MagficMirror on debian 12 Dell Wyse 3040 PC
Greetings to all. It is possible to install MagicMirror under these conditions: Debian 12 on Dell Wyse 3040 PC with 2gb of RAM and 16gb ssd. Thank you Eddy
@Eddy4011 sure, use my install script
@Eddy4011 might have to make the swap file bigger
Thank you very much for your answer. what I have to do is after being installed debian12, I have to open the terminal and paste the scrit that you recommend and paste ,them ,MM will be installed is correct??? Sorry for my lack of knowledge
Thanks for your answer!!!
@Eddy4011 paste the one line from my scripts page into a terminal window. on system or ssh or vnc
@sdetweil Thank you I already understood everything, happy day, when I have time, install the MM with your help and let you know. HAVE A HAPPY SUNDAY
Hi the MM has been installed but I have this error Unable to install dependencies! being installed which command I apply to boot the MM. Sorry to bother you, you have already helped me enough, THANK YOUError from the terminal:
Cloning MagicMirror Done!
Installing dependencies …
npm error code ENOSPC
npm error syscall write
npm error errno ENOSPC
npm error nospc Invalid response body while trying to fetch https://registry.npmjs.org/import-fresh: ENOSPC: no space left on device, write
npm error nospc There appears to be insufficient space on your system to finish.
npm error nospc Clear up some disk space and try again.
npm error A complete log of this run can be found in: /home/eddy/.npm/_logs/2024-09-22T15_32_05_299Z-debug-0.log
eddy@debian11:~$ cd MagicMirror
eddy@debian11:~/MagicMirror$ -
@Eddy4011 maybe 16gb too small
i know i have a chromebook 16gb i have to fight
Thank my freind for your gelp!!!
