
    				updateInterval: 60,  // 12 hrs
    				requestDelay: 1500,  // ms
    				colored: false,
    				units: "imperial",
    				showSummary: false,
    			disabled: false,
    			module: "MMM-SunRiseSet",
    				lat: "47.394788",
    				lng: "-122.214061",
    				imageOnly: "no",
    				timeFormat: "h:mm a",
    				maxWidth: "515px"
    			header: "Today's Hourly Weather",
    				apikey: "myapikey",
    				updateInterval: 15,  // minutes
    				requestDelay: 2500,  // ms
    				units: "imperial",
    				hourlyForecastInterval: 1,
    				maxHourliesToShow: 24,
    				showDailyForecast: true,
    				concise: false,
    				iconset: "4c",
    Raspberry Pi 4 top results while system appears locked up. I am ssh’ing from another computer’s terminal.
    karsten13K S 2 Replies Last reply Jul 9, 2024, 9:58 PM Reply Quote 0
      sdetweil @jfields
      @jfields good debug on the multiple problem
      lets try this temp fix
      in the MM/js folder do
      curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror/fixloading/js/app.js >app.js
      stop and restart MM
      this adds a hash to check for loading or already loading the node_helper for this module
      S J 2 Replies Last reply Jul 23, 2024, 9:37 PM Reply Quote 0
      • karsten13K Offline
        karsten13 @jfields
        @jfields
        without knowing if it is related to this we have another odd behaviour here which sounds similiar
          sdetweil @jfields
          @jfields I don’t know the cause of the unexpected multiples, but the ‘freeze’ is because you hit the 1000 calls per day
          limit of the free plan.
          can we see your config.js?
          xxx out any api key or url etc that is
          private but don’t change anything else, use the code block wrapper
          weather is done all in browser , so any messages are logged there
          ctrl-shift-i to open the developers window and then select the console tab.
          add weather to the files field to see messages just from the weather module
          you can change filter to cal for Calendar
          as well.
          Calendar fetching is done server side, so the output of
           pm2 logs --lines=100
          might be helpful
          as well as the output of
          pm2 status
          J 1 Reply Last reply Jul 12, 2024, 7:02 AM Reply Quote 1
            jfields @sdetweil
            @sdetweil Thanks for the response. The freezing is not from exceeding the 1,000 API calls. The system is bogging down. I can watch it get worse over time by watching how often the seconds update on the clock. Also, I have a credit card on file and allow up to 2,000 call. I haven’t exceeded that but I have gone up to 1,700.
            I have reverted to using MMM-OpenWeatherMapForecast for just one call and that is working fine. I’m using the standard weather module for the rest of the calls.
            API calls
            pm2 status
            For the config.js, I copied the module section and pasted it above. Do you need more than that?
            I wasn’t sure what to grab from the console tab, but I did see some errors and grabbed those.
            Video of some error messages popping up. They were really flashing fast at first, hard to get a screen grab so I made a video. The longer it went, the more errors, and the longer you could see them. Something is compounding.
            https://imgur.com/a/QXU5SzI
            The longer it goes, the more errors I see.
            One of the POST error messages
            S 2 Replies Last reply Jul 12, 2024, 8:40 AM Reply Quote 0
              sdetweil @jfields
              @jfields which version of MMM-OpenWeatherMapForecast are you using?
              in the module folder do
              git remote -v
              J 1 Reply Last reply Jul 12, 2024, 3:03 PM Reply Quote 0
                jfields @sdetweil
                origin https://github.com/MarcLandis/MMM-OpenWeatherMapForecast.git (fetch)
                origin https://github.com/MarcLandis/MMM-OpenWeatherMapForecast.git (push)
                S 1 Reply Last reply Jul 12, 2024, 3:21 PM Reply Quote 0
                  sdetweil @jfields
                  @jfields that one is quite old
                  I’d try this one, as the author is active
                  https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast
                  J 1 Reply Last reply Jul 13, 2024, 2:54 PM Reply Quote 0
                    jfields @sdetweil
                    @sdetweil Thanks. I haven’t tried that one. I honestly only thought there were two, one that was way old and the one I’m using (MarcLandis). The one I’m using did get a recent update so it is somewhat supported, although I cannot open an Issue on it.
                    From where I’m at now, I have a good working solution but using the MarcLandis version on one side and the built-in for everything else. If I do change, I will look at the Tom-Hirschberger version. It’s getting updates and has a tab to open Issues.
                      sdetweil @jfields
                      stop and restart MM
                        Socrates @sdetweil
                        Sorry to hijack this post. I can create a new one if needed. I’ve been using the “MMM-OpenWeatherMapForecast” module for a while, but for the past few weeks, it hasn’t been showing up on my MM. I’ve rebooted MM several times and made sure the module is up to date, but no luck.
                        S 1 Reply Last reply Jul 23, 2024, 9:42 PM Reply Quote 0
