    MagicMirror With Face Recognition
    22 Posts 9 Posters 12.3k Views 9 Watching
      monark @sdetweil
      @sdetweil my cmd error
      pip install face-recognition numpy dlib picamera2 opencv-python
      Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
      Collecting face-recognition
        Downloading https://www.piwheels.org/simple/face-recognition/face_recognition-1.3.0-py2.py3-none-any.whl (15 kB)
      Requirement already satisfied: numpy in /usr/lib/python3/dist-packages (1.19.5)
      Collecting dlib
        Downloading https://www.piwheels.org/simple/dlib/dlib-19.24.6-cp39-cp39-linux_armv7l.whl (3.4 MB)
           |################################| 3.4 MB 1.3 MB/s
      Requirement already satisfied: picamera2 in /usr/lib/python3/dist-packages (0.3.12)
      Collecting opencv-python
        Downloading opencv-python-4.10.0.84.tar.gz (95.1 MB)
           |################################| 95.1 MB 59 kB/s
        Installing build dependencies ... done
        Getting requirements to build wheel ... done
          Preparing wheel metadata ... done
      Requirement already satisfied: Pillow in /usr/lib/python3/dist-packages (from face-recognition) (8.1.2)
      Collecting face-recognition-models>=0.3.0
        Downloading https://www.piwheels.org/simple/face-recognition-models/face_recognition_models-0.3.0-py2.py3-none-any.whl (100.6 MB)
           |################################| 100.6 MB 83 kB/s
      Requirement already satisfied: Click>=6.0 in /usr/lib/python3/dist-packages (from face-recognition) (7.1.2)
      Requirement already satisfied: v4l2-python3 in /usr/lib/python3/dist-packages (from picamera2) (0.3.2)
      Building wheels for collected packages: opencv-python
        Building wheel for opencv-python (PEP 517) ... error
        ERROR: Command errored out with exit status 1:
         command: /usr/bin/python3 /tmp/tmpxl4fq1u5_in_process.py build_wheel /tmp/tmpdgg843yi
             cwd: /tmp/pip-install-681jn0xe/opencv-python_e610009f30624d9ea2b1e3ef82a9824f
        Complete output (11 lines):
        patching file opencv/3rdparty/openexr/IlmImf/ImfSystemSpecific.cpp
        /tmp/pip-build-env-im9uh8sr/overlay/lib/python3.9/site-packages/cmake/data/bin/cmake: error while loading shared libraries: libssl.so.3: cannot open shared object file: No such file or directory
          File "/tmp/pip-build-env-im9uh8sr/overlay/lib/python3.9/site-packages/skbuild/setuptools_wrap.py", line 639, in setup
            cmkr = cmaker.CMaker(cmake_executable)
          File "/tmp/pip-build-env-im9uh8sr/overlay/lib/python3.9/site-packages/skbuild/cmaker.py", line 145, in __init__
            self.cmake_version = get_cmake_version(self.cmake_executable)
          File "/tmp/pip-build-env-im9uh8sr/overlay/lib/python3.9/site-packages/skbuild/cmaker.py", line 102, in get_cmake_version
            raise SKBuildError(msg) from err
        Problem with the CMake installation, aborting build. CMake executable is /tmp/pip-build-env-im9uh8sr/overlay/lib/python3.9/site-packages/cmake/data/bin/cmake
        ERROR: Failed building wheel for opencv-python
      Failed to build opencv-python
      ERROR: Could not build wheels for opencv-python which use PEP 517 and cannot be installed directly
        monark @sdetweil
        @sdetweil maybe the problem is i have libcamera-still (rpi4, bulleye, 32bit, camera v3)
          sdetweil @monark
          M 2 Replies Last reply
            monark @sdetweil
            @sdetweil it’s strange because I’ve updated everything
              monark @sdetweil
              @sdetweil i try with sudo apt install libssl.so.3 but not working “impossible find the packet”
                sdetweil @monark
                @monark google search
                  sdetweil @monark
                  @monark the collection of dependencies is not complete, don’t know where it got dropped
                  M 1 Reply Last reply
                    monark @sdetweil
                    @sdetweil change to opencv-python from opencv-python-headless…
                    I’m try to find with google but it seems they are talking about something else (SSL). anyway you recommended me to use this form because it explained how to install and it was easier…
                      sdetweil @monark
                      @monark said in MagicMirror With Face Recognition:
                      and it was easier
                      I didn’t say perfect… opencv setup is a pain in the rear
                      • T
                        toxeek
                        That mirror looks huge, what did you use as display to place behind the mirror? A huge monitor/tv?
                          chris1971
                          Which weather module do you use? Could it be used for Germany?
