    MagicMirror install on LXC Container as a server will not do
    10 Posts 3 Posters 989 Views 2 Watching
    • kusselinK Offline
      kusselin
      Hello everyone, I would like to install the MagicMirror as a server on a Proxmox LXC container…what have I done so far:
      1.New ConLXC container created
      1. Ubuntu 24 LTS installed
        3.run apt-get update && apt-get upgrade -y
        4.created new user “MM” with useradd -s /bin/bash -m MM
        5.assign password for MM
      2. add the new user to the group “sudo” with sudo usermod -a -G sudo MM
        7.reboot
        8.logged in with MM and pass
        9.then execute the following command:
      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
      10.After installation, the following command is executed:
      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
      11.then entered cd and I am on
      mm@MagicMirror-live:~$
      12.then enter nano mm.sh and insert the following there:
      npm run server
      13.Then make the file executable with
      chmod +r ~/mm.sh
      1. then enter crontab -e and select 1 then enter the last thing at the bottom:
      @reboot /home/pi/mm.sh
      15.then out and reboot made…
      16.to be on the safe side, go to the /MagicMirror directory and run npm run server…then this is what comes out:
      mm@MagicMirror-live:~/MagicMirror$ npm run server
      > magicmirror@2.28.0 server
      > node ./serveronly
      [2024-08-10 16:51:17.974] [LOG]   Starting MagicMirror: v2.28.0
      [2024-08-10 16:51:17.986] [LOG]   Loading config ...
      [2024-08-10 16:51:17.989] [LOG]   config template file not exists, no envsubst
      [2024-08-10 16:51:18.334] [LOG]   Loading module helpers ...
      [2024-08-10 16:51:18.335] [LOG]   No helper found for module: alert.
      [2024-08-10 16:51:18.343] [LOG]   Initializing new module helper ...
      [2024-08-10 16:51:18.344] [LOG]   Module helper loaded: updatenotification
      [2024-08-10 16:51:18.344] [LOG]   No helper found for module: clock.
      [2024-08-10 16:51:18.561] [LOG]   Initializing new module helper ...
      [2024-08-10 16:51:18.563] [LOG]   Module helper loaded: calendar
      [2024-08-10 16:51:18.565] [LOG]   No helper found for module: compliments.
      [2024-08-10 16:51:18.567] [LOG]   No helper found for module: weather.
      [2024-08-10 16:51:18.568] [LOG]   No helper found for module: weather.
      [2024-08-10 16:51:18.717] [LOG]   Initializing new module helper ...
      [2024-08-10 16:51:18.717] [LOG]   Module helper loaded: newsfeed
      [2024-08-10 16:51:18.718] [LOG]   All module helpers loaded.
      [2024-08-10 16:51:18.724] [LOG]   Starting server on port 8080 ...
      [2024-08-10 16:51:18.746] [LOG]   Server started ...
      [2024-08-10 16:51:18.747] [LOG]   Connecting socket for: updatenotification
      [2024-08-10 16:51:18.747] [LOG]   Starting module helper: updatenotification
      [2024-08-10 16:51:18.748] [LOG]   Connecting socket for: calendar
      [2024-08-10 16:51:18.748] [LOG]   Starting node helper for: calendar
      [2024-08-10 16:51:18.748] [LOG]   Connecting socket for: newsfeed
      [2024-08-10 16:51:18.748] [LOG]   Starting node helper for: newsfeed
      [2024-08-10 16:51:18.749] [LOG]   Sockets connected & modules started ...
      [2024-08-10 16:51:18.749] [INFO]
      >>>   Ready to go! Please point your browser to: http://localhost:8080   <<<
      [2024-08-10 16:51:18.871] [INFO]  System information:
      ### SYSTEM:   manufacturer: ; model: ; raspberry: undefined; virtual: false
      ### OS:       platform: linux; distro: Ubuntu; release: 24.04 LTS; arch: x64; kernel: 6.5.13-3-pve
      ### VERSIONS: electron: undefined; used node: 20.9.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2
      ### OTHER:    timeZone: UTC; ELECTRON_ENABLE_GPU: undefined
      ^C[2024-08-10 16:51:29.977] [LOG]   [SIGINT] Received. Shutting down server...
      [2024-08-10 16:51:29.977] [LOG]   Stopping module helper: updatenotification
      [2024-08-10 16:51:29.977] [LOG]   Stopping module helper: calendar
      [2024-08-10 16:51:29.977] [LOG]   Stopping module helper: newsfeed
      [2024-08-10 16:51:29.978] [LOG]   Node_helpers stopped ...
      whats that 😞
      He shuts down the server again… 😞 why ?
      Did I do it wrong again???
      Thanks and greetings
        sdetweil @kusselin
        @kusselin server should run forever til stopped with kill or ctrl-c
        Also you don’t need to run upgrade right after install. Install always does the latest
        kusselinK 1 Reply Last reply Reply Quote 0
        • kusselinK Offline
          kusselin @sdetweil
          @sdetweil hi, And how do I get it so that the server is always running…
          Isn’t npm run server enough?
            sdetweil @kusselin
            @kusselin that should be it
            Says received int signal, like someone did ctrl-c
            • garblefluxG Offline
              garbleflux Project Sponsor
              Hi kusselin,
              use this ready skript from Proxmox VE Helper Scripts - it works like a charme.
              "To create a new MagicMirror Server LXC, run the command below in the Proxmox VE Shell.
              To Update MagicMirror, run the command below (or type update) in the LXC Console.
              bash -c “$(wget -qLO - https://github.com/tteck/Proxmox/raw/main/ct/magicmirror.sh)”
              ⚡ Default Settings: 512MiB RAM - 3GB Storage - 1vCPU ⚡
              MagicMirror Interface: IP:8080
              ⚙️ Configuration
              It’s from this url: https://tteck.github.io/Proxmox/
              kusselinK 2 Replies Last reply Reply Quote 0
              • kusselinK Offline
                kusselin @garbleflux
                @garbleflux hi, thanks a lot fpr your answer…TOP
                • kusselinK Offline
                  @garbleflux said in MagicMirror install on LXC Container as a server will not do:
                  Hi kusselin,
                  ⚙️ Configuration
                  it´s not going…
                  Fehler
                    sdetweil @kusselin
                    @kusselin worked for me
                    • kusselinK Offline
                      kusselin @sdetweil
                      @sdetweil hi…are you conneted as root ?
                        sdetweil @kusselin
                        @kusselin I am on my desktop… not on a container
