    MagicMirror Failing on Raspberry Pi Zero W Rev 1.1
    43 Posts 3 Posters 14.4k Views 3 Watching
      davidgagne @sdetweil
      @sdetweil Here are the contents of the package.json and run-start.sh files. Note that I have not edited anything. This is exactly how they came from the installation process.
      	"name": "magicmirror",
      	"version": "2.27.0",
      	"description": "The open source modular smart mirror platform.",
      	"main": "js/electron.js",
      	"scripts": {
          "start":"./run-start.sh $1",
      		"server": "node ./serveronly",
      		"install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev",
      		"install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier",
      		"install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
      		"install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
      		"postinstall": "npm run install-vendor && npm run install-fonts && echo \"MagicMirror² installation finished successfully! \n\"",
      		"test": "NODE_ENV=test jest -i --forceExit",
      		"test:coverage": "NODE_ENV=test jest --coverage -i --verbose false --forceExit",
      		"test:electron": "NODE_ENV=test jest --selectProjects electron -i --forceExit",
      		"test:e2e": "NODE_ENV=test jest --selectProjects e2e -i --forceExit",
      		"test:unit": "NODE_ENV=test jest --selectProjects unit",
      		"test:prettier": "prettier . --check",
      		"test:js": "eslint .",
      		"test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json",
      		"test:calendar": "node ./modules/default/calendar/debug.js",
      		"config:check": "node js/check_config.js",
      		"lint:prettier": "prettier . --write",
      		"lint:js": "eslint . --fix",
      		"lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json --fix",
      		"lint:staged": "lint-staged",
      		"prepare": "[ -f node_modules/.bin/husky ] && husky || echo no husky installed."
      	"repository": {
      		"type": "git",
      		"url": "https://github.com/MagicMirrorOrg/MagicMirror"
      	"keywords": [
      		"magic mirror",
      		"magicmirror",
      		"smart mirror",
      		"mirror UI",
      		"modular"
      	"author": "Michael Teeuw",
      	"contributors": [
      		"https://github.com/MagicMirrorOrg/MagicMirror/graphs/contributors"
      	"license": "MIT",
      	"bugs": {
      		"url": "https://github.com/MagicMirrorOrg/MagicMirror/issues"
      	"homepage": "https://magicmirror.builders",
      	"devDependencies": {
      		"@stylistic/eslint-plugin": "^1.7.0",
      		"eslint-plugin-import": "^2.29.1",
      		"eslint-plugin-jest": "^27.9.0",
      		"eslint-plugin-jsdoc": "^48.2.2",
      		"eslint-plugin-package-json": "^0.12.1",
      		"eslint-plugin-unicorn": "^51.0.1",
      		"express-basic-auth": "^1.2.1",
      		"husky": "^9.0.11",
      		"jest": "^29.7.0",
      		"jsdom": "^24.0.0",
      		"lint-staged": "^15.2.2",
      		"playwright": "^1.42.1",
      		"prettier": "^3.2.5",
      		"sinon": "^17.0.1",
      		"stylelint": "^16.3.1",
      		"stylelint-config-standard": "^36.0.0",
      		"stylelint-prettier": "^5.0.0"
      	"optionalDependencies": {
      		"electron": "^29.1.6"
      	"dependencies": {
      		"ansis": "^2.3.0",
      		"console-stamp": "^3.1.2",
      		"envsub": "^4.1.0",
      		"eslint": "^8.57.0",
      		"express": "^4.19.2",
      		"express-ipfilter": "^1.3.2",
      		"feedme": "^2.0.2",
      		"helmet": "^7.1.0",
      		"html-to-text": "^9.0.5",
      		"iconv-lite": "^0.6.3",
      		"module-alias": "^2.2.3",
      		"moment": "^2.30.1",
      		"node-ical": "^0.18.0",
      		"pm2": "^5.3.1",
      		"socket.io": "^4.7.5",
      		"suncalc": "^1.9.0",
      		"systeminformation": "^5.22.6"
      	"lint-staged": {
      		"*": "prettier --write",
      		"*.js": "eslint --fix",
      		"*.css": "stylelint --fix"
      	"_moduleAliases": {
      		"node_helper": "js/node_helper.js",
      		"logger": "js/logger.js"
      	"engines": {
      		"node": ">=18"
      And here is run-start.sh:
      #!/bin/bash
      # use bash instead of sh
      # get the folder  for this file
      DIR=$(dirname "$0")
      # make sure we are running in that folder
      cd "$DIR" >/dev/null
      # check for the old untrack css script
      [ -f ./untrack-css.sh ] && ./untrack-css.sh
      # if running under docker
      if grep docker /proc/1/cgroup -qa; then
        #  only start electron
        electron js/electron.js $1;
      else
        # not running in docker
        if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
          export DISPLAY=:0 # Set by default display
