    MagicMirror Failing on Raspberry Pi Zero W Rev 1.1
    43 Posts 3 Posters 10.4k Views 3 Watching
      davidgagne
      Something has gone wrong recently and I’m not sure what happened.
      I had my MM unplugged for a few weeks. When I attempted to use it again, the Pi wouldn’t run MM.
      I investigated and the error log shows that electron is missing. Understand that the device was working perfectly fine, then I simply unplugged the device, it sat in my backpack for a while, and then I plugged it back in.
      I tried reinstalling node and a hundred other things, then just gave up and started from scratch using the same method @sdetweil and I cobbled together a few months ago.
      But now that doesn’t work.
      Help.
      Error: Cannot find module 'electron'
      Require stack:
      - /home/dvg/MagicMirror/js/electron.js
          at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
          at Hook._require.Module.require (/usr/local/lib/node_modules/pm2/node_modules/require-in-the-middle/index.js:81:25)
          at require (node:internal/modules/helpers:130:18)
          at Object.<anonymous> (/home/dvg/MagicMirror/js/electron.js:3:18)
          at Module._compile (node:internal/modules/cjs/loader:1241:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1295:10)
          at Module.load (node:internal/modules/cjs/loader:1091:32)
          at Module._load (node:internal/modules/cjs/loader:938:12)
          at Object.<anonymous> (/usr/local/lib/node_modules/pm2/lib/ProcessContainerFork.js:33:23)
          at Module._compile (node:internal/modules/cjs/loader:1241:14) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [ '/home/dvg/MagicMirror/js/electron.js' ]
        sdetweil @davidgagne
        @davidgagne Electron is not available for the pi0w, armv6l
        hasn’t been for years
        my install script configures server mode and launches a local browser over that , connected to the port from the MM config
        to do this. my install script changes package.json start clause to launch a runtime script I provide (run-start.sh)
        I cannot think of a way that package.json was reverted without some manual intervention
        check package,json for
        "start":"./run-start.sh",
        D 5 Replies Last reply Reply Quote 0
          davidgagne @sdetweil
          @sdetweil I’m not trying to be argumentative, but something has changed in the last two months that has caused the existing install scripts to stop working and/or caused MM to want electron.
          I’m using this:
          https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh
          And then this:
          https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh
          Exactly the way everything worked at the end of May. One of those scripts had to have changed, or the July 1 MM update has a bug. I cannot think of any other reason this isn’t working.
          (See also: https://www.davidgagne.net/2024/05/30/how-to-get-magicmirror-to-run-on-a-raspberry-pi-zero-w-rev-1-1/)
            @sdetweil Here are the contents of the package.json and run-start.sh files. Note that I have not edited anything. This is exactly how they came from the installation process.
            	"name": "magicmirror",
            	"version": "2.27.0",
            	"description": "The open source modular smart mirror platform.",
            	"main": "js/electron.js",
            	"scripts": {
                "start":"./run-start.sh $1",
            		"server": "node ./serveronly",
            		"install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev",
            		"install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier",
            		"install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
            		"install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
            		"postinstall": "npm run install-vendor && npm run install-fonts && echo \"MagicMirror² installation finished successfully! \n\"",
            		"test": "NODE_ENV=test jest -i --forceExit",
            		"test:coverage": "NODE_ENV=test jest --coverage -i --verbose false --forceExit",
            		"test:electron": "NODE_ENV=test jest --selectProjects electron -i --forceExit",
            		"test:e2e": "NODE_ENV=test jest --selectProjects e2e -i --forceExit",
            		"test:unit": "NODE_ENV=test jest --selectProjects unit",
            		"test:prettier": "prettier . --check",
            		"test:js": "eslint .",
            		"test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json",
            		"test:calendar": "node ./modules/default/calendar/debug.js",
            		"config:check": "node js/check_config.js",
            		"lint:prettier": "prettier . --write",
            		"lint:js": "eslint . --fix",
            		"lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json --fix",
            		"lint:staged": "lint-staged",
            		"prepare": "[ -f node_modules/.bin/husky ] && husky || echo no husky installed."
