    Switchbot API access - MMM-CommandtoNotification
    6 Posts 2 Posters 990 Views 2 Watching
    • BKeyportB
      BKeyport Module Developer
      Folks, I’m not understanding the api at https://github.com/OpenWonderLabs/SwitchBotAPI very well - What I’d like to do is use MMM-CommandtoNotification to get the current tempurature and humidity off my switchbot hub 2, so I can display it on my mirror in another room.
      Could someone help me develop the command/code to do so?
      I flat out think it’s beyond my current ability.
      Thanks!
        sdetweil @BKeyport
        @BKeyport easier to write the module and not add another script to process the results
        • BKeyportB
          @sdetweil You might be right - but then again - when you’re already using CommandToNotification for the back end of a module, you might as well continue.
          Even so, the problem still exists - I’m having trouble following the documentation for the API.
            sdetweil @BKeyport
            @BKeyport doesn’t look good for bash/curl usage
              @BKeyport I am away from my dev system, will try to look this week when I return
              • BKeyportB
                @sdetweil Actually, I went around it - found one of my old temp units and wired it up and did a bad thing™ according to the python docs now.
                Same effect, across the room.
