    MagicMirror Failing on Raspberry Pi Zero W Rev 1.1
    43 Posts 3 Posters 10.0k Views 3 Watching
      sdetweil @davidgagne
      @davidgagne Electron is not available for the pi0w, armv6l
      hasn’t been for years
      my install script configures server mode and launches a local browser over that , connected to the port from the MM config
      to do this. my install script changes package.json start clause to launch a runtime script I provide (run-start.sh)
      I cannot think of a way that package.json was reverted without some manual intervention
      check package,json for
      "start":"./run-start.sh",
      D 5 Replies Last reply Reply Quote 0
        davidgagne @sdetweil
        @sdetweil I’m not trying to be argumentative, but something has changed in the last two months that has caused the existing install scripts to stop working and/or caused MM to want electron.
        I’m using this:
        https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh
        And then this:
        https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh
        Exactly the way everything worked at the end of May. One of those scripts had to have changed, or the July 1 MM update has a bug. I cannot think of any other reason this isn’t working.
        (See also: https://www.davidgagne.net/2024/05/30/how-to-get-magicmirror-to-run-on-a-raspberry-pi-zero-w-rev-1-1/)
          @sdetweil Here are the contents of the package.json and run-start.sh files. Note that I have not edited anything. This is exactly how they came from the installation process.
          	"name": "magicmirror",
          	"version": "2.27.0",
          	"description": "The open source modular smart mirror platform.",
          	"main": "js/electron.js",
          	"scripts": {
              "start":"./run-start.sh $1",
          		"server": "node ./serveronly",
          		"install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev",
          		"install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier",
          		"install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
          		"install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
          		"postinstall": "npm run install-vendor && npm run install-fonts && echo \"MagicMirror² installation finished successfully! \n\"",
          		"test": "NODE_ENV=test jest -i --forceExit",
          		"test:coverage": "NODE_ENV=test jest --coverage -i --verbose false --forceExit",
          		"test:electron": "NODE_ENV=test jest --selectProjects electron -i --forceExit",
          		"test:e2e": "NODE_ENV=test jest --selectProjects e2e -i --forceExit",
          		"test:unit": "NODE_ENV=test jest --selectProjects unit",
          		"test:prettier": "prettier . --check",
          		"test:js": "eslint .",
          		"test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json",
          		"test:calendar": "node ./modules/default/calendar/debug.js",
          		"config:check": "node js/check_config.js",
          		"lint:prettier": "prettier . --write",
          		"lint:js": "eslint . --fix",
          		"lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json --fix",
          		"lint:staged": "lint-staged",
          		"prepare": "[ -f node_modules/.bin/husky ] && husky || echo no husky installed."
          	"repository": {
          		"type": "git",
          		"url": "https://github.com/MagicMirrorOrg/MagicMirror"
          	"keywords": [
          		"magic mirror",
          		"magicmirror",
          		"smart mirror",
          		"mirror UI",
          		"modular"
          	"author": "Michael Teeuw",
          	"contributors": [
          		"https://github.com/MagicMirrorOrg/MagicMirror/graphs/contributors"
          	"license": "MIT",
          	"bugs": {
          		"url": "https://github.com/MagicMirrorOrg/MagicMirror/issues"
          	"homepage": "https://magicmirror.builders",
          	"devDependencies": {
          		"@stylistic/eslint-plugin": "^1.7.0",
          		"eslint-plugin-import": "^2.29.1",
          		"eslint-plugin-jest": "^27.9.0",
          		"eslint-plugin-jsdoc": "^48.2.2",
          		"eslint-plugin-package-json": "^0.12.1",
          		"eslint-plugin-unicorn": "^51.0.1",
          		"express-basic-auth": "^1.2.1",
          		"husky": "^9.0.11",
          		"jest": "^29.7.0",
          		"jsdom": "^24.0.0",
          		"lint-staged": "^15.2.2",
          		"playwright": "^1.42.1",
          		"prettier": "^3.2.5",
          		"sinon": "^17.0.1",
          		"stylelint": "^16.3.1",
          		"stylelint-config-standard": "^36.0.0",
          		"stylelint-prettier": "^5.0.0"
          	"optionalDependencies": {
          		"electron": "^29.1.6"
          	"dependencies": {
          		"ansis": "^2.3.0",
          		"console-stamp": "^3.1.2",
          		"envsub": "^4.1.0",
          		"eslint": "^8.57.0",
          		"express": "^4.19.2",
          		"express-ipfilter": "^1.3.2",
          		"feedme": "^2.0.2",
          		"helmet": "^7.1.0",
          		"html-to-text": "^9.0.5",
          		"iconv-lite": "^0.6.3",
          		"module-alias": "^2.2.3",
          		"moment": "^2.30.1",
          		"node-ical": "^0.18.0",
          		"pm2": "^5.3.1",
          		"socket.io": "^4.7.5",
          		"suncalc": "^1.9.0",
          		"systeminformation": "^5.22.6"
          	"lint-staged": {
          		"*": "prettier --write",
          		"*.js": "eslint --fix",
          		"*.css": "stylelint --fix"
          	"_moduleAliases": {
          		"node_helper": "js/node_helper.js",
          		"logger": "js/logger.js"
          	"engines": {
          		"node": ">=18"
          And here is run-start.sh:
          #!/bin/bash
          # use bash instead of sh
          # get the folder  for this file
          DIR=$(dirname "$0")
          # make sure we are running in that folder
          cd "$DIR" >/dev/null
          # check for the old untrack css script
          [ -f ./untrack-css.sh ] && ./untrack-css.sh
          # if running under docker
          if grep docker /proc/1/cgroup -qa; then
            #  only start electron
            electron js/electron.js $1;
          else
            # not running in docker
            if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
              export DISPLAY=:0 # Set by default display
            fi
            # get the processor architecture
            arch=$(uname -m)
            false='false'
            true='true'
            # get the config option, if any
            # only check non comment lines
            serveronly=$(grep -v '^[[:blank:]]*//' config/config.js | grep -i serveronly: | tr -d ',"'\''\r' | tr -d ' ' | awk -F/ '{print $1}'  |  awk -F: '{print $2}')
            # set default if not defined in config
            serveronly=${serveronly:-false}
            # check for xwindows running
            while [ 1 -eq 1 ];
            do
              xorg=$(pgrep Xorg)
              if [ "$xorg." == "." ]; then
                 # check for x on Lubuntu
                 xorg=$(pgrep X)
              fi
              # if user set wait_for_x to some value (ANY value)
              if [ "$wait_for_x." != "." ]; then
                if [ "$xorg." != "." ]; then
                  # then break from loop
                  break;
                else
                  # sleep for 1 second
                  sleep 1
                fi
              else
                # exit loop, not waiting, default
                break;
              fi
            done
            #check for macOS
            mac=$(uname)
            el_installed=$true
            if [ ! -d node_modules/electron ]; then
              el_installed=$false
            fi
            # if the user requested serveronly OR
            #    electron support for armv6l has been dropped OR
            #    system is in text mode
            if [ "$serveronly." != "$false." -o  "$arch" == "armv6l" -o "$arch" == "i686" -o $el_installed == $false  ]  ||  [ "$xorg." == "." -a $mac != 'Darwin' -a "$wait_for_x." != "." ]; then
                t=$(ps -ef | grep  "node serveronly" | grep -m1 -v color | awk '{print $2}')
                if [ "$t." != '.' ]; then
                  sudo kill -9 $t >/dev/null 2>&1
                fi
              # if user explicitly configured to run server only (no ui local)
              # OR there is no xwindows running, so no support for browser graphics
              if [ "$serveronly." == "$true." ] || [ "$xorg." == "." -a $mac != 'Darwin' -a "$wait_for_x." != "." ]; then
                # start server mode,
                node serveronly
              else
                # start the server in the background
                # wait for server to be ready
                # need bash for this
                exec 3< <(node serveronly)
                # Read the output of server line by line until one line 'point your browser'
                while read line; do
                   case "$line" in
                   *point\ your\ browser*)
                      echo $line
                      break
                      echo $line
                      #sleep .25
                   esac
                done <&3
                # Close the file descriptor
                #exec 3<&-
                # lets use chrome to display here now
                # get the server port address from the ready message
                port=$(echo $line | awk -F\: '{print $4}')
                # start chromium
                # echo "Starting chromium browser now, have patience, it takes a minute"
                # continue to spool stdout to console
                tee <&3 &
                if [ "$external_browser." == "." ]; then
                  # start chromium
                	if [ $mac != 'Darwin' ]; then
                    	b="chromium"
                      if [ $(which $b). == '.' -o $arch == 'armv6l' ]; then
                        b='chromium-browser'
                      fi
                    	if [ $(which $b). != '.' ]; then
                        rm -rf ~/.config/$b 2>/dev/null
                        r=$(mktemp -d "${TMPDIR:-/tmp}"/tmp.XXXXXXXX)
                        "$b" -noerrdialogs -kiosk -start_maximized --new-window --site-per-process --no-zygote --no-sandbox --disable-infobars --app=http://localhost:$port  --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors --user-data-dir=$r 2>/dev/null
                        rm -rf $r >/dev/null
                      else
                        echo "Chromium_browser not installed"
                        # if we can't start chrome,
                        # get the server process id
                        ns=$(ps -ef | grep  "node serveronly" | grep -m1 -v color | awk '{print $2}')
                        # if we have the process id
                        if [ "$ns". != "." ]; then
                            # kill server for restart
                            sudo kill -9 $ns >/dev/null 2>&1
                        fi
                    	fi
                	else
                	  open -a "Google Chrome" http://localhost:$port --args -noerrdialogs -kiosk -start_maximized  --disable-infobars --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors 2>/dev/null
                	fi
                else
                  # if the external browser was specified
                  if [ "$(which $external_browser)." !=  "." ]; then
                    # launch it
                    case ${external_browser,,} in
                    midori )
                      # start midori
                      echo "Starting $external_browser  browser now, have patience, it takes a minute"
                      "$external_browser" http://localhost:$port -e Fullscreen -e Navigationbar  >/dev/null 2>&1
                    firefox )
                      # start firefox
                      "$external_browser" http://localhost:$port  -kiosk >/dev/null 2>&1
                    surf )
                      # start surf
                      "$external_browser" -F http://localhost:$port >/dev/null 2>&1
                    #else
                      echo "don't know how to launch $external_browser"
                    esac
                  else
                    echo "couldn't locate $external_browser from the command shell,. check the PATH environment variable"
                  fi
                fi
                exit
              fi
            else
              # we can use electron directly
              node_modules/.bin/electron js/electron.js $1;
            fi
          fi
            @sdetweil And just to be thorough, here is my install.log. I don’t know what’s going on with those weird unicode characters in the log. And there are lots of “memory leak detected” that I don’t recall seeing back in May.
            install starting  - Thu Aug  1 11:35:10 EDT 2024
            installing on armv6l processor system
            the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
                           total        used        free      shared  buff/cache   available
            Mem:             429         182          71           7         175         187
            Swap:             99           5          94
            Updating packages ...
            Reading package lists...
            Update failed, retrying installation ...
            Installing helper tools ...
            Building dependency tree...
            Reading state information...
            build-essential is already the newest version (12.9).
            curl is already the newest version (7.74.0-1.3+deb11u12).
            git is already the newest version (1:2.30.2-1+deb11u2).
            unzip is already the newest version (6.0-26+deb11u1).
            wget is already the newest version (1.21-1+deb11u1).
            wget set to manually installed.
            The following package was automatically installed and is no longer required:
              libfuse2
            Use 'sudo apt autoremove' to remove it.
            0 upgraded, 0 newly installed, 0 to remove and 39 not upgraded.
             this should be a raspberry pi 02w
            increasing swap space
            computing size, want /var/swap=878MByte, checking existing: deleting wrong size file (104857600), generating swapfile ... of 878MBytes
            Node.js is not installed.
            Installing Node.js ...
            Node release info = 2024-08-01 11:37:40 - Installing pre-requisites Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Reading package lists... Reading package lists... Building dependency tree... Reading state information... ca-certificates is already the newest version (20210119). curl is already the newest version (7.74.0-1.3+deb11u12). gnupg is already the newest version (2.2.27-2+deb11u2). The following package was automatically installed and is no longer required: libfuse2 Use 'sudo apt autoremove' to remove it. The following NEW packages will be installed: apt-transport-https 0 upgraded, 1 newly installed, 0 to remove and 39 not upgraded. Need to get 160 kB of archives. After this operation, 166 kB of additional disk space will be used. Get:1 http://mirror.umd.edu/raspbian/raspbian bullseye/main armhf apt-transport-https all 2.2.4 [160 kB] Fetched 160 kB in 1s (126 kB/s) Selecting previously unselected package apt-transport-https.
             (Reading database ...
            (Reading database ... 5%
            (Reading database ... 10%
            (Reading database ... 15%
            (Reading database ... 20%
            (Reading database ... 25%
            (Reading database ... 30%
            (Reading database ... 35%
            (Reading database ... 40%
            (Reading database ... 45%
            (Reading database ... 50%
            (Reading database ... 55%
            (Reading database ... 60%
            (Reading database ... 65%
            (Reading database ... 70%
            (Reading database ... 75%
            (Reading database ... 80%
            (Reading database ... 85%
            (Reading database ... 90%
            (Reading database ... 95%
            (Reading database ... 100%
            (Reading database ... 106675 files and directories currently installed.)
             Preparing to unpack .../apt-transport-https_2.2.4_all.deb ...
             Unpacking apt-transport-https (2.2.4) ...
             Setting up apt-transport-https (2.2.4) ...
             Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Get:3 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB] Get:4 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages [8,776 B] Fetched 20.9 kB in 5s (3,822 B/s) Reading package lists... 2024-08-01 11:39:23 - Repository configured successfully. 2024-08-01 11:39:23 - To install Node.js, run: apt-get install nodejs -y 2024-08-01 11:39:23 - You can use N|solid Runtime as a node.js alternative 2024-08-01 11:39:23 - To install N|solid Runtime, run: apt-get install nsolid -y
            node 20.x version installer not available, doing manually
            libstdc++6 is already the newest version (10.2.1-6+rpi1).
              libfuse2
            using release tar file = node_release-v20.9.0.tar.gz
            node version is v20.9.0
            Node.js installation Done! version=v20.9.0
            Minimum npm version: V10.1.0
            Installed npm version: V10.1.0
            No npm upgrade necessary.
            Cloning MagicMirror ...
            Cloning MagicMirror Done!
            Installing dependencies ...
            > magicmirror@2.28.0 postinstall > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully! > " > magicmirror@2.28.0 install-vendor > echo "Installing vendor files ... > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier Installing vendor files ... added 10 packages in 1m > magicmirror@2.28.0 install-fonts > echo "Installing fonts ... > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier Installing fonts ... added 2 packages in 36s MagicMirror² installation finished successfully! > magicmirror@2.28.0 prepare > [ -f node_modules/.bin/husky ] && husky || echo no husky installed. no husky installed. added 433 packages in 19m 101 packages are looking for funding run `npm fund` for details
            Dependencies installation Done!
            package.json update for armv6l or Electron missing, completed ok
            setting up initial config.js
            Check plymouth installation ...
            Splashscreen: Checking themes directory.
            Splashscreen: Create theme directory if not exists.
            Splashscreen: Changed theme to MagicMirror successfully.
            disable screensaver via gsettings was true and uint32 300
            disable screensaver via lightdm.conf
            disable screensaver via lxsession
            install and setup pm2
            pm2 not installed, installing
            pm2 install result (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (Use `node --trace-warnings ...` to show where the warning was created) (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit added 138 packages in 3m
            get the pm2 platform specific startup command
            startup command = sudo env PATH=$PATH:/usr/local/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u dvg --hp /home/dvg
            __/\\\\\\\\\\\\\____/\\\\____________/\\\\____/\\\\\\\\\_____
             _\/\\\/////////\\\_\/\\\\\\________/\\\\\\__/\\\///////\\\___
              _\/\\\_______\/\\\_\/\\\//\\\____/\\\//\\\_\///______\//\\\__
               _\/\\\\\\\\\\\\\/__\/\\\\///\\\/\\\/_\/\\\___________/\\\/___
                _\/\\\/////////____\/\\\__\///\\\/___\/\\\________/\\\//_____
                 _\/\\\_____________\/\\\____\///_____\/\\\_____/\\\//________
                  _\/\\\_____________\/\\\_____________\/\\\___/\\\/___________
                   _\/\\\_____________\/\\\_____________\/\\\__/\\\\\\\\\\\\\\\_
                    _\///______________\///______________\///__\///////////////__
                                      Runtime Edition
                    PM2 is a Production Process Manager for Node.js applications
                                 with a built-in Load Balancer.