            	"repository": {
            		"type": "git",
            		"url": "https://github.com/MagicMirrorOrg/MagicMirror"
            	"keywords": [
            		"magic mirror",
            		"magicmirror",
            		"smart mirror",
            		"mirror UI",
            		"modular"
            	"author": "Michael Teeuw",
            	"contributors": [
            		"https://github.com/MagicMirrorOrg/MagicMirror/graphs/contributors"
            	"license": "MIT",
            	"bugs": {
            		"url": "https://github.com/MagicMirrorOrg/MagicMirror/issues"
            	"homepage": "https://magicmirror.builders",
            	"devDependencies": {
            		"@stylistic/eslint-plugin": "^1.7.0",
            		"eslint-plugin-import": "^2.29.1",
            		"eslint-plugin-jest": "^27.9.0",
            		"eslint-plugin-jsdoc": "^48.2.2",
            		"eslint-plugin-package-json": "^0.12.1",
            		"eslint-plugin-unicorn": "^51.0.1",
            		"express-basic-auth": "^1.2.1",
            		"husky": "^9.0.11",
            		"jest": "^29.7.0",
            		"jsdom": "^24.0.0",
            		"lint-staged": "^15.2.2",
            		"playwright": "^1.42.1",
            		"prettier": "^3.2.5",
            		"sinon": "^17.0.1",
            		"stylelint": "^16.3.1",
            		"stylelint-config-standard": "^36.0.0",
            		"stylelint-prettier": "^5.0.0"
            	"optionalDependencies": {
            		"electron": "^29.1.6"
            	"dependencies": {
            		"ansis": "^2.3.0",
            		"console-stamp": "^3.1.2",
            		"envsub": "^4.1.0",
            		"eslint": "^8.57.0",
            		"express": "^4.19.2",
            		"express-ipfilter": "^1.3.2",
            		"feedme": "^2.0.2",
            		"helmet": "^7.1.0",
            		"html-to-text": "^9.0.5",
            		"iconv-lite": "^0.6.3",
            		"module-alias": "^2.2.3",
            		"moment": "^2.30.1",
            		"node-ical": "^0.18.0",
            		"pm2": "^5.3.1",
            		"socket.io": "^4.7.5",
            		"suncalc": "^1.9.0",
            		"systeminformation": "^5.22.6"
            	"lint-staged": {
            		"*": "prettier --write",
            		"*.js": "eslint --fix",
            		"*.css": "stylelint --fix"
            	"_moduleAliases": {
            		"node_helper": "js/node_helper.js",
            		"logger": "js/logger.js"
            	"engines": {
            		"node": ">=18"
            And here is run-start.sh:
            #!/bin/bash
            # use bash instead of sh
            # get the folder  for this file
            DIR=$(dirname "$0")
            # make sure we are running in that folder
            cd "$DIR" >/dev/null
            # check for the old untrack css script
            [ -f ./untrack-css.sh ] && ./untrack-css.sh
            # if running under docker
            if grep docker /proc/1/cgroup -qa; then
              #  only start electron
              electron js/electron.js $1;
            else
              # not running in docker
              if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
                export DISPLAY=:0 # Set by default display
              fi
              # get the processor architecture
              arch=$(uname -m)
              false='false'
              true='true'
              # get the config option, if any
              # only check non comment lines
              serveronly=$(grep -v '^[[:blank:]]*//' config/config.js | grep -i serveronly: | tr -d ',"'\''\r' | tr -d ' ' | awk -F/ '{print $1}'  |  awk -F: '{print $2}')
              # set default if not defined in config
              serveronly=${serveronly:-false}
              # check for xwindows running
              while [ 1 -eq 1 ];
              do
                xorg=$(pgrep Xorg)
                if [ "$xorg." == "." ]; then
                   # check for x on Lubuntu
                   xorg=$(pgrep X)
                fi
                # if user set wait_for_x to some value (ANY value)
                if [ "$wait_for_x." != "." ]; then
                  if [ "$xorg." != "." ]; then
                    # then break from loop
                    break;
                  else
                    # sleep for 1 second
                    sleep 1
                  fi
                else
                  # exit loop, not waiting, default
                  break;
                fi
              done
              #check for macOS
              mac=$(uname)
              el_installed=$true
              if [ ! -d node_modules/electron ]; then
                el_installed=$false
              fi
              # if the user requested serveronly OR
              #    electron support for armv6l has been dropped OR
              #    system is in text mode
              if [ "$serveronly." != "$false." -o  "$arch" == "armv6l" -o "$arch" == "i686" -o $el_installed == $false  ]  ||  [ "$xorg." == "." -a $mac != 'Darwin' -a "$wait_for_x." != "." ]; then
                  t=$(ps -ef | grep  "node serveronly" | grep -m1 -v color | awk '{print $2}')
                  if [ "$t." != '.' ]; then
                    sudo kill -9 $t >/dev/null 2>&1
                  fi
                # if user explicitly configured to run server only (no ui local)
                # OR there is no xwindows running, so no support for browser graphics
                if [ "$serveronly." == "$true." ] || [ "$xorg." == "." -a $mac != 'Darwin' -a "$wait_for_x." != "." ]; then
