    Help restyling MMM-ValuesByNotification
    18 Posts 3 Posters 2.9k Views 3 Watching
      sdetweil @BKeyport
      @BKeyport remember, along the bottom edge of the elements tab view window is the selector style clauses for the selected element
      • BKeyportB Offline
        @sdetweil I’m aware of everything you said, the problem is that I can’t get the CSS to cooperate. I can get 'em all to row, all to column (Default), etc, just not anything else.
        Where I’m weakest is CSS, I have a hard time wrapping my head around it.
        S wishmaster270W 2 Replies Last reply Reply Quote 0
          sdetweil @BKeyport
          @BKeyport ok, it’s not row, column or anything else.
          the stuff before the { is called the selector clause. it selects the elements (document wide) that the stuff inside the braces will be applied to.
          many elements do NOT inherit settings from their parent, much less their grandparent
          I use this cheatsheet to help me remember
          https://www.w3schools.com/cssref/css_selectors.php
          spaces between elements in the selector matter.
          no space means AN element MUST have ALL the attributes. not parent child…
          sometimes for me it is better read right to left.
          styles are selected by the nearest specifier if there are multiples. unless you use the !important override.
          . means class
          # means id
          [] means element  attribute [src...]
          no prefix  means tag name,  table, p, div ..
          • wishmaster270W Offline
            wishmaster270 Module Developer @BKeyport
            @BKeyport
            Hi and sorry for the late reply.
            I am not sure if I will have time to test your case the next days.
            I think your main problem is that you try to use “normal” styling directives for the layout but I use flexbox css as the basic.
            You can find a short tutorial at:
            https://css-tricks.com/snippets/css/a-guide-to-flexbox/
            Edit:
            Had 5 minutes and did a quick check.
            I think the following two statements are a good starting point:
            .MMM-ValuesByNotification .vbn .groupsWrapper {
              flex-direction: row;
            .MMM-ValuesByNotification .vbn .valueWrapper {
            • BKeyportB Offline
              BKeyport Module Developer @wishmaster270
              @wishmaster270 I think the problem I’m having is figuring out where to place the classes to trigger what I want. Flex to me seems a bit erratic with how to set things.
                sdetweil @BKeyport
                @BKeyport said in Help restyling MMM-ValuesByNotification:
                the
                if the class style affects a single element, then the style goes there
                if it affects multiple items, then on their parent
                and then you need to look at the style to see if it can be inherited from an ancestor
                http://web.simmons.edu/~grabiner/comm244/weekfour/css-concepts.html#:~:text=In CSS%2C some styles are,tree while others are not.
                • BKeyportB Offline
                  I’ve officially given up.
                  I can get it to start to look right outside the magicmirror environment, and even with unsetting everything styled within the ValuesByNotification app, I can’t get it to duplicate within Magic Mirror.
                  This is with copying Main.css into a test environment, along with the other modules’ CSS files, and using the output HTML from MagicMirror.
                  Works great in test, but the moment I try to make it go live, it’s doing random things.
                  I hate CSS. I really do.
                    sdetweil @BKeyport
                    @BKeyport can you send me info on what you are trying to do
                    outside and inside
                    same userid at gmail
                      @BKeyport Hi, can you make a screenshot of the things styled outside MagicMirror so we can see how it should look exactly?
                      Maybe you will need some additional classes in your module config to make it possible to select the different elements jn CSS.
                      • BKeyportB Offline
                        So, after some more playing around, I’ve come to the determination that the HTML and class setup isn’t good for my use. As a result, I’ve got most of a new module set up for use, however, I’m having issues breaking down the JSON as processed through the notification.
                        in short, I’m unable to get the payload on the notification to flow into the array for use. I’ve determined that it’s not flowing through to an array, based on various tests.
                        Currently, I have this:
                        		if (notification === 'Weather') {
                        			this.storedEvents = JSON.parse(JSON.stringify(payload))
                        			this.updateDom();
                        Could you provide me something better to strip down the JSON into an array?