        fi
        # get the processor architecture
        arch=$(uname -m)
        false='false'
        true='true'
        # get the config option, if any
        # only check non comment lines
        serveronly=$(grep -v '^[[:blank:]]*//' config/config.js | grep -i serveronly: | tr -d ',"'\''\r' | tr -d ' ' | awk -F/ '{print $1}'  |  awk -F: '{print $2}')
        # set default if not defined in config
        serveronly=${serveronly:-false}
        # check for xwindows running
        while [ 1 -eq 1 ];
        do
          xorg=$(pgrep Xorg)
          if [ "$xorg." == "." ]; then
             # check for x on Lubuntu
             xorg=$(pgrep X)
          fi
          # if user set wait_for_x to some value (ANY value)
          if [ "$wait_for_x." != "." ]; then
            if [ "$xorg." != "." ]; then
              # then break from loop
              break;
            else
              # sleep for 1 second
              sleep 1
            fi
          else
            # exit loop, not waiting, default
            break;
          fi
        done
        #check for macOS
        mac=$(uname)
        el_installed=$true
        if [ ! -d node_modules/electron ]; then
          el_installed=$false
        fi
        # if the user requested serveronly OR
        #    electron support for armv6l has been dropped OR
        #    system is in text mode
        if [ "$serveronly." != "$false." -o  "$arch" == "armv6l" -o "$arch" == "i686" -o $el_installed == $false  ]  ||  [ "$xorg." == "." -a $mac != 'Darwin' -a "$wait_for_x." != "." ]; then
            t=$(ps -ef | grep  "node serveronly" | grep -m1 -v color | awk '{print $2}')
            if [ "$t." != '.' ]; then
              sudo kill -9 $t >/dev/null 2>&1
            fi
          # if user explicitly configured to run server only (no ui local)
          # OR there is no xwindows running, so no support for browser graphics
          if [ "$serveronly." == "$true." ] || [ "$xorg." == "." -a $mac != 'Darwin' -a "$wait_for_x." != "." ]; then
            # start server mode,
            node serveronly
          else
            # start the server in the background
            # wait for server to be ready
            # need bash for this
            exec 3< <(node serveronly)
            # Read the output of server line by line until one line 'point your browser'
            while read line; do
               case "$line" in
               *point\ your\ browser*)
                  echo $line
                  break
                  echo $line
                  #sleep .25
               esac
            done <&3
            # Close the file descriptor
            #exec 3<&-
            # lets use chrome to display here now
            # get the server port address from the ready message
            port=$(echo $line | awk -F\: '{print $4}')
            # start chromium
            # echo "Starting chromium browser now, have patience, it takes a minute"
            # continue to spool stdout to console
            tee <&3 &
            if [ "$external_browser." == "." ]; then
              # start chromium
            	if [ $mac != 'Darwin' ]; then
                	b="chromium"
                  if [ $(which $b). == '.' -o $arch == 'armv6l' ]; then
                    b='chromium-browser'
                  fi
                	if [ $(which $b). != '.' ]; then
                    rm -rf ~/.config/$b 2>/dev/null
                    r=$(mktemp -d "${TMPDIR:-/tmp}"/tmp.XXXXXXXX)
                    "$b" -noerrdialogs -kiosk -start_maximized --new-window --site-per-process --no-zygote --no-sandbox --disable-infobars --app=http://localhost:$port  --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors --user-data-dir=$r 2>/dev/null
                    rm -rf $r >/dev/null
                  else
                    echo "Chromium_browser not installed"
                    # if we can't start chrome,
                    # get the server process id
                    ns=$(ps -ef | grep  "node serveronly" | grep -m1 -v color | awk '{print $2}')
                    # if we have the process id
                    if [ "$ns". != "." ]; then
                        # kill server for restart
                        sudo kill -9 $ns >/dev/null 2>&1
                    fi
                	fi
            	else
            	  open -a "Google Chrome" http://localhost:$port --args -noerrdialogs -kiosk -start_maximized  --disable-infobars --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors 2>/dev/null
            	fi
            else
              # if the external browser was specified
