    Help restyling MMM-ValuesByNotification
    18 Posts 3 Posters 4.5k Views 3 Watching
    • wishmaster270W
      wishmaster270 Module Developer @BKeyport
      @BKeyport
      Hi and sorry for the late reply.
      I am not sure if I will have time to test your case the next days.
      I think your main problem is that you try to use “normal” styling directives for the layout but I use flexbox css as the basic.
      You can find a short tutorial at:
      https://css-tricks.com/snippets/css/a-guide-to-flexbox/
      Edit:
      Had 5 minutes and did a quick check.
      I think the following two statements are a good starting point:
      .MMM-ValuesByNotification .vbn .groupsWrapper {
        flex-direction: row;
      .MMM-ValuesByNotification .vbn .valueWrapper {
      • BKeyportB
        BKeyport Module Developer @wishmaster270
        @wishmaster270 I think the problem I’m having is figuring out where to place the classes to trigger what I want. Flex to me seems a bit erratic with how to set things.
          sdetweil @BKeyport
          @BKeyport said in Help restyling MMM-ValuesByNotification:
          the
          if the class style affects a single element, then the style goes there
          if it affects multiple items, then on their parent
          and then you need to look at the style to see if it can be inherited from an ancestor
          http://web.simmons.edu/~grabiner/comm244/weekfour/css-concepts.html#:~:text=In CSS%2C some styles are,tree while others are not.
          • BKeyportB
            I’ve officially given up.
            I can get it to start to look right outside the magicmirror environment, and even with unsetting everything styled within the ValuesByNotification app, I can’t get it to duplicate within Magic Mirror.
            This is with copying Main.css into a test environment, along with the other modules’ CSS files, and using the output HTML from MagicMirror.
            Works great in test, but the moment I try to make it go live, it’s doing random things.
            I hate CSS. I really do.
            S wishmaster270W 2 Replies Last reply Reply Quote 0
              sdetweil @BKeyport
              @BKeyport can you send me info on what you are trying to do
              outside and inside
              same userid at gmail
              • wishmaster270W
                @BKeyport Hi, can you make a screenshot of the things styled outside MagicMirror so we can see how it should look exactly?
                Maybe you will need some additional classes in your module config to make it possible to select the different elements jn CSS.
                • BKeyportB
                  So, after some more playing around, I’ve come to the determination that the HTML and class setup isn’t good for my use. As a result, I’ve got most of a new module set up for use, however, I’m having issues breaking down the JSON as processed through the notification.
                  in short, I’m unable to get the payload on the notification to flow into the array for use. I’ve determined that it’s not flowing through to an array, based on various tests.
                  Currently, I have this:
                  		if (notification === 'Weather') {
                  			this.storedEvents = JSON.parse(JSON.stringify(payload))
                  			this.updateDom();
                  Could you provide me something better to strip down the JSON into an array?
                  Relevant CommandtoNotification config:
                  						script: "/usr/bin/curl",
                  						args: "-X GET -H 'application/json' http://192.168.0.6:80/v1/current_conditions",
                  						timeout: 5000,
                  						sync: false,
                  						notifications: [
                  							"Weather",
                  Raw data from command:
                  {"data":{"did":"001D0A71573B","ts":1722493593,"conditions":[{"lsid":434637,"data_structure_type":1,"txid":1,"temp": 61.7,"hum":83.1,"dew_point": 56.5,"wet_bulb": 58.3,"heat_index": 62.0,"wind_chill": 61.7,"thw_index": 62.0,"thsw_index":null,"wind_speed_last":0.00,"wind_dir_last":0,"wind_speed_avg_last_1_min":0.00,"wind_dir_scalar_avg_last_1_min":0,"wind_speed_avg_last_2_min":0.00,"wind_dir_scalar_avg_last_2_min":0,"wind_speed_hi_last_2_min":null,"wind_dir_at_hi_speed_last_2_min":null,"wind_speed_avg_last_10_min":0.00,"wind_dir_scalar_avg_last_10_min":226,"wind_speed_hi_last_10_min":1.00,"wind_dir_at_hi_speed_last_10_min":225,"rain_size":1,"rain_rate_last":0,"rain_rate_hi":0,"rainfall_last_15_min":0,"rain_rate_hi_last_15_min":0,"rainfall_last_60_min":0,"rainfall_last_24_hr":0,"rain_storm":0,"rain_storm_start_at":null,"solar_rad":null,"uv_index":null,"rx_state":0,"trans_battery_flag":0,"rainfall_daily":0,"rainfall_monthly":19,"rainfall_year":3902,"rain_storm_last":19,"rain_storm_last_start_at":1722266760,"rain_storm_last_end_at":1722423661},{"lsid":434634,"data_structure_type":4,"temp_in": 82.9,"hum_in":44.5,"dew_point_in": 59.1,"heat_index_in": 82.8},{"lsid":434633,"data_structure_type":3,"bar_sea_level":30.057,"bar_trend": 0.011,"bar_absolute":29.593}]},"error":null}
                  formatted json:
                    "data": {
                      "did": "001D0A71573B",
                      "ts": 1722493593,
                      "conditions": [
                          "lsid": 434637,
                          "data_structure_type": 1,
                          "txid": 1,
                          "temp": 61.7,
                          "hum": 83.1,
                          "dew_point": 56.5,
                          "wet_bulb": 58.3,
                          "heat_index": 62,
                          "wind_chill": 61.7,
                          "thw_index": 62,
                          "thsw_index": null,
                          "wind_speed_last": 0,
                          "wind_dir_last": 0,
                          "wind_speed_avg_last_1_min": 0,
                          "wind_dir_scalar_avg_last_1_min": 0,
                          "wind_speed_avg_last_2_min": 0,
                          "wind_dir_scalar_avg_last_2_min": 0,
                          "wind_speed_hi_last_2_min": null,
                          "wind_dir_at_hi_speed_last_2_min": null,
                          "wind_speed_avg_last_10_min": 0,
                          "wind_dir_scalar_avg_last_10_min": 226,
                          "wind_speed_hi_last_10_min": 1,
                          "wind_dir_at_hi_speed_last_10_min": 225,
                          "rain_size": 1,
                          "rain_rate_last": 0,
                          "rain_rate_hi": 0,
                          "rainfall_last_15_min": 0,
                          "rain_rate_hi_last_15_min": 0,
                          "rainfall_last_60_min": 0,
                          "rainfall_last_24_hr": 0,
                          "rain_storm": 0,
                          "rain_storm_start_at": null,
                          "solar_rad": null,
                          "uv_index": null,
                          "rx_state": 0,
                          "trans_battery_flag": 0,
                          "rainfall_daily": 0,
                          "rainfall_monthly": 19,
                          "rainfall_year": 3902,
                          "rain_storm_last": 19,
                          "rain_storm_last_start_at": 1722266760,
                          "rain_storm_last_end_at": 1722423661
                          "lsid": 434634,
                          "data_structure_type": 4,
                          "temp_in": 82.9,
                          "hum_in": 44.5,
                          "lsid": 434633,
                          "data_structure_type": 3,
                          "bar_sea_level": 30.057,
                          "bar_trend": 0.011,
                          "bar_absolute": 29.593
                    "error": null
                  I already know what the path is to the various array elements (from ValuesByNotification’s config:
                  										valueTitle: "Temperature Outdoors",
                  										valueUnit: "°",
                  										jsonpath: "data.conditions[0].temp",
                  										//valueFormat: "Number(${value}).toFixed(2)",
                  										//classes: "",
                  Should be a path something like this.storedEvents.data.conditions[0].temp
                  Thanks!
                    sdetweil @BKeyport
                    @BKeyport if you use the developers window sources tab, you can put a stop on the line after receivenotification
                    and examine the payload by putting the cursor over the word notification
                    is it a string, or is it an object already
                    your parse(stringify(… ))
                    assumes it is an object already,
                    my guess is curl returned a string
                    • BKeyportB
                      @sdetweil you’re correct. It’s a string. That started fixing it up, just gotta reset a couple of variables I forgot to capture. 😏
                        sdetweil @BKeyport
                        @BKeyport awesome
