    MMM-CalDAV
    97 Posts 10 Posters 57.7k Views 9 Watching
      sdetweil @GregoryWest
      @gregorywest that I do not know
      G 1 Reply Last reply
      • G
        GregoryWest @sdetweil
        @sdetweil I noticed a different issue now. I was updating my calendar in SoGo, but none of the updates are showing up on MMM. This is even the case after a reboot of MMM.
        The problem of the multiple calendars might be a show stopper. Will keep muddling through this.
        Greg
        S M 2 Replies Last reply
          @gregorywest ok, for multiple cals, u use another instance of the module in config.js
          his doc shows that…
          update? should be the updateInterval parm… default 15 mins it says
            MMRIZE @GregoryWest
            Thanks your kind help. I was absent for days. So I couldn’t support this issue.
            @GregoryWest
            When you want to get several calendars(or accounts), just add this module again in your config.
            And to refresh calendar, wait updateInterval.
            And with rebooting, usually last result will be shown after reboot.(CalDAV parsing is quite slow ). Generally it will take updateInterval after reboot, the change will be displayed.
              MMRIZE @GregoryWest
              @gregorywest said in MMM-CalDAV:
              @sdetweil WOW its working!!! Thanks for your patience. Looking good. Something just occured to me. Can I do this with multiple users/calendars? The plan is for 5 calendars to be on the screen, they are all coming from the same SoGo server.
              What you want is;
              • 5 CalDAV calendars from one account (It has more than 5 calendars) as one iCal Calendar : Just use calendarFilter
              • 5 CalDAV calendaras from one account as 5 iCal Calendars: Use this module 5 times with calendarFilter
              • 5 CalDAV calendars from several accounts as one summarized iCal Calendar : Sorry, impossible with this module.
              • 5 CalDav calendars from several accounts as 5 iCal Calendars : Use method 2.
                MMRIZE
                UPDATE 2.0.0
                • Newly rebuilt from scratch
                • OAUTH supported (For Google Calendar)
                • Multi servers/calendars in one module.
                • more secure and efficiently
                Now, you can use Google Calendar in the default calendar module(and more).
                https://github.com/MMRIZE/MMM-CalDAV
                  MMRIZE @Guest
                  @matt216
                  More details about your environment are needed to know what happens.
                  Let’s start with the concept.
                  Some CALDAV Providers don’t serve any public iCAL(.ics) URL to be consumed externally. You don’t need this module if your CALDAV service can host iCAL URLs. I have no idea about baikal, but I think you know whether that service would provide iCAL or not.
                  MMM-CALDAV can access the CALDAV server(which would not host any public iCAL URL) to get target calendar events. Then, this module converts the event data to a real iCAL file(.ics). And this module also hosts that file as a URL accessible from the default calendar module or some iCAL consuming modules with security. MMM-CALDAV will work like a private iCAL provider service.
                  So, to show your event on MM, you may need both MMM-CALDAV and calendar module together.
                  .env file is needed to connect/authenticate CALDAV server and some security features. Calendar events are very private so I want to block the security hole on working this module. You should put .env in MMM-CALDAV directory.
                  So, where are you stuck now? Tell me what happens.
                  M 1 Reply Last reply
                    matt216 @MMRIZE
                    @MMRIZE Thank you for your help, but I managed to figure out getting baikal to generate the ics file, so I don’t need this module anymore.
                    Thanks anyway
                      MMRIZE
                      Update 2.1.0
                      • Birthday calendar enabled. (CardDAV implementation)
                      • Some code refactoring.
                      • calendars: [], is changed to targets: []. you have to reconfigure your config.js
                      Now you can get Birthdays calendar from iCloud or Google Contacts. (Of course, other CardDAV supported contacts services.)
                      T 1 Reply Last reply
                      • T
                        Tiller @MMRIZE
                        @MMRIZE
                        Hello I’m trying to sync my synology calendar to the MagicMirror calendar with the MMM_CalDAV module. Sadly it’s not working and I don’t know why. I tried different settings and everything I could find online.
                        My config.js (without the standard stuff) looks like this:
                          module: "MMM-CalDAV",
                            timeRangeStart: -30,
                            servers: [
                                envPrefix: "SYOLOGY_",
                                serverUrl: "http://192.168.xxx/caldav/",
                                targets: ["family" ],
                            servers: [
                                symbol: "calendar-check",
                                url: "http://localhost:8080/CALDAV/SYNOLOGY_family.ics",
                                auth: {
                                  user: 'username1',
                                  pass: 'password1',
                                  method: 'basic'
                        The .env looks like this:
                        CALDAV_SERVICE_USERNAME=
                        ### For SYNOLOGY
                        SYNOLOGY_username=username1
                        SYNOLOGY_password=password1
                        Do you have any idea what I could try to do, to sync it?
                        Thank you
                        Tillmann
                          sdetweil @Tiller
                          @Tiller can you show any of the output from
                          npm start
                          if using pm2 to autolaunch, then
                          pm2 logs --lines=xxxx
                          xxxx is the number of the most recent lines in the logs, default 15
                          note that the log data will have full urls for calendar , so this could expose info
                            MMRIZE @Tiller
                            @Tiller said in MMM-CalDAV:
                            For SYNOLOGY
                            I think you may have confusing the username and password for the server and the module.
