    Call for testers, updated calendar module
    6 Posts 2 Posters 793 Views 4 Watching
      like you I am tired of all the troubles we have with the calendar module,
      so lets end that here. we’ve got time between now and Jan 1 to find and fix any remaining issues.
      I have (I think) finally fixed it , this is built on top of the cal module in the current release 2.29.
      to get my fork into a DIFFERENT folder, not touching existing MM (I use newmm here as the new folder name, use whatever you like
      git clone https://github.com/sdetweil/MagicMirror newmm
      cd newmm
      git checkout fixcaldates2
      npm run install-mm
      cd config
      cp config.js.sample config.js
      cd ..
      edit the config.js and add your appropriate url in place of the default calendar we supply
      add whatever config settings are appropriate for your calendar, date/time formats, etc
      then
      npm start
      DST/STD change is coming this weekend for Europe, and next weekend for the US
      let me know what you see…
      you can open issue on my fork, add a ics for the events you find that you have trouble with
      if you want to run under this new MM… you can copy your whole config over and
      the modules folder too…
      you can use my backup/restore to do that too…(save time and energy)
      https://github.com/sdetweil/MagicMirror-backup-restore
      backup from MagicMirror (-s MagicMirror)
      restore to newmm (-s newmm) it will reinstall the modules
        sdetweil @evroom
        @evroom bug with
        showsEndOnlyWithDuration, new code suggestion posted in other topic
        i will open an issue and add this to the fix list (and two testcases)
        • evroomE Offline
          evroom @sdetweil
          Repeating all day event with X occurrences shows end time of 23:59.
          urgency: 0,
          timeFormat: "absolute",
          dateFormat: "dddd MMM D - HH:mm",
          dateEndFormat: "HH:mm",
          fullDayEventDateFormat: "dddd MMM D",
          showEnd: true,
          showEndsOnlyWithDuration: true,
          getRelative: 0,
          BEGIN:VEVENT
          DTSTART;VALUE=DATE:20241104
          DTEND;VALUE=DATE:20241107
          DTSTAMP:20241023T164753Z
          UID:086ujg156a8n9t0dpg8h3g4ptu@google.com
          CREATED:20241023T164710Z
          LAST-MODIFIED:20241023T164710Z
          SEQUENCE:0
          STATUS:CONFIRMED
          SUMMARY:TestCal: ALLDAY_REPEAT_FROM_TO
          TRANSP:TRANSPARENT
          END:VEVENT
          BEGIN:VEVENT
          DTSTART;VALUE=DATE:20241111
          DTEND;VALUE=DATE:20241112
          RRULE:FREQ=DAILY;COUNT=3
          UID:0c9ah6plfonal1s1250k2mmgbt@google.com
          CREATED:20241023T164743Z
          LAST-MODIFIED:20241023T164743Z
          SEQUENCE:0
          STATUS:CONFIRMED
          SUMMARY:TestCal: ALLDAY_REPEAT_3_OCCURENCES
          TRANSP:TRANSPARENT
          END:VEVENT
          (cannot upload a text file anymore, only images)
          Changed:
          dateEndFormat: "dddd MMM D - HH:mm",
          Changed:
          showEnd: false,
          MagicMirror version: 2.33.0
          Test environment:
          MagicMirror version: v2.33.0
            sdetweil @evroom
            @evroom yes, you are working the end time issue on the other topic
            • evroomE Offline
              evroom @sdetweil
              Just to follow up on the test I did where I got the end date displayed according to ‘dateEndFormat’ for a repeating allday event.
              Most of it is also covered in the other thread.
              It is working with your suggested change in calendar.js.
              No need to set ‘showEnd: false’.
              urgency: 0,
              showEnd: true,
              getRelative: 0,
              Test environment:
                sdetweil @evroom
                @evroom bug with
                • evroomE Offline
                  evroom @sdetweil
                  Will follow up in the “Cant use showEnd icloud cal” topic then.
                  Test environment:
