    MagicMirror Failing on Raspberry Pi Zero W Rev 1.1
    43 Posts 3 Posters 13.3k Views 3 Watching
      davidgagne @sdetweil
      @sdetweil Can I run sudo npm i -g npm@10 to upgrade to v10?
      Also: Can you help with getting my forum account upgraded so I don’t have all my posts queued for approval?
        sdetweil @davidgagne
        @davidgagne said in MagicMirror Failing on Raspberry Pi Zero W Rev 1.1:
        pm2 start MagicMirror, and now MM crashes again looking for electron.
        if you do
        npm start
        what happens?
          @sdetweil Here is the output from npm start called from within MM folder:
          > magicmirror@2.28.0 start /home/dvg/MagicMirror
          > ./run-start.sh $1
          [2024-08-01 14:22:15.896] [LOG] Starting MagicMirror: v2.28.0
          [2024-08-01 14:22:17.801] [LOG] Loading config ...
          [2024-08-01 14:22:17.876] [LOG] config template file not exists, no envsubst
          [2024-08-01 14:22:37.345] [LOG] Loading module helpers ...
          [2024-08-01 14:22:37.587] [LOG] No helper found for module: alert.
          [2024-08-01 14:22:39.311] [LOG] Initializing new module helper ...
          [2024-08-01 14:22:39.627] [LOG] Module helper loaded: updatenotification
          [2024-08-01 14:22:39.840] [LOG] No helper found for module: clock.
          [2024-08-01 14:22:40.776] [LOG] Initializing new module helper ...
          [2024-08-01 14:22:40.933] [LOG] Module helper loaded: mmm-systemtemperature
          [2024-08-01 14:22:41.119] [LOG] No helper found for module: compliments.
          [2024-08-01 14:22:41.252] [LOG] No helper found for module: weather.
          [2024-08-01 14:22:41.370] [LOG] No helper found for module: weather.
          [2024-08-01 14:22:41.440] [LOG] No helper found for module: weather.
          [2024-08-01 14:22:41.542] [LOG] All module helpers loaded.
          [2024-08-01 14:22:43.350] [LOG] Starting server on port 8080 ...
          [2024-08-01 14:22:44.452] [WARN]  You're using a full whitelist configuration to allow for all IPs
          [2024-08-01 14:22:46.725] [LOG] Server started ...
          [2024-08-01 14:22:46.942] [LOG] Connecting socket for: updatenotification
          [2024-08-01 14:22:47.186] [LOG] Starting module helper: updatenotification
          [2024-08-01 14:22:47.362] [LOG] Connecting socket for: mmm-systemtemperature
          [2024-08-01 14:22:47.504] [LOG] Starting node helper: mmm-systemtemperature
          [2024-08-01 14:22:47.554] [LOG] Sockets connected & modules started ...
          [2024-08-01 14:22:47.633] [INFO]
          >>> Ready to go! Please point your browser to: http://0.0.0.0:8080 <<<
          Starting chromium browser now, have patience, it takes a minute
          Chromium_browser not installed
          ./run-start.sh: line 79: 11125 Killed                  node serveronly
            the config I requested for the forum a couple years ago is a reputation of 2, and then posts will not be moderated.
            https://forum.magicmirror.builders/post/104688
            this keeps out all the spam, and other nasty stuff…
            I review every post that goes thru moderation queue. so I am the bottleneck…
            to improve your rep, takes contributing something that other users like enough to vote up your post…
            I cannot override that.
              so you have to install, firefox, midiori, or surf
              see my scripts doc
              https://github.com/sdetweil/MagicMirror_scripts?tab=readme-ov-file#switch-to-the-midori-or-firefox-or-surf-browser
                @sdetweil Right. I did all that – uninstalled chromium, installed Firefox, and edited installers/mm.sh – as part of my installation process. I’m not sure why it’s still looking for chromium; I assume it’s hard coded somewhere in the MM startup script.
                  @davidgagne not hard coded…
                      # if not set
                      if [ "$external_browser." == "." ]; then
                          # start chromium
                          echo "Starting chromium browser now, have patience, it takes a minute"
                  it IS case sensitive and ALSO needs the export
                  unlike Windows in linux environment variables are not inherited by default…
                  show me the mm.sh
                    @sdetweil Here’s the entire mm.sh file:
                    #!/bin/bash
                    # This file is still here to keep PM2 working on older installations.
                    export external_browser=firefox
                    DISPLAY=:0 npm start
                      @davidgagne hm… no idea really
                      you can test the script with
                      installers/mm.sh
                      and
                      npm start
                      never seen it fail tho.
                        @sdetweil If electron hasn’t been required for years, then why does a fresh install of everything generate tens of thousands of “can’t find electron” lines in MagicMirror-error.log?
                          @davidgagne the default install is to use electron.
                          We made it optional, so the install would not just fail.
                          and my script makes other browsers available as alternatives.
                          if you do the manual install, there is nothing to fix the package.json still trying to use electron. and it errors out.
                          now you can clear the pm2 logs
                          pm2 flush
                          and then see info from future runs
                            @sdetweil Okay. Next issue is that MagicMirror-out.log is always empty. I recall that I could find lots of information in there the last time I was setting up a MM, but this time it’s always just blank. (The MagicMirror-error.log file is, sadly, useless because it’s just filled with tens of thousands of lines of Error: Cannot find module 'electron'.)