                            This is for your Synology Caldav Server, usually it is your account id/password to login Synology Server (Or Synology calendar account)
                            CALDAV_SERVICE_USERNAME=username2
                            CALDAV_SERVICE_PASSWORD=password2
                            This is a different thing. It is used for your MM calendar module. This module provide a secure calendar ics host by itself with this auth information. You should need to set your calendar config like this;
                            // default calendar module.
                                    url: "http://localhost:8080/CALDAV/SYNOLOGY_Family.ics",
                                    auth: { // REQUIRED
                                      user: 'username2', // <= used here (CALDAV_SERVICE_USERNAME)
                                      pass: 'password2', // <= used here (CALDAV_SERVICE_PASSWORD)
                                      method: 'basic'
                            • T
                              Tiller @MMRIZE
                              Thank you for your quick reply.
                              @sdetweil I’m not using pm2 at the moment, but I could try to do it and check the logs.
                              @MMRIZE sorry, my bad. I changed the password for the post, it’s correct in my .env but not working.
                              I’m not exactly sure about the Synology url
                              synology.com says I should use
                              http://192.168.x.x:5000/caldav
                              and than log in with my username and password
                              But an older link is (seems there was an update)
                              http://192.168.x.x:5000/caldav/username/ejialfjl/
                              If I’m using the last one in the browser, it is downloading an .ics file.
                              But it’s not working with both urls.
                              Maybe I should try to reinstall everything?
                              S M 3 Replies Last reply
                                sdetweil @Tiller
                                @Tiller if you are not using pm2 then the errors would be shown where you do npm start
                                  sdetweil @Tiller
                                  @Tiller no reinstall
                                  can you show us the new url(#2) in config.js,
                                  assume you are still using the env variables
                                    MMRIZE @Tiller
                                    @Tiller
                                    CalDAV is different to general ics hosting.
                                    Usually, the URL of Synology CalDAV accessing would be;
                                    https://IP_OR_URL:5001/caldav/
                                    http://IP_OR_URL:5000/caldav/
                                    Anyway, there would be some log to diagnosis. Can you show the frontend and backend logs?
                                    C T 2 Replies Last reply
                                      caw @MMRIZE
                                      @MMRIZE
                                      i´ve got the same problem. I´m completly new to magicmirror but the integration of my Synology CalDAV should be the main part of it.
                                      i´ve tried several combinations and addresses but no one worked for me.
                                      maybe its possible to get a “step - by - step” Tutorial.
                                      hopefully you can help :)
                                        MMRIZE @caw
                                        @caw
                                        https://github.com/MMRIZE/MMM-CalDAV/wiki
                                        1. Install
                                        cd <Your MagicMirror directory>/modules
                                        git clone https://github.com/MMRIZE/MMM-CalDAV
                                        cd MMM-CalDAV
                                        npm install
                                        1. There would be .env (It would be hidden, so you should check it with ls -al or equivalent for your environment/OS)
                                        If not there, copy it from env.example
                                        cp env.example .env
                                        1. Open your Synology Calendar. You can open it from your Synology Package Center Or installed app lists. Usually it will have http(s)://<IP_OR_URL>:<PORT(5000 or 5001)>/?launchApp=SYNO.Cal.Application as URL so you can open it on the browser.
                                        You will see something like this.
                                        1. Get the CadDAV account. Copy or memo the URL. Usually URL will have http(s)://<IP_OR_URL>:<PORT_5000_OR_5001>/caldav/ format.
                                        1. Back to the terminal. Open the .env file with your favourite editor. Then, fulfil these lines.
                                        2. Then configure the MMM-CalDAV module and the calendar module like this.
                                        Carefully See the configuration of the calendar module.
                                        1. Then run the MagicMirror.
                                          At the very first execution, some time would be needed for CalDAV calendars to be reflected on the screen. So, just stop the MagicMirror.
                                        If CalDAV calendars would be success to be derived, the log will say something like this.
                                        [2024-09-03 22:52:01.461] [LOG]   [CALDAV] File: SYNOLOGY_test.ics is refreshed.
                                        And there be files to be hosted in the service directory like these;
                                        I have two calendars, My Calendar and test, so there would be 2 hidden ics files generated, service/.SYNOLOGY_My_20Calendar.ics and service/.SYNOLOGY_test.ics.
                                        But the real URL consumed by the calendar module would be http://localhost:8080/CALDAV/SYNOLOGY_test.ics, don’t be confused.
                                        1. Rerun the MM again. Now on the screen, your hosting calendar will be served.
                                        C 1 Reply Last reply
                                          caw @MMRIZE
                                          @MMRIZE said in MMM-CalDAV:
                                          Hi thank you very much for the really fast supply.
                                          the strange thing is that i configured it like you said. but if im running it the magicmirror it is showing me that the “Site is not reachable” (The Synology default page)
                                          if im running MM just without the CALDAV Module it´s working.
                                          I´m running the MM in Docker on the Synology.
                                            MMRIZE @caw
                                            @caw could you show me the capture of error message to know what happened?
                                            • 2 / 5