              if [ "$(which $external_browser)." !=  "." ]; then
                # launch it
                case ${external_browser,,} in
                midori )
                  # start midori
                  echo "Starting $external_browser  browser now, have patience, it takes a minute"
                  "$external_browser" http://localhost:$port -e Fullscreen -e Navigationbar  >/dev/null 2>&1
                firefox )
                  # start firefox
                  "$external_browser" http://localhost:$port  -kiosk >/dev/null 2>&1
                surf )
                  # start surf
                  "$external_browser" -F http://localhost:$port >/dev/null 2>&1
                #else
                  echo "don't know how to launch $external_browser"
                esac
              else
                echo "couldn't locate $external_browser from the command shell,. check the PATH environment variable"
              fi
            fi
            exit
          fi
        else
          # we can use electron directly
          node_modules/.bin/electron js/electron.js $1;
        fi
      fi
        @sdetweil And just to be thorough, here is my install.log. I don’t know what’s going on with those weird unicode characters in the log. And there are lots of “memory leak detected” that I don’t recall seeing back in May.
        install starting  - Thu Aug  1 11:35:10 EDT 2024
        installing on armv6l processor system
        the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
                       total        used        free      shared  buff/cache   available
        Mem:             429         182          71           7         175         187
        Swap:             99           5          94
        Updating packages ...
        Reading package lists...
        Update failed, retrying installation ...
        Installing helper tools ...
        Building dependency tree...
        Reading state information...
        build-essential is already the newest version (12.9).
        curl is already the newest version (7.74.0-1.3+deb11u12).
        git is already the newest version (1:2.30.2-1+deb11u2).
        unzip is already the newest version (6.0-26+deb11u1).
        wget is already the newest version (1.21-1+deb11u1).
        wget set to manually installed.
        The following package was automatically installed and is no longer required:
          libfuse2
        Use 'sudo apt autoremove' to remove it.
        0 upgraded, 0 newly installed, 0 to remove and 39 not upgraded.
         this should be a raspberry pi 02w
        increasing swap space
        computing size, want /var/swap=878MByte, checking existing: deleting wrong size file (104857600), generating swapfile ... of 878MBytes
        Node.js is not installed.
        Installing Node.js ...
        Node release info = 2024-08-01 11:37:40 - Installing pre-requisites Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Reading package lists... Reading package lists... Building dependency tree... Reading state information... ca-certificates is already the newest version (20210119). curl is already the newest version (7.74.0-1.3+deb11u12). gnupg is already the newest version (2.2.27-2+deb11u2). The following package was automatically installed and is no longer required: libfuse2 Use 'sudo apt autoremove' to remove it. The following NEW packages will be installed: apt-transport-https 0 upgraded, 1 newly installed, 0 to remove and 39 not upgraded. Need to get 160 kB of archives. After this operation, 166 kB of additional disk space will be used. Get:1 http://mirror.umd.edu/raspbian/raspbian bullseye/main armhf apt-transport-https all 2.2.4 [160 kB] Fetched 160 kB in 1s (126 kB/s) Selecting previously unselected package apt-transport-https.
         (Reading database ...
        (Reading database ... 5%
        (Reading database ... 10%
        (Reading database ... 15%
        (Reading database ... 20%
        (Reading database ... 25%
        (Reading database ... 30%
        (Reading database ... 35%
        (Reading database ... 40%
        (Reading database ... 45%
        (Reading database ... 50%
        (Reading database ... 55%
        (Reading database ... 60%
        (Reading database ... 65%
        (Reading database ... 70%
        (Reading database ... 75%
        (Reading database ... 80%
        (Reading database ... 85%
        (Reading database ... 90%
        (Reading database ... 95%
        (Reading database ... 100%
        (Reading database ... 106675 files and directories currently installed.)
