    Experience with MMM-WebUntis?
    12 Posts 4 Posters 5.1k Views 4 Watching
      rabbit83ka @kai
      @kai I used it until last year, then this issue occured. Maybe check your logs with
      pm2 logs MagicMirror --lines=500
      to see if you have the same issue.
      karsten13K 1 Reply Last reply
      • karsten13K
        karsten13 @rabbit83ka
        the package.json contains "webuntis": "latest" so it will always install the latest version of this dependency.
        I suspect that there were breaking changes within some versions, you could try an older version (see https://github.com/SchoolUtils/WebUntis/tags).
        You have to update package.json with e.g. "webuntis": "2.2.1" and execute npm install in the module folder.
        R 1 Reply Last reply
          rabbit83ka @karsten13
          @karsten13 thanks for the hint, I tried several versions, the issue still persists.
          H 1 Reply Last reply
          • H
            HeikoGr @rabbit83ka
            @rabbit83ka I got it working, with a few modifications, so i can use the qr codes from my kids (our school uses MS365 Accounts for login, so unfortunately the username + password didn’t work…). You can find it here: https://github.com/heikogr/MMM-WebUntis wich is forked from https://github.com/r3wald/MMM-Webuntis wich is forked from https://github.com/thyed/MMM-Webuntis
              rabbit83ka @HeikoGr
              @HeikoGr Great, it works again. Thanks for your effort!
                rabbit83ka @rabbit83ka
                @HeikoGr , one addition: until 2023, there was a very compact layout of the module (screenshot still in the readme). Then there was this PR, and the new layout is very space consuming with more then one child/student. Maybe it’s feasible to use both layouts (old and new) by a config switch, but I’m a mechanical engineer, not a programmer… but I could test the modifications.
                H 2 Replies Last reply
                • H
                  HeikoGr @rabbit83ka
                  @rabbit83ka I‘m not a developer either, but i think this is something i could do. But maybe it will take a few days
                  • H
                    HeikoGr @rabbit83ka
                    @rabbit83ka you can try my newest commit (https://github.com/HeikoGr/MMM-Webuntis/). just add a line to your config.js:
                    mode: "compact",
                    R kaiK 2 Replies Last reply
                      rabbit83ka @HeikoGr
                      @HeikoGr Thank you! Works great and saves a lot of space.
                      kaiK 1 Reply Last reply
                      • kaiK
                        kai @HeikoGr
                        @HeikoGr Thank you so much for your effort! It works now, and it’s just great!
                        • kaiK
                          kai @rabbit83ka
                          @rabbit83ka Thank you for getting the ball rolling!
                          Reply Quote 2