                            Any idea why MagicMirror-out.log is always empty?
                              @davidgagne out is empty cause mm never started
                              Does
                              npm run server
                              Work
                                @sdetweil I’m sorry, but I don’t understand. What exactly is mm? (MagicMirror is running.)
                                What does npm run server do? (I can visit the IP address of the Pi on my phone or laptop on my home network.)
                                  @sdetweil Calling npm run server immediately after connecting via ssh yields:
                                  npm error code ENOENT
                                  npm error syscall open
                                  npm error path /home/dvg/package.json
                                  npm error errno -2
                                  npm error enoent Could not read package.json: Error: ENOENT: no such file or directory, open '/home/dvg/package.json'
                                  npm error enoent This is related to npm not being able to find a file.
                                  npm error enoent
                                  npm error A complete log of this run can be found in: /home/dvg/.npm/_logs/2024-08-05T16_42_00_562Z-debug-0.log
                                  If I switch to the MagicMirror directory and call it, I get this:
                                  > magicmirror@2.28.0 server
                                  > node ./serveronly
                                  [2024-08-05 12:43:48.489] [LOG]   Starting MagicMirror: v2.28.0
                                  [2024-08-05 12:43:48.956] [LOG]   Loading config ...
                                  [2024-08-05 12:43:49.021] [LOG]   config template file not exists, no envsubst
                                  [2024-08-05 12:43:56.659] [LOG]   Loading module helpers ...
                                  [2024-08-05 12:43:56.760] [LOG]   No helper found for module: alert.
                                  [2024-08-05 12:43:57.912] [LOG]   Initializing new module helper ...
                                  [2024-08-05 12:43:58.105] [LOG]   Module helper loaded: updatenotification
                                  [2024-08-05 12:43:58.210] [LOG]   No helper found for module: clock.
                                  [2024-08-05 12:43:58.475] [LOG]   Initializing new module helper ...
                                  [2024-08-05 12:43:58.608] [LOG]   Module helper loaded: mmm-systemtemperature
                                  [2024-08-05 12:43:58.784] [LOG]   No helper found for module: weather.
                                  [2024-08-05 12:43:58.837] [LOG]   No helper found for module: weather.
                                  [2024-08-05 12:44:06.841] [LOG]   Initializing new module helper ...
                                  [2024-08-05 12:44:06.956] [LOG]   Module helper loaded: MMM-ThemeParkWaitTimes
                                  [2024-08-05 12:44:08.953] [LOG]   Initializing new module helper ...
                                  [2024-08-05 12:44:09.018] [LOG]   Module helper loaded: MMM-birthdays
                                  [2024-08-05 12:44:09.067] [LOG]   No helper found for module: MMM-CloneWarsQuotes.
                                  [2024-08-05 12:44:09.136] [LOG]   Initializing new module helper ...
                                  [2024-08-05 12:44:09.228] [LOG]   Module helper loaded: MMM-ThemeParkWaitTimes
                                  [2024-08-05 12:44:09.603] [LOG]   Initializing new module helper ...
                                  [2024-08-05 12:44:09.673] [LOG]   Module helper loaded: MMM-ImagesPhotos
                                  [2024-08-05 12:44:09.721] [LOG]   All module helpers loaded.
                                  [2024-08-05 12:44:11.000] [LOG]   Starting server on port 8080 ...
                                  [2024-08-05 12:44:11.743] [WARN]  You're using a full whitelist configuration to allow for all IPs
                                  [2024-08-05 12:44:13.607] [ERROR] Whoops! There was an uncaught exception...
                                  [2024-08-05 12:44:14.335] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                                      at Server.setupListenHandle [as _listen2] (node:net:1872:16)
                                      at listenInCluster (node:net:1920:12)
                                      at doListen (node:net:2069:7)
                                      at process.processTicksAndRejections (node:internal/process/task_queues:83:21) {
                                    code: 'EADDRINUSE',
                                    errno: -98,
                                    syscall: 'listen',
                                    address: '0.0.0.0',
                                    port: 8080
                                  [2024-08-05 12:44:14.400] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                  [2024-08-05 12:44:14.422] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                                  [2024-08-05 12:47:35.279] [INFO]  System information:
                                  ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi Zero W Rev 1.1; raspberry: [object Object]; virtual: false
                                  ### OS:       platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21+
                                  ### VERSIONS: electron: undefined; used node: 20.9.0; installed node: 20.9.0; npm: 10.8.2; pm2: 5.4.2
                                  ### OTHER:    timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
                                    @davidgagne mm is my shorthand for MagicMirror
                                      @davidgagne ok, another instance is already running
                                        @sdetweil So then why is my MagicMirror-out.log always empty?
                                          @davidgagne do
                                          pm2 status
                                            @sdetweil Executing pm2 status yields:
                                            │ id │ name   │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                                            │ 0  │ pm2    │ default     │ 2.28.0  │ fork    │ 1238     │ 17h    │ 0    │ online    │ 0%       │ 240.0kb  │ dvg      │ enabled  │
                                            • 2 / 3