                  # start server mode,
                  node serveronly
                else
                  # start the server in the background
                  # wait for server to be ready
                  # need bash for this
                  exec 3< <(node serveronly)
                  # Read the output of server line by line until one line 'point your browser'
                  while read line; do
                     case "$line" in
                     *point\ your\ browser*)
                        echo $line
                        break
                        echo $line
                        #sleep .25
                     esac
                  done <&3
                  # Close the file descriptor
                  #exec 3<&-
                  # lets use chrome to display here now
                  # get the server port address from the ready message
                  port=$(echo $line | awk -F\: '{print $4}')
                  # start chromium
                  # echo "Starting chromium browser now, have patience, it takes a minute"
                  # continue to spool stdout to console
                  tee <&3 &
                  if [ "$external_browser." == "." ]; then
                    # start chromium
                  	if [ $mac != 'Darwin' ]; then
                      	b="chromium"
                        if [ $(which $b). == '.' -o $arch == 'armv6l' ]; then
                          b='chromium-browser'
                        fi
                      	if [ $(which $b). != '.' ]; then
                          rm -rf ~/.config/$b 2>/dev/null
                          r=$(mktemp -d "${TMPDIR:-/tmp}"/tmp.XXXXXXXX)
                          "$b" -noerrdialogs -kiosk -start_maximized --new-window --site-per-process --no-zygote --no-sandbox --disable-infobars --app=http://localhost:$port  --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors --user-data-dir=$r 2>/dev/null
                          rm -rf $r >/dev/null
                        else
                          echo "Chromium_browser not installed"
                          # if we can't start chrome,
                          # get the server process id
                          ns=$(ps -ef | grep  "node serveronly" | grep -m1 -v color | awk '{print $2}')
                          # if we have the process id
                          if [ "$ns". != "." ]; then
                              # kill server for restart
                              sudo kill -9 $ns >/dev/null 2>&1
                          fi
                      	fi
                  	else
                  	  open -a "Google Chrome" http://localhost:$port --args -noerrdialogs -kiosk -start_maximized  --disable-infobars --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors 2>/dev/null
                  	fi
                  else
                    # if the external browser was specified
                    if [ "$(which $external_browser)." !=  "." ]; then
                      # launch it
                      case ${external_browser,,} in
                      midori )
                        # start midori
                        echo "Starting $external_browser  browser now, have patience, it takes a minute"
                        "$external_browser" http://localhost:$port -e Fullscreen -e Navigationbar  >/dev/null 2>&1
                      firefox )
                        # start firefox
                        "$external_browser" http://localhost:$port  -kiosk >/dev/null 2>&1
                      surf )
                        # start surf
                        "$external_browser" -F http://localhost:$port >/dev/null 2>&1
                      #else
                        echo "don't know how to launch $external_browser"
                      esac
                    else
                      echo "couldn't locate $external_browser from the command shell,. check the PATH environment variable"
                    fi
                  fi
                  exit
                fi
              else
                # we can use electron directly
                node_modules/.bin/electron js/electron.js $1;
              fi
            fi
              @sdetweil And just to be thorough, here is my install.log. I don’t know what’s going on with those weird unicode characters in the log. And there are lots of “memory leak detected” that I don’t recall seeing back in May.
              install starting  - Thu Aug  1 11:35:10 EDT 2024
              installing on armv6l processor system
              the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
                             total        used        free      shared  buff/cache   available
              Mem:             429         182          71           7         175         187
              Swap:             99           5          94
              Updating packages ...
              Reading package lists...
              Update failed, retrying installation ...
              Installing helper tools ...
              Building dependency tree...
              Reading state information...
              build-essential is already the newest version (12.9).
              curl is already the newest version (7.74.0-1.3+deb11u12).
              git is already the newest version (1:2.30.2-1+deb11u2).
              unzip is already the newest version (6.0-26+deb11u1).
              wget is already the newest version (1.21-1+deb11u1).
              wget set to manually installed.
