    trouble updating module
    17 Posts 2 Posters 5.1k Views 2 Watching
      sdetweil @pat59
      @pat59 yes, the output has been sent to the file somefile.txt
      please paste its content here
      in linux the ‘rule’ is, if all is ok, produce no output… this was set when systems were connected over slow phone lines with modems… so no output was better than waiting to read all was good.
        pat59
        I copy paste the file and it shows me too many characters.
        I copy and paste the file and remove txt it tells me invalid file type authorized jpg jpeg png gif what to do?
          sdetweil @pat59
          @pat59 put in code block like always
          paste text with empty line above and below
          select text just pasted
          hit the button </> above the messge editor
          you cannot ‘attach’ files… only pictures…
          there shouldn’t be that much in the paste output anyhow
          neither of those files is very big
            pat59
            code_text
            +    "longname": "MMM-Remote-Control-Repository",
            +    "id": "MMRIZE/MMM-Remote-Control-Repository",
            +    "url": "https://github.com/MMRIZE/MMM-Remote-Control-Repository",
            +    "author": "MMRIZE",
            +    "desc": "Plugin for `MMM-Remote-Control` to update installable modules automatically."
                 "longname": "MMM-Remote-Control",
                 "id": "Jopyth/MMM-Remote-Control",
            @@ -147,18 +350,39 @@
                 "desc": "Cleanly shutdown (or reboot) your mirror, edit which modules are shown on your mirror and turn your monitor off and on from a simple website, i.e. from your smartphone.
            -    "longname": "MMM-Remote-Control-Repository",
            -    "id": "eouia/MMM-Remote-Control-Repository",
            -    "url": "https://github.com/eouia/MMM-Remote-Control-Repository",
            -    "author": "eouia",
            -    "desc": "Plugin for `MMM-Remote-Control` to update installable modules automatically."
            +    "longname": "MM-Remote",
            +    "id": "Klettner/MM-Remote",
            +    "url": "https://github.com/Klettner/MM-Remote",
            +    "author": "Klettner",
            +    "desc": "Android 📱 and Windows-desktop 💻 app to control your MagicMirror² remotely. (Shutdown, reboot, toggle monitor on/off, change brightness of monitor, custom-commands, etc.)."
              sdetweil @pat59
              @pat59 weird
              in the module folder do
              git reset  --hard HEAD
              this will restore all changed files back to the repo level
              then your module update process should work
                pat59
                always the update message that appears
                  pat59
                    sdetweil @pat59
                    @pat59 no, in the folder of the module you are having trouble updating
                    MMM-RemoteControl
                    as you are having trouble with one module, all the commands would be relative to that module’s folder… right??
                      pat59
                      Sorry I don’t understand your question I’m a newbie
                        pat59
                        I just noticed that I forgot to put Remote control in the module folder. I did the manipulation again, then did a git pull again and npm install, that’s it, it’s back to normal, no more update messages, a big thank you to you for your help. how can I thank you do you have a kitty to make a donation cordially