                            Start and Daemonize any application:
                            $ pm2 start app.js
                            Load Balance 4 instances of api.js:
                            $ pm2 start api.js -i 4
                            Monitor in production:
                            $ pm2 monitor
                            Make pm2 auto-boot at server restart:
                            $ pm2 startup
                            To go further checkout:
                            http://pm2.io/
            [PM2] Init System found: systemd
            Platform systemd
            Template
            [Unit]
            Description=PM2 process manager
            Documentation=https://pm2.keymetrics.io/
            After=network.target
            [Service]
            Type=forking
            User=dvg
            LimitNOFILE=infinity
            LimitNPROC=infinity
            LimitCORE=infinity
            Environment=PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games:/usr/local/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
            Environment=PM2_HOME=/home/dvg/.pm2
            PIDFile=/home/dvg/.pm2/pm2.pid
            Restart=on-failure
            ExecStart=/usr/local/lib/node_modules/pm2/bin/pm2 resurrect
            ExecReload=/usr/local/lib/node_modules/pm2/bin/pm2 reload all
            ExecStop=/usr/local/lib/node_modules/pm2/bin/pm2 kill
            [Install]
            WantedBy=multi-user.target
            Target path
            /etc/systemd/system/pm2-dvg.service
            Command list
            [ 'systemctl enable pm2-dvg' ]
            [PM2] Writing init configuration in /etc/systemd/system/pm2-dvg.service
            [PM2] Making script booting at startup...
            [PM2] [-] Executing: systemctl enable pm2-dvg...
            Created symlink /etc/systemd/system/multi-user.target.wants/pm2-dvg.service → /etc/systemd/system/pm2-dvg.service.
            [PM2] [v] Command successfully executed.
            [PM2] Freeze a process list on reboot via:
            $ pm2 save
            [PM2] Remove init script via:
            $ pm2 unstartup systemd
            pm2 startup command done
            configure the pm2 config file for MagicMirror
            rename pm2 process in pm2_MagicMirror.json
            the user is not pi
            change pm2_MagicMirror.json
            now using this config file pm2_MagicMirror_new.json
            start MagicMirror via pm2 now
            save MagicMirror pm2 config now
            stop MagicMirror via pm2 now
            We're ready! Run pm2 start pm2 from the ~/MagicMirror directory to start your MagicMirror.
            install completed - Thu Aug  1 12:08:49 EDT 2024
              @sdetweil I scoured the forums and found someone else complaining about electron being missing.
              I ran this sudo npm i -g npm@6 and now it seems to be working fine.
                @davidgagne that makes no sense… the latest version of npm is 10.x
                and you just installed v6… (maybe)
                do
                npm -v
                  @davidgagne said in MagicMirror Failing on Raspberry Pi Zero W Rev 1.1:
                  that is an npm bug… nothing we can do anything about. no impact on install
                  unicode… those are shell escape codes for color (the colors don’t show in the file, only on the actual console)
                    @sdetweil npm -v returns 6.14.18 (and it takes a solid 45 seconds to do that, which seems like a very long time for such a simple command, even on a Zero).
                    S butchkemperB 2 Replies Last reply Reply Quote 0
                      @davidgagne do free -m
                      pi is small on memory, so running off sd card a lot…
                        @sdetweil I was wrong. It’s not working fine.
                        It was working fine. Then I rebooted to make sure everything was fine. Comes back up with no problem.
                        Then I ssh-ed to it, installed a module, ran npm install inside the new module’s directory, execute pm2 start MagicMirror, and now MM crashes again looking for electron.
                        So frustrating.
                        • 1 / 5