              The following package was automatically installed and is no longer required:
                libfuse2
              Use 'sudo apt autoremove' to remove it.
              0 upgraded, 0 newly installed, 0 to remove and 39 not upgraded.
               this should be a raspberry pi 02w
              increasing swap space
              computing size, want /var/swap=878MByte, checking existing: deleting wrong size file (104857600), generating swapfile ... of 878MBytes
              Node.js is not installed.
              Installing Node.js ...
              Node release info = 2024-08-01 11:37:40 - Installing pre-requisites Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Reading package lists... Reading package lists... Building dependency tree... Reading state information... ca-certificates is already the newest version (20210119). curl is already the newest version (7.74.0-1.3+deb11u12). gnupg is already the newest version (2.2.27-2+deb11u2). The following package was automatically installed and is no longer required: libfuse2 Use 'sudo apt autoremove' to remove it. The following NEW packages will be installed: apt-transport-https 0 upgraded, 1 newly installed, 0 to remove and 39 not upgraded. Need to get 160 kB of archives. After this operation, 166 kB of additional disk space will be used. Get:1 http://mirror.umd.edu/raspbian/raspbian bullseye/main armhf apt-transport-https all 2.2.4 [160 kB] Fetched 160 kB in 1s (126 kB/s) Selecting previously unselected package apt-transport-https.
               (Reading database ...
              (Reading database ... 5%
              (Reading database ... 10%
              (Reading database ... 15%
              (Reading database ... 20%
              (Reading database ... 25%
              (Reading database ... 30%
              (Reading database ... 35%
              (Reading database ... 40%
              (Reading database ... 45%
              (Reading database ... 50%
              (Reading database ... 55%
              (Reading database ... 60%
              (Reading database ... 65%
              (Reading database ... 70%
              (Reading database ... 75%
              (Reading database ... 80%
              (Reading database ... 85%
              (Reading database ... 90%
              (Reading database ... 95%
              (Reading database ... 100%
              (Reading database ... 106675 files and directories currently installed.)
               Preparing to unpack .../apt-transport-https_2.2.4_all.deb ...
               Unpacking apt-transport-https (2.2.4) ...
               Setting up apt-transport-https (2.2.4) ...
               Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Get:3 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB] Get:4 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages [8,776 B] Fetched 20.9 kB in 5s (3,822 B/s) Reading package lists... 2024-08-01 11:39:23 - Repository configured successfully. 2024-08-01 11:39:23 - To install Node.js, run: apt-get install nodejs -y 2024-08-01 11:39:23 - You can use N|solid Runtime as a node.js alternative 2024-08-01 11:39:23 - To install N|solid Runtime, run: apt-get install nsolid -y
              node 20.x version installer not available, doing manually
              libstdc++6 is already the newest version (10.2.1-6+rpi1).
                libfuse2
              using release tar file = node_release-v20.9.0.tar.gz
              node version is v20.9.0
              Node.js installation Done! version=v20.9.0
              Minimum npm version: V10.1.0
              Installed npm version: V10.1.0
              No npm upgrade necessary.
              Cloning MagicMirror ...
              Cloning MagicMirror Done!
              Installing dependencies ...
              > magicmirror@2.28.0 postinstall > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully! > " > magicmirror@2.28.0 install-vendor > echo "Installing vendor files ... > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier Installing vendor files ... added 10 packages in 1m > magicmirror@2.28.0 install-fonts > echo "Installing fonts ... > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier Installing fonts ... added 2 packages in 36s MagicMirror² installation finished successfully! > magicmirror@2.28.0 prepare > [ -f node_modules/.bin/husky ] && husky || echo no husky installed. no husky installed. added 433 packages in 19m 101 packages are looking for funding run `npm fund` for details
              Dependencies installation Done!
              package.json update for armv6l or Electron missing, completed ok
              setting up initial config.js
              Check plymouth installation ...
              Splashscreen: Checking themes directory.
              Splashscreen: Create theme directory if not exists.
