    Trouble Integrating MMM-OpenWeatherMapForecast with OpenWeather API v3.0
    29 Posts 2 Posters 4.8k Views 2 Watching
      Socrates @sdetweil
      So do i need to sign up for a paid API using a credit card? Or do u think there is an inconsistency with my MMM-OWMF module? I have made the changes to the node_helper.js file just as you suggested and restarted MM, still no avail.
        sdetweil @Socrates
        @Socrates i believe the 3.0 free tier also requires a credit card on file…
        they give you 1000 calls no charge per day, but if you go over they charge you
        see the link ‘Pay as you call’
        (vs prevent the api from working)
        this is new for 3.0
        the linked pages says
        'One Call API 3.0 is included to the “One call by call” subscription plan only, users pay for the actual use of the product. '
        if you are using pm2 to autolaunch then the output will be here
        pm2 logs --lines=xxxx
        where xxxx is the number of the most recent lines of the log to display,
        default 15
        you may need more
        I always recommend using manual start mode while debugging, this makes the output easier to access
        pm2 status
        will show the running apps
        pm2 stop all
        will stop them all
        manual start
        npm start
        ctrl-c at the terminal or
        ctrl-q on the mm screen to stop mm
        once things are resolved
        pm2 status
        pm2 start x
        where x is the number of the line for the app to start or the name on that line
        0 or MagicMirror as shown below on one of my systems
        │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
        │ 0  │ MagicMirror        │ fork     │ 5    │ online    │ 0%       │ 2.5mb    │
          sdetweil @Socrates
          @Socrates said in Trouble Integrating MMM-OpenWeatherMapForecast with OpenWeather API v3.0:
          all that change did was output the status code to the log , instead of the empty error
          so, the log output will tell you
          Im sure its 401
          I hacked my apikey , and this is what the line should look like in the log
          [2024-09-09 21:49:07.454] [LOG]   [MMM-OpenWeatherMapForecast] 9-Sep-24 21:49 ** ERROR ** 401
            Socrates
            Sounds good, its getting very late here in Houston, I will check this in the morning, add a credit card on file with OpenWeather and subscribe to a v3.0 api, make the changes accordingly and let u know in the morning. Thanks again for helping me out with this.
              Socrates
              Ok, before i go to sleep i had to do this.
              I added a credit card on openweather and subscribed for the plan.
              created a new api, and added it to the owmf module config file.
              restarted mm, and navigated to the log file, and i see this…
              [2024-09-10 00:52:18.498] [LOG] [MMM-OpenWeatherMapForecast] 10-Sep-24 00:52 ** ERROR ** 401
              [2024-09-10 00:52:18.526] [INFO] .
              [2024-09-10 00:52:18.527] [INFO] Beginning of Update Data:
              [2024-09-10 00:52:18.529] [INFO] .
              [2024-09-10 00:52:18.544] [INFO] {
                Socrates @sdetweil
                Sorry to keep nagging you. But today morning when i started troubleshooting MM, i see the Weather title bar show up, but the whole module per say is loading.
                I have the credit card on file with openweather, and have subscribed to v3.0 api
                  sdetweil @Socrates
                  @Socrates can you show the log output?
                    Socrates @sdetweil
                    Thanks, i have pm’ed you the output, as the output file contains api keys and all google calander private url details. Hence sent it to you through pm
                      sdetweil @Socrates
                      @Socrates sent pm back
                        Socrates @sdetweil
                        It looks like i might be facing an issue with the OpenWeather api. Under services tab i see this msg. It looks like Hourly and Daily forcast is still not available to me.
                        My membership services shows. See screenshot below.
                        alt text
                        However my subscription shows its active with the paid membership
                        alt text
                        I have written an email to OpenWeather support, as soon as i hear from them, i will report back. I think this has to do with my subscription and for them to activate the daily forcast on my account.
                          sdetweil @Socrates
                          @Socrates when u need to upload a pic, use the 2nd icon from the right (upload image) on the editor toolbar
                            sdetweil @Socrates
                            @Socrates remember it worked ok from my system
                              Socrates @sdetweil
                              With my API key?
                                sdetweil @Socrates
                                @Socrates yes, i copied your config exactly, and disabled mine…
                                  Socrates @sdetweil
                                    Socrates @sdetweil
                                    Sucks, what do you recommend in this case? Uninstall/delete OWMF module and any css folders relating to it, and reinstall it completely?
                                      Socrates @sdetweil
                                      Other than deleting the module folder what other components relating to OWMF can i delete? Also, is there a way to uninstall instead of deleting, so any dependent package that was installed with OWMF can be removed?
                                        sdetweil @Socrates
                                        @Socrates delete the module folder and reinstall the module . don’t need to edit the config
                                          Socrates @sdetweil
                                          Hello and good evening again. The issue has been resolved. Even after reinstalling the module it did not work. Then i thought about something i would have done years back as a Linux System admin if a rpm package was not able to find depedencies already installed, i went and granted chmod -R 777 * to the MMM-OWMF folder, thus giving it recursive permission to read write and execute to self and guest users. After that i restarted and now I can see the module in my dashboard.
                                          Thank you so much for standing with me since yesterday and helping me out with this issue. This has been a great learning curve.
                                          Thanks again!!!
                                          S S 2 Replies Last reply Reply Quote 0
                                            sdetweil @Socrates
                                            @Socrates BUT BUT BUT that sounds like you installed the module using sudo…
                                            NEVER use sudo with any MagicMirror commands , regardless what anyone says, no reason to do that…
                                            use of sudo leads to troubles like this
