    Trouble Integrating MMM-OpenWeatherMapForecast with OpenWeather API v3.0
    29 Posts 2 Posters 5.1k Views 2 Watching
      Socrates @sdetweil
      Sorry to keep nagging you. But today morning when i started troubleshooting MM, i see the Weather title bar show up, but the whole module per say is loading.
      I have the credit card on file with openweather, and have subscribed to v3.0 api
        sdetweil @Socrates
        @Socrates can you show the log output?
          Socrates @sdetweil
          Thanks, i have pm’ed you the output, as the output file contains api keys and all google calander private url details. Hence sent it to you through pm
            sdetweil @Socrates
            @Socrates sent pm back
              Socrates @sdetweil
              It looks like i might be facing an issue with the OpenWeather api. Under services tab i see this msg. It looks like Hourly and Daily forcast is still not available to me.
              My membership services shows. See screenshot below.
              alt text
              However my subscription shows its active with the paid membership
              alt text
              I have written an email to OpenWeather support, as soon as i hear from them, i will report back. I think this has to do with my subscription and for them to activate the daily forcast on my account.
              S 2 Replies Last reply
                sdetweil @Socrates
                @Socrates when u need to upload a pic, use the 2nd icon from the right (upload image) on the editor toolbar
                  sdetweil @Socrates
                  @Socrates remember it worked ok from my system
                    Socrates @sdetweil
                    With my API key?
                      sdetweil @Socrates
                      @Socrates yes, i copied your config exactly, and disabled mine…
                        Socrates @sdetweil
                          Socrates @sdetweil
                          Sucks, what do you recommend in this case? Uninstall/delete OWMF module and any css folders relating to it, and reinstall it completely?
                            Socrates @sdetweil
                            Other than deleting the module folder what other components relating to OWMF can i delete? Also, is there a way to uninstall instead of deleting, so any dependent package that was installed with OWMF can be removed?
                              sdetweil @Socrates
                              @Socrates delete the module folder and reinstall the module . don’t need to edit the config
                                Socrates @sdetweil
                                Hello and good evening again. The issue has been resolved. Even after reinstalling the module it did not work. Then i thought about something i would have done years back as a Linux System admin if a rpm package was not able to find depedencies already installed, i went and granted chmod -R 777 * to the MMM-OWMF folder, thus giving it recursive permission to read write and execute to self and guest users. After that i restarted and now I can see the module in my dashboard.
                                Thank you so much for standing with me since yesterday and helping me out with this issue. This has been a great learning curve.
                                Thanks again!!!
                                S S 2 Replies Last reply
                                  sdetweil @Socrates
                                  @Socrates BUT BUT BUT that sounds like you installed the module using sudo…
                                  NEVER use sudo with any MagicMirror commands , regardless what anyone says, no reason to do that…
                                  use of sudo leads to troubles like this
                                    Socrates @Socrates
                                    @Socrates
                                    Ah that makes sense. Yes i did use sudo. You are right. Will follow the guidelines now.