              Splashscreen: Changed theme to MagicMirror successfully.
              disable screensaver via gsettings was true and uint32 300
              disable screensaver via lightdm.conf
              disable screensaver via lxsession
              install and setup pm2
              pm2 not installed, installing
              pm2 install result (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (Use `node --trace-warnings ...` to show where the warning was created) (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit added 138 packages in 3m
              get the pm2 platform specific startup command
              startup command = sudo env PATH=$PATH:/usr/local/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u dvg --hp /home/dvg
              __/\\\\\\\\\\\\\____/\\\\____________/\\\\____/\\\\\\\\\_____
               _\/\\\/////////\\\_\/\\\\\\________/\\\\\\__/\\\///////\\\___
                _\/\\\_______\/\\\_\/\\\//\\\____/\\\//\\\_\///______\//\\\__
                 _\/\\\\\\\\\\\\\/__\/\\\\///\\\/\\\/_\/\\\___________/\\\/___
                  _\/\\\/////////____\/\\\__\///\\\/___\/\\\________/\\\//_____
                   _\/\\\_____________\/\\\____\///_____\/\\\_____/\\\//________
                    _\/\\\_____________\/\\\_____________\/\\\___/\\\/___________
                     _\/\\\_____________\/\\\_____________\/\\\__/\\\\\\\\\\\\\\\_
                      _\///______________\///______________\///__\///////////////__
                                        Runtime Edition
                      PM2 is a Production Process Manager for Node.js applications
                                   with a built-in Load Balancer.
                              Start and Daemonize any application:
                              $ pm2 start app.js
                              Load Balance 4 instances of api.js:
                              $ pm2 start api.js -i 4
                              Monitor in production:
                              $ pm2 monitor
                              Make pm2 auto-boot at server restart:
                              $ pm2 startup
                              To go further checkout:
                              http://pm2.io/
              [PM2] Init System found: systemd
              Platform systemd
              Template
              [Unit]
              Description=PM2 process manager
              Documentation=https://pm2.keymetrics.io/
              After=network.target
              [Service]
              Type=forking
              User=dvg
              LimitNOFILE=infinity
              LimitNPROC=infinity
              LimitCORE=infinity
              Environment=PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games:/usr/local/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
              Environment=PM2_HOME=/home/dvg/.pm2
              PIDFile=/home/dvg/.pm2/pm2.pid
              Restart=on-failure
              ExecStart=/usr/local/lib/node_modules/pm2/bin/pm2 resurrect
              ExecReload=/usr/local/lib/node_modules/pm2/bin/pm2 reload all
              ExecStop=/usr/local/lib/node_modules/pm2/bin/pm2 kill
              [Install]
              WantedBy=multi-user.target
              Target path
              /etc/systemd/system/pm2-dvg.service
              Command list
              [ 'systemctl enable pm2-dvg' ]
              [PM2] Writing init configuration in /etc/systemd/system/pm2-dvg.service
              [PM2] Making script booting at startup...
              [PM2] [-] Executing: systemctl enable pm2-dvg...
              Created symlink /etc/systemd/system/multi-user.target.wants/pm2-dvg.service → /etc/systemd/system/pm2-dvg.service.
              [PM2] [v] Command successfully executed.
              [PM2] Freeze a process list on reboot via:
              $ pm2 save
              [PM2] Remove init script via:
              $ pm2 unstartup systemd
              pm2 startup command done
              configure the pm2 config file for MagicMirror
              rename pm2 process in pm2_MagicMirror.json
              the user is not pi
              change pm2_MagicMirror.json
              now using this config file pm2_MagicMirror_new.json
              start MagicMirror via pm2 now
              save MagicMirror pm2 config now
              stop MagicMirror via pm2 now
              We're ready! Run pm2 start pm2 from the ~/MagicMirror directory to start your MagicMirror.
              install completed - Thu Aug  1 12:08:49 EDT 2024
                @sdetweil I scoured the forums and found someone else complaining about electron being missing.
                I ran this sudo npm i -g npm@6 and now it seems to be working fine.
                  @davidgagne that makes no sense… the latest version of npm is 10.x
                  and you just installed v6… (maybe)
                  do
                  npm -v
                    @davidgagne said in MagicMirror Failing on Raspberry Pi Zero W Rev 1.1:
                    that is an npm bug… nothing we can do anything about. no impact on install
                    unicode… those are shell escape codes for color (the colors don’t show in the file, only on the actual console)
                      @sdetweil npm -v returns 6.14.18 (and it takes a solid 45 seconds to do that, which seems like a very long time for such a simple command, even on a Zero).
                      S butchkemperB 2 Replies Last reply Reply Quote 0
                        @davidgagne do free -m
                        pi is small on memory, so running off sd card a lot…
                          @sdetweil I was wrong. It’s not working fine.
                          It was working fine. Then I rebooted to make sure everything was fine. Comes back up with no problem.