         Preparing to unpack .../apt-transport-https_2.2.4_all.deb ...
         Unpacking apt-transport-https (2.2.4) ...
         Setting up apt-transport-https (2.2.4) ...
         Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Get:3 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB] Get:4 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages [8,776 B] Fetched 20.9 kB in 5s (3,822 B/s) Reading package lists... 2024-08-01 11:39:23 - Repository configured successfully. 2024-08-01 11:39:23 - To install Node.js, run: apt-get install nodejs -y 2024-08-01 11:39:23 - You can use N|solid Runtime as a node.js alternative 2024-08-01 11:39:23 - To install N|solid Runtime, run: apt-get install nsolid -y
        node 20.x version installer not available, doing manually
        libstdc++6 is already the newest version (10.2.1-6+rpi1).
          libfuse2
        using release tar file = node_release-v20.9.0.tar.gz
        node version is v20.9.0
        Node.js installation Done! version=v20.9.0
        Minimum npm version: V10.1.0
        Installed npm version: V10.1.0
        No npm upgrade necessary.
        Cloning MagicMirror ...
        Cloning MagicMirror Done!
        Installing dependencies ...
        > magicmirror@2.28.0 postinstall > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully! > " > magicmirror@2.28.0 install-vendor > echo "Installing vendor files ... > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier Installing vendor files ... added 10 packages in 1m > magicmirror@2.28.0 install-fonts > echo "Installing fonts ... > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier Installing fonts ... added 2 packages in 36s MagicMirror² installation finished successfully! > magicmirror@2.28.0 prepare > [ -f node_modules/.bin/husky ] && husky || echo no husky installed. no husky installed. added 433 packages in 19m 101 packages are looking for funding run `npm fund` for details
        Dependencies installation Done!
        package.json update for armv6l or Electron missing, completed ok
        setting up initial config.js
        Check plymouth installation ...
        Splashscreen: Checking themes directory.
        Splashscreen: Create theme directory if not exists.
        Splashscreen: Changed theme to MagicMirror successfully.
        disable screensaver via gsettings was true and uint32 300
        disable screensaver via lightdm.conf
        disable screensaver via lxsession
        install and setup pm2
        pm2 not installed, installing
        pm2 install result (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (Use `node --trace-warnings ...` to show where the warning was created) (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit (node:2290) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit added 138 packages in 3m
        get the pm2 platform specific startup command
        startup command = sudo env PATH=$PATH:/usr/local/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u dvg --hp /home/dvg
        __/\\\\\\\\\\\\\____/\\\\____________/\\\\____/\\\\\\\\\_____
         _\/\\\/////////\\\_\/\\\\\\________/\\\\\\__/\\\///////\\\___
          _\/\\\_______\/\\\_\/\\\//\\\____/\\\//\\\_\///______\//\\\__
           _\/\\\\\\\\\\\\\/__\/\\\\///\\\/\\\/_\/\\\___________/\\\/___
            _\/\\\/////////____\/\\\__\///\\\/___\/\\\________/\\\//_____
             _\/\\\_____________\/\\\____\///_____\/\\\_____/\\\//________
              _\/\\\_____________\/\\\_____________\/\\\___/\\\/___________
               _\/\\\_____________\/\\\_____________\/\\\__/\\\\\\\\\\\\\\\_
                _\///______________\///______________\///__\///////////////__
                                  Runtime Edition
                PM2 is a Production Process Manager for Node.js applications
                             with a built-in Load Balancer.
