    Traffic Maps (Any recent users?)
    8 Posts 2 Posters 881 Views 2 Watching
      awwbaker
      Good Morning,
      I am a recent MM builder. I have all the general stuff working along with a call to Home Assistant for presence data as well as getting my iCloud Events listed. Very happy.
      The ONE thing I want most is a local traffic map, like Google has. I have tried the GoogleMapsTraffic and a couple of the TomTom modules. I am sure that I have correctly collected and implemented the required API keys correctly. But have not had success in making either work. I have not yet the experience to do any “real” debugging. I was hoping someone could point me in the direction of a recently used module that provides a traffic map.
      Kindest regards, Anthony
        sdetweil @awwbaker
        @awwbaker what mapping trouble are you having?
        A 1 Reply Last reply Reply Quote 1
          awwbaker @sdetweil
          @sdetweil thank you for the response. I have tried a couple of the TomTom map modules as well as Google Maps. The TomTomTrafficsIncidents module responds with square template and a frown in the upper right corner. Google gives me an “oops” logo. I noted it had been sometime since either module had been updated so wondered if something had changed on the back-end? That is why I was trying to find the latest modules. I am not yet experienced enough to trouble shoot into what the failure is in a particular module, but with the right push gladly jump in as deep as I can go. Thank you again!!! VR Anthony Baker
            sdetweil @awwbaker
            @awwbaker don’t know anything about the tomtom modules.
            there are two places to look for debug info
            in the output of npm start
            if you are using pm2, then
            pm2 logs --lines=xxxx
            where xxxx is tye number of most recent lines to display, default 15
            the second place is in the browser log
            cttl-shift-i, then select the console tab, and put a unique part of the module name in the filter field
              sdetweil @awwbaker
              @awwbaker I put this on my system , and only had one problem
              there is a syntax error in the sample, a missing trailing comma
                          module: 'MMM-GoogleMapsTraffic',
                          position: 'top_right',
                              key: 'my key',
                              lat: 37.8262306,
                              lng: -122.2920096,
                              height: '300px',
                              width: '300px'   // <------  here
                              styledMapType: "transparent",
                              disableDefaultUI: true,
                              backgroundColor: 'hsla(0, 0%, 0%, 0)',
                              markers: [
                                      lat: 37.8262316,
                                      lng: -122.2920196,
                                      fillColor: '#9966ff'
              now, I DID you my fork of this module which fixed a couple problems, since the author has not updated in quite a while… I am still 3 changes up from that code…
              https://github.com/sdetweil/MMM-GoogleMapsTraffic.git
                awwbaker @sdetweil
                Mr @sdetweil,
                Thank you so much your help. Had put the module in the lower right. On your suggestion I saw a warning message for “this module cannot be in that location.” Not an exact quote, but that was the flavor. Moved the module to center bottom and GoogleMap version worked. Really cool, thank you. I too found the comma issue! Do you know the syntax to “update” a module versus installing fresh??? I am going to try the TomTomIncident module and see if that was a similiar issue. If useful I will report out here on findings. Again, thank you for yout time, be safe Anthony
                  sdetweil @awwbaker
                  @awwbaker to update a module that has changes is exactly like for MagicMirror
                  go to the module folder, and enter this command
                  git pull
                  then do
                  ls package.json
                  if you do NOT get an error, then do
                  npm install
                    awwbaker @sdetweil
                    @sdetweil Roger wico will give update a try…btw, installed and tested TomTomIncident module. That one is working too! Thank you! Anthony