                        Relevant CommandtoNotification config:
                        						script: "/usr/bin/curl",
                        						args: "-X GET -H 'application/json' http://192.168.0.6:80/v1/current_conditions",
                        						timeout: 5000,
                        						sync: false,
                        						notifications: [
                        							"Weather",
                        Raw data from command:
                        {"data":{"did":"001D0A71573B","ts":1722493593,"conditions":[{"lsid":434637,"data_structure_type":1,"txid":1,"temp": 61.7,"hum":83.1,"dew_point": 56.5,"wet_bulb": 58.3,"heat_index": 62.0,"wind_chill": 61.7,"thw_index": 62.0,"thsw_index":null,"wind_speed_last":0.00,"wind_dir_last":0,"wind_speed_avg_last_1_min":0.00,"wind_dir_scalar_avg_last_1_min":0,"wind_speed_avg_last_2_min":0.00,"wind_dir_scalar_avg_last_2_min":0,"wind_speed_hi_last_2_min":null,"wind_dir_at_hi_speed_last_2_min":null,"wind_speed_avg_last_10_min":0.00,"wind_dir_scalar_avg_last_10_min":226,"wind_speed_hi_last_10_min":1.00,"wind_dir_at_hi_speed_last_10_min":225,"rain_size":1,"rain_rate_last":0,"rain_rate_hi":0,"rainfall_last_15_min":0,"rain_rate_hi_last_15_min":0,"rainfall_last_60_min":0,"rainfall_last_24_hr":0,"rain_storm":0,"rain_storm_start_at":null,"solar_rad":null,"uv_index":null,"rx_state":0,"trans_battery_flag":0,"rainfall_daily":0,"rainfall_monthly":19,"rainfall_year":3902,"rain_storm_last":19,"rain_storm_last_start_at":1722266760,"rain_storm_last_end_at":1722423661},{"lsid":434634,"data_structure_type":4,"temp_in": 82.9,"hum_in":44.5,"dew_point_in": 59.1,"heat_index_in": 82.8},{"lsid":434633,"data_structure_type":3,"bar_sea_level":30.057,"bar_trend": 0.011,"bar_absolute":29.593}]},"error":null}
                        formatted json:
                          "data": {
                            "did": "001D0A71573B",
                            "ts": 1722493593,
                            "conditions": [
                                "lsid": 434637,
                                "data_structure_type": 1,
                                "txid": 1,
                                "temp": 61.7,
                                "hum": 83.1,
                                "dew_point": 56.5,
                                "wet_bulb": 58.3,
                                "heat_index": 62,
                                "wind_chill": 61.7,
                                "thw_index": 62,
                                "thsw_index": null,
                                "wind_speed_last": 0,
                                "wind_dir_last": 0,
                                "wind_speed_avg_last_1_min": 0,
                                "wind_dir_scalar_avg_last_1_min": 0,
                                "wind_speed_avg_last_2_min": 0,
                                "wind_dir_scalar_avg_last_2_min": 0,
                                "wind_speed_hi_last_2_min": null,
                                "wind_dir_at_hi_speed_last_2_min": null,
                                "wind_speed_avg_last_10_min": 0,
                                "wind_dir_scalar_avg_last_10_min": 226,
                                "wind_speed_hi_last_10_min": 1,
                                "wind_dir_at_hi_speed_last_10_min": 225,
                                "rain_size": 1,
                                "rain_rate_last": 0,
                                "rain_rate_hi": 0,
                                "rainfall_last_15_min": 0,
                                "rain_rate_hi_last_15_min": 0,
                                "rainfall_last_60_min": 0,
                                "rainfall_last_24_hr": 0,
                                "rain_storm": 0,
                                "rain_storm_start_at": null,
                                "solar_rad": null,
                                "uv_index": null,
                                "rx_state": 0,
                                "trans_battery_flag": 0,
                                "rainfall_daily": 0,
                                "rainfall_monthly": 19,
                                "rainfall_year": 3902,
                                "rain_storm_last": 19,
                                "rain_storm_last_start_at": 1722266760,
                                "rain_storm_last_end_at": 1722423661
                                "lsid": 434634,
                                "data_structure_type": 4,
                                "temp_in": 82.9,
                                "hum_in": 44.5,
                                "lsid": 434633,
                                "data_structure_type": 3,
                                "bar_sea_level": 30.057,
                                "bar_trend": 0.011,
                                "bar_absolute": 29.593
                          "error": null
                        I already know what the path is to the various array elements (from ValuesByNotification’s config:
                        										valueTitle: "Temperature Outdoors",
                        										valueUnit: "°",
                        										jsonpath: "data.conditions[0].temp",
                        										//valueFormat: "Number(${value}).toFixed(2)",
                        										//classes: "",
                        Should be a path something like this.storedEvents.data.conditions[0].temp
                        Thanks!
