    Trouble Integrating MMM-OpenWeatherMapForecast with OpenWeather API v3.0
    29 Posts 2 Posters 5.1k Views 2 Watching
      sdetweil @Socrates
      @Socrates ok, edit the node_helper.js
      and change the end of line 63 from
       HH:mm") + " ** ERROR ** " + error);
      to
       HH:mm") + " ** ERROR ** " + response .statusCode);
      then restart MagicMirror and look at the output of npm start
      im guessing its 401, access denied
      is your new apikey with a credit card?
        Socrates @sdetweil
        Also wanted to let you know I am using one openweather api for a different module in mm and thats working fine, only this module its not working, the module wont even show up on mm screen.
          sdetweil @Socrates
          @Socrates I took your config, used my v3 apikey and it works…
            Socrates @sdetweil
            hello and good evening again. No i do not have a credit card on file with Openweathermap. Its a free tier.
            Also, may i request you to guide me where to find the output file? I have mm on auto start while rebooting
              Socrates @sdetweil
              So do i need to sign up for a paid API using a credit card? Or do u think there is an inconsistency with my MMM-OWMF module? I have made the changes to the node_helper.js file just as you suggested and restarted MM, still no avail.
                sdetweil @Socrates
                @Socrates i believe the 3.0 free tier also requires a credit card on file…
                they give you 1000 calls no charge per day, but if you go over they charge you
                see the link ‘Pay as you call’
                (vs prevent the api from working)
                this is new for 3.0
                the linked pages says
                'One Call API 3.0 is included to the “One call by call” subscription plan only, users pay for the actual use of the product. '
                if you are using pm2 to autolaunch then the output will be here
                pm2 logs --lines=xxxx
                where xxxx is the number of the most recent lines of the log to display,
                default 15
                you may need more
                I always recommend using manual start mode while debugging, this makes the output easier to access
                pm2 status
                will show the running apps
                pm2 stop all
                will stop them all
                manual start
                npm start
                ctrl-c at the terminal or
                ctrl-q on the mm screen to stop mm
                once things are resolved
                pm2 status
                pm2 start x
                where x is the number of the line for the app to start or the name on that line
                0 or MagicMirror as shown below on one of my systems
                │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                │ 0  │ MagicMirror        │ fork     │ 5    │ online    │ 0%       │ 2.5mb    │
                  sdetweil @Socrates
                  @Socrates said in Trouble Integrating MMM-OpenWeatherMapForecast with OpenWeather API v3.0:
                  all that change did was output the status code to the log , instead of the empty error
                  so, the log output will tell you
                  Im sure its 401
                  I hacked my apikey , and this is what the line should look like in the log
                  [2024-09-09 21:49:07.454] [LOG]   [MMM-OpenWeatherMapForecast] 9-Sep-24 21:49 ** ERROR ** 401
                    Socrates
                    Sounds good, its getting very late here in Houston, I will check this in the morning, add a credit card on file with OpenWeather and subscribe to a v3.0 api, make the changes accordingly and let u know in the morning. Thanks again for helping me out with this.
                      Socrates
                      Ok, before i go to sleep i had to do this.
                      I added a credit card on openweather and subscribed for the plan.
                      created a new api, and added it to the owmf module config file.
                      restarted mm, and navigated to the log file, and i see this…
                      [2024-09-10 00:52:18.498] [LOG] [MMM-OpenWeatherMapForecast] 10-Sep-24 00:52 ** ERROR ** 401
                      [2024-09-10 00:52:18.526] [INFO] .
                      [2024-09-10 00:52:18.527] [INFO] Beginning of Update Data:
                      [2024-09-10 00:52:18.529] [INFO] .
                      [2024-09-10 00:52:18.544] [INFO] {
                        Socrates @sdetweil
                        Sorry to keep nagging you. But today morning when i started troubleshooting MM, i see the Weather title bar show up, but the whole module per say is loading.
                        I have the credit card on file with openweather, and have subscribed to v3.0 api
                          sdetweil @Socrates
                          @Socrates can you show the log output?
                            Socrates @sdetweil
                            Thanks, i have pm’ed you the output, as the output file contains api keys and all google calander private url details. Hence sent it to you through pm
                              sdetweil @Socrates
                              @Socrates sent pm back
                                Socrates @sdetweil
                                It looks like i might be facing an issue with the OpenWeather api. Under services tab i see this msg. It looks like Hourly and Daily forcast is still not available to me.
                                My membership services shows. See screenshot below.
                                alt text
                                However my subscription shows its active with the paid membership
                                alt text
                                I have written an email to OpenWeather support, as soon as i hear from them, i will report back. I think this has to do with my subscription and for them to activate the daily forcast on my account.
                                S 2 Replies Last reply
                                  sdetweil @Socrates
                                  @Socrates when u need to upload a pic, use the 2nd icon from the right (upload image) on the editor toolbar
                                    sdetweil @Socrates
                                    @Socrates remember it worked ok from my system
                                      Socrates @sdetweil
                                      With my API key?
                                        sdetweil @Socrates
                                        @Socrates yes, i copied your config exactly, and disabled mine…
                                          Socrates @sdetweil
                                            Socrates @sdetweil
                                            Sucks, what do you recommend in this case? Uninstall/delete OWMF module and any css folders relating to it, and reinstall it completely?
