    trouble updating module
    17 Posts 2 Posters 4.9k Views 2 Watching
      pat59
      Good evening after several attempts to update the remote control module it is impossible for it to work the message always appears I tried with the scripts https://github.com/sdetwe![Remote-Control.jpg](/assets/uploads/files/1728491285411-remote-control.jpg) MagicMirror (2).jpg il/MagicMirror_scripts ditto attached the report
        pat59
        I just noticed that I forgot to put Remote control in the module folder. I did the manipulation again, then did a git pull again and npm install, that’s it, it’s back to normal, no more update messages, a big thank you to you for your help. how can I thank you do you have a kitty to make a donation cordially
          sdetweil @pat59
          @pat59 right something editing package.json and modules.json
          can you do
          git diff > somefile.txt
          it will list the changes
          post so i can see
          but most likely we will do on my scripts, do NOT save those files, and the originsls will be restored
          or the brute force way
          git reset  --hard HEAD
            pat59
            patrick@raspberrypi:~ $ git diff >somefile.txt
            warning: Pas un dépôt git. Utilisez --no-index pour comparer deux chemins hors d’un arbre de travail
            usage : git diff --no-index []
              sdetweil @pat59
              @pat59 you must be in the module folder, same as when trying to update
              please
              cd ~/MagicMirror/modules/MMM-RemoteControl
                pat59
                nothing happens attached
                the photo
                THANKS
                  sdetweil @pat59
                  @pat59 yes, the output has been sent to the file somefile.txt
                  please paste its content here
                  in linux the ‘rule’ is, if all is ok, produce no output… this was set when systems were connected over slow phone lines with modems… so no output was better than waiting to read all was good.
                    pat59
                    I copy paste the file and it shows me too many characters.
                    I copy and paste the file and remove txt it tells me invalid file type authorized jpg jpeg png gif what to do?
                      sdetweil @pat59
                      @pat59 put in code block like always
                      paste text with empty line above and below
                      select text just pasted
                      hit the button </> above the messge editor
                      you cannot ‘attach’ files… only pictures…
                      there shouldn’t be that much in the paste output anyhow
                      neither of those files is very big
                        pat59
                        code_text
                        +    "longname": "MMM-Remote-Control-Repository",
                        +    "id": "MMRIZE/MMM-Remote-Control-Repository",
                        +    "url": "https://github.com/MMRIZE/MMM-Remote-Control-Repository",
                        +    "author": "MMRIZE",
                        +    "desc": "Plugin for `MMM-Remote-Control` to update installable modules automatically."
                             "longname": "MMM-Remote-Control",
                             "id": "Jopyth/MMM-Remote-Control",
                        @@ -147,18 +350,39 @@
                             "desc": "Cleanly shutdown (or reboot) your mirror, edit which modules are shown on your mirror and turn your monitor off and on from a simple website, i.e. from your smartphone.
                        -    "longname": "MMM-Remote-Control-Repository",
                        -    "id": "eouia/MMM-Remote-Control-Repository",
                        -    "url": "https://github.com/eouia/MMM-Remote-Control-Repository",
                        -    "author": "eouia",
                        -    "desc": "Plugin for `MMM-Remote-Control` to update installable modules automatically."
                        +    "longname": "MM-Remote",
                        +    "id": "Klettner/MM-Remote",
                        +    "url": "https://github.com/Klettner/MM-Remote",
                        +    "author": "Klettner",
                        +    "desc": "Android 📱 and Windows-desktop 💻 app to control your MagicMirror² remotely. (Shutdown, reboot, toggle monitor on/off, change brightness of monitor, custom-commands, etc.)."
                          sdetweil @pat59
                          @pat59 weird
                          in the module folder do
                          this will restore all changed files back to the repo level
                          then your module update process should work