                        Start and Daemonize any application:
                        $ pm2 start app.js
                        Load Balance 4 instances of api.js:
                        $ pm2 start api.js -i 4
                        Monitor in production:
                        $ pm2 monitor
                        Make pm2 auto-boot at server restart:
                        $ pm2 startup
                        To go further checkout:
                        http://pm2.io/
        [PM2] Init System found: systemd
        Platform systemd
        Template
        [Unit]
        Description=PM2 process manager
        Documentation=https://pm2.keymetrics.io/
        After=network.target
        [Service]
        Type=forking
        User=dvg
        LimitNOFILE=infinity
        LimitNPROC=infinity
        LimitCORE=infinity
        Environment=PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games:/usr/local/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
        Environment=PM2_HOME=/home/dvg/.pm2
        PIDFile=/home/dvg/.pm2/pm2.pid
        Restart=on-failure
        ExecStart=/usr/local/lib/node_modules/pm2/bin/pm2 resurrect
        ExecReload=/usr/local/lib/node_modules/pm2/bin/pm2 reload all
        ExecStop=/usr/local/lib/node_modules/pm2/bin/pm2 kill
        [Install]
        WantedBy=multi-user.target
        Target path
        /etc/systemd/system/pm2-dvg.service
        Command list
        [ 'systemctl enable pm2-dvg' ]
        [PM2] Writing init configuration in /etc/systemd/system/pm2-dvg.service
        [PM2] Making script booting at startup...
        [PM2] [-] Executing: systemctl enable pm2-dvg...
        Created symlink /etc/systemd/system/multi-user.target.wants/pm2-dvg.service → /etc/systemd/system/pm2-dvg.service.
        [PM2] [v] Command successfully executed.
        [PM2] Freeze a process list on reboot via:
        $ pm2 save
        [PM2] Remove init script via:
        $ pm2 unstartup systemd
        pm2 startup command done
        configure the pm2 config file for MagicMirror
        rename pm2 process in pm2_MagicMirror.json
        the user is not pi
        change pm2_MagicMirror.json
        now using this config file pm2_MagicMirror_new.json
        start MagicMirror via pm2 now
        save MagicMirror pm2 config now
        stop MagicMirror via pm2 now
        We're ready! Run pm2 start pm2 from the ~/MagicMirror directory to start your MagicMirror.
        install completed - Thu Aug  1 12:08:49 EDT 2024
          @sdetweil I scoured the forums and found someone else complaining about electron being missing.
          I ran this sudo npm i -g npm@6 and now it seems to be working fine.
            sdetweil @davidgagne
            @davidgagne that makes no sense… the latest version of npm is 10.x
            and you just installed v6… (maybe)
            do
            npm -v
            D 2 Replies Last reply
              @davidgagne said in MagicMirror Failing on Raspberry Pi Zero W Rev 1.1:
              that is an npm bug… nothing we can do anything about. no impact on install
              unicode… those are shell escape codes for color (the colors don’t show in the file, only on the actual console)
                @sdetweil npm -v returns 6.14.18 (and it takes a solid 45 seconds to do that, which seems like a very long time for such a simple command, even on a Zero).
                S butchkemperB 2 Replies Last reply
                  @davidgagne do free -m
                  pi is small on memory, so running off sd card a lot…
                  D 1 Reply Last reply
                    @sdetweil I was wrong. It’s not working fine.
                    It was working fine. Then I rebooted to make sure everything was fine. Comes back up with no problem.
                    Then I ssh-ed to it, installed a module, ran npm install inside the new module’s directory, execute pm2 start MagicMirror, and now MM crashes again looking for electron.
                    So frustrating.
                      @sdetweil Can I run sudo npm i -g npm@10 to upgrade to v10?
                      Also: Can you help with getting my forum account upgraded so I don’t have all my posts queued for approval?
                        if you do
                        npm start
                        what happens?
                          @sdetweil Here is the output from npm start called from within MM folder:
                          > magicmirror@2.28.0 start /home/dvg/MagicMirror
                          > ./run-start.sh $1
                          [2024-08-01 14:22:15.896] [LOG] Starting MagicMirror: v2.28.0
                          [2024-08-01 14:22:17.801] [LOG] Loading config ...
                          [2024-08-01 14:22:17.876] [LOG] config template file not exists, no envsubst
                          [2024-08-01 14:22:37.345] [LOG] Loading module helpers ...
                          [2024-08-01 14:22:37.587] [LOG] No helper found for module: alert.
                          [2024-08-01 14:22:39.311] [LOG] Initializing new module helper ...
