    MagicMirror on second Monitor
    9 Posts 4 Posters 1.2k Views 4 Watching
      sdetweil @Babene1
      @Babene1 you should have two X11 DISPLAY objects…
      the default is :0 (which we set in the mm.sh script and in the package.json START clause, if it is not set
      "scripts": {
      so you shouldn’t need the electronOptions settings, just set the display variable
      export DISPLAY=??
      xrandr --query
      should give you the list of displays
      note this is the X11 term, the Wayland value is different
      when I do xrandr on my pi5 with wayland (only ‘one’ screen) I see
      xrandr --query
      Screen 0: minimum 16 x 16, current 3840 x 2160, maximum 32767 x 32767
      XWAYLAND14 connected 3840x2160+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
         3840x2160     29.98*+
         2048x1536     29.95
         1920x1440     29.95
         1600x1200     29.95
         1440x1080     29.86
         1400x1050     29.98
         1280x1024     29.90
         1280x960      29.82
         1152x864      29.92
         1024x768      29.89
         800x600       29.55
         640x480       29.85
         320x240       27.50
         2560x1600     29.99
         1920x1200     29.95
         1680x1050     29.95
         1440x900      29.91
         1280x800      29.83
         720x480       29.25
         640x400       29.58
         320x200       26.53
         3200x1800     29.96
         2880x1620     29.96
         2560x1440     29.94
         2048x1152     29.94
         1920x1080     29.95
         1600x900      29.92
         1368x768      29.94
         1280x720      29.93
         1024x576      29.84
         864x486       29.50
         720x400       29.51
         640x350       29.03
        @Babene1 I have run two monitors one landscape, one portait with MM on each
        using the electronOptions:{} settings.
        the cursor moves over both seamlessly.
        that is one big display space.
        the xrandr command will tell you …
        do you have two complete independant desktops?
        • BKeyportB Offline
          @sdetweil With the displays showing “HDMI-A-1” etc, it’s in Wayland, xrandr doesn’t function under that. This is part of why I suggested going back to X11.
          S Z 2 Replies Last reply Reply Quote 0
            sdetweil @BKeyport
            @BKeyport xrandr --query worked while running wayland, output above
            wlr-randr does not do --query
            • BKeyportB Offline
              @sdetweil Ahh, ok, I thought it was completely dead. Good to know.
                Babene1 Project Sponsor
                You are absolutely brilliant, now it works.
                I change in “raspi-config” to x11 desktop environment and now magicmirror run on second monitor.
                Thank you all for your tips
                • B Babene1 has marked this topic as solved on
                • Z Offline
                  zane-zan @BKeyport
                  @BKeyport I believe you are right. I had the same issue. I tried to run the xrandr query and I could not print the displays. I looked everywhere, the only solution I found was to switch back to X11. This was the only way to get the electron option to treat the screen as a single screen and move the display to the second monitor.
                  Anyway, thanks a lot, reading this post solved my problem and I was trying to figure it out for a while !