                          Then I ssh-ed to it, installed a module, ran npm install inside the new module’s directory, execute pm2 start MagicMirror, and now MM crashes again looking for electron.
                          So frustrating.
                            @sdetweil Can I run sudo npm i -g npm@10 to upgrade to v10?
                            Also: Can you help with getting my forum account upgraded so I don’t have all my posts queued for approval?
                              if you do
                              npm start
                              what happens?
                                @sdetweil Here is the output from npm start called from within MM folder:
                                > magicmirror@2.28.0 start /home/dvg/MagicMirror
                                > ./run-start.sh $1
                                [2024-08-01 14:22:15.896] [LOG] Starting MagicMirror: v2.28.0
                                [2024-08-01 14:22:17.801] [LOG] Loading config ...
                                [2024-08-01 14:22:17.876] [LOG] config template file not exists, no envsubst
                                [2024-08-01 14:22:37.345] [LOG] Loading module helpers ...
                                [2024-08-01 14:22:37.587] [LOG] No helper found for module: alert.
                                [2024-08-01 14:22:39.311] [LOG] Initializing new module helper ...
                                [2024-08-01 14:22:39.627] [LOG] Module helper loaded: updatenotification
                                [2024-08-01 14:22:39.840] [LOG] No helper found for module: clock.
                                [2024-08-01 14:22:40.776] [LOG] Initializing new module helper ...
                                [2024-08-01 14:22:40.933] [LOG] Module helper loaded: mmm-systemtemperature
                                [2024-08-01 14:22:41.119] [LOG] No helper found for module: compliments.
                                [2024-08-01 14:22:41.252] [LOG] No helper found for module: weather.
                                [2024-08-01 14:22:41.370] [LOG] No helper found for module: weather.
                                [2024-08-01 14:22:41.440] [LOG] No helper found for module: weather.
                                [2024-08-01 14:22:41.542] [LOG] All module helpers loaded.
                                [2024-08-01 14:22:43.350] [LOG] Starting server on port 8080 ...
                                [2024-08-01 14:22:44.452] [WARN]  You're using a full whitelist configuration to allow for all IPs
                                [2024-08-01 14:22:46.725] [LOG] Server started ...
                                [2024-08-01 14:22:46.942] [LOG] Connecting socket for: updatenotification
                                [2024-08-01 14:22:47.186] [LOG] Starting module helper: updatenotification
                                [2024-08-01 14:22:47.362] [LOG] Connecting socket for: mmm-systemtemperature
                                [2024-08-01 14:22:47.504] [LOG] Starting node helper: mmm-systemtemperature
                                [2024-08-01 14:22:47.554] [LOG] Sockets connected & modules started ...
                                [2024-08-01 14:22:47.633] [INFO]
                                >>> Ready to go! Please point your browser to: http://0.0.0.0:8080 <<<
                                ./run-start.sh: line 79: 11125 Killed                  node serveronly
                                  the config I requested for the forum a couple years ago is a reputation of 2, and then posts will not be moderated.
                                  https://forum.magicmirror.builders/post/104688
                                  this keeps out all the spam, and other nasty stuff…
                                  I review every post that goes thru moderation queue. so I am the bottleneck…
                                  to improve your rep, takes contributing something that other users like enough to vote up your post…
                                  I cannot override that.
                                    so you have to install, firefox, midiori, or surf
                                    see my scripts doc
                                    https://github.com/sdetweil/MagicMirror_scripts?tab=readme-ov-file#switch-to-the-midori-or-firefox-or-surf-browser
                                      @sdetweil Right. I did all that – uninstalled chromium, installed Firefox, and edited installers/mm.sh – as part of my installation process. I’m not sure why it’s still looking for chromium; I assume it’s hard coded somewhere in the MM startup script.
                                        @davidgagne not hard coded…
                                            # if not set
                                                # start chromium
                                        it IS case sensitive and ALSO needs the export
                                        unlike Windows in linux environment variables are not inherited by default…
                                        show me the mm.sh
                                          @sdetweil Here’s the entire mm.sh file:
                                          #!/bin/bash
                                          # This file is still here to keep PM2 working on older installations.
                                          export external_browser=firefox
                                          DISPLAY=:0 npm start
                                            @davidgagne hm… no idea really
                                            you can test the script with
                                            installers/mm.sh
                                            and
                                            npm start
                                            never seen it fail tho.