                          [2024-08-01 14:22:39.627] [LOG] Module helper loaded: updatenotification
                          [2024-08-01 14:22:39.840] [LOG] No helper found for module: clock.
                          [2024-08-01 14:22:40.776] [LOG] Initializing new module helper ...
                          [2024-08-01 14:22:40.933] [LOG] Module helper loaded: mmm-systemtemperature
                          [2024-08-01 14:22:41.119] [LOG] No helper found for module: compliments.
                          [2024-08-01 14:22:41.252] [LOG] No helper found for module: weather.
                          [2024-08-01 14:22:41.370] [LOG] No helper found for module: weather.
                          [2024-08-01 14:22:41.440] [LOG] No helper found for module: weather.
                          [2024-08-01 14:22:41.542] [LOG] All module helpers loaded.
                          [2024-08-01 14:22:43.350] [LOG] Starting server on port 8080 ...
                          [2024-08-01 14:22:44.452] [WARN]  You're using a full whitelist configuration to allow for all IPs
                          [2024-08-01 14:22:46.725] [LOG] Server started ...
                          [2024-08-01 14:22:46.942] [LOG] Connecting socket for: updatenotification
                          [2024-08-01 14:22:47.186] [LOG] Starting module helper: updatenotification
                          [2024-08-01 14:22:47.362] [LOG] Connecting socket for: mmm-systemtemperature
                          [2024-08-01 14:22:47.504] [LOG] Starting node helper: mmm-systemtemperature
                          [2024-08-01 14:22:47.554] [LOG] Sockets connected & modules started ...
                          [2024-08-01 14:22:47.633] [INFO]
                          >>> Ready to go! Please point your browser to: http://0.0.0.0:8080 <<<
                          ./run-start.sh: line 79: 11125 Killed                  node serveronly
                            the config I requested for the forum a couple years ago is a reputation of 2, and then posts will not be moderated.
                            https://forum.magicmirror.builders/post/104688
                            this keeps out all the spam, and other nasty stuff…
                            I review every post that goes thru moderation queue. so I am the bottleneck…
                            to improve your rep, takes contributing something that other users like enough to vote up your post…
                            I cannot override that.
                              so you have to install, firefox, midiori, or surf
                              see my scripts doc
                              https://github.com/sdetweil/MagicMirror_scripts?tab=readme-ov-file#switch-to-the-midori-or-firefox-or-surf-browser
                                @sdetweil Right. I did all that – uninstalled chromium, installed Firefox, and edited installers/mm.sh – as part of my installation process. I’m not sure why it’s still looking for chromium; I assume it’s hard coded somewhere in the MM startup script.
                                  @davidgagne not hard coded…
                                      # if not set
                                          # start chromium
                                  it IS case sensitive and ALSO needs the export
                                  unlike Windows in linux environment variables are not inherited by default…
                                  show me the mm.sh
                                    @sdetweil Here’s the entire mm.sh file:
                                    #!/bin/bash
                                    # This file is still here to keep PM2 working on older installations.
                                    export external_browser=firefox
                                    DISPLAY=:0 npm start
                                      @davidgagne hm… no idea really
                                      you can test the script with
                                      installers/mm.sh
                                      and
                                      npm start
                                      never seen it fail tho.
                                        @sdetweil If electron hasn’t been required for years, then why does a fresh install of everything generate tens of thousands of “can’t find electron” lines in MagicMirror-error.log?
                                          @davidgagne the default install is to use electron.
                                          We made it optional, so the install would not just fail.
                                          and my script makes other browsers available as alternatives.
                                          if you do the manual install, there is nothing to fix the package.json still trying to use electron. and it errors out.
                                          now you can clear the pm2 logs
                                          pm2 flush
                                          and then see info from future runs
                                            @sdetweil Okay. Next issue is that MagicMirror-out.log is always empty. I recall that I could find lots of information in there the last time I was setting up a MM, but this time it’s always just blank. (The MagicMirror-error.log file is, sadly, useless because it’s just filled with tens of thousands of lines of Error: Cannot find module 'electron'.)
                                            Any idea why MagicMirror-out.log is always empty?
