    MMM-GoogleAssistant Gateway big update = big error = big trouble = ):
    9 Posts 4 Posters 1.1k Views 4 Watching
      sillen @sdetweil
      @sdetweil ok, I tried your upgrading script but never with force option. Will try after school. But when I tried the script yesterday it seemed extremely fast but that just might be your coding skills at play lol. I come back with this after school
        sillen @Kazzer
        @Kazzer but it’s seems very unfamiliar when you enter this website. Can’t find where to view or make posts
        • bugsounetB Offline
          bugsounet Banned @Kazzer
          Hi, Gateway is not needed since 1 year 1/2 now.
          Can you read againNew wiki of MMM-GoogleAssistant v7.x ?
          Happy use,
          @bugsounet
            sillen @sdetweil
            @sdetweil I tried with the option force but I still get authentication error when it comes to Gateway module. And also now because the script was forced too cancel my script it also removed electron. It didn’t let me download electron again with npm install electron so I used sudo even tho I wasn’t supposed to. And that’s gave me a whole bunch more errors:
            mm
            A JavaScript error occurred in the main process
            Uncaught Exception:
            0 mm
            on has a valid
            0 mm
            Error: Cannot find module '/home/pi/MagicMirror/node_modules/finalhandler/node_modules/debug/src/index.js'. Please verify that the package.js
            "main" entry
            mm
            at tryPackage (node: internal/modules/cjs/loader:494:19)
            mm
            at Module. _findPath (node:internal/modules/cjs/loader: 778:18)
            at Module._resolveFilename (node: internal/modules/cjs/loader: 1218:27) at s._resolveFilename (node: electron/js2c/browser_init:2:120689)
            mm
            mm
            mm
            mm
            0 mm mm mm mm
            0 mm
            0mm
            0 mm mm
            at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
            at Module. _load (node: internal/modules/cjs/loader: 1058:27)
            at c._load (node: electron/js2c/node_init: 2:16955)
            at Module.require (node: internal/modules/cjs/loader:1318:19)
            at require (node: internal/modules/helpers:179:18)
            at Object. <anonymous> (/home/pi/MagicMirror/node_modules/finalhandler/index.js:14:13)
            at Module._compile (node: internal/modules/cjs/loader: 1484:14) at Module._
            _extensions..js (node: internal/modules/cjs/loader: 1564:10)
            at Module. load (node:internal/modules/cjs/loader:1295:32) at Module._load (node: internal/modules/cjs/loader: 1111:12)
            What should I do too completely reinstall magic mirror again but keep my config and modules the same. Preferably also reinstall google assistant.
              sdetweil @sillen
              @sillen note the author posted that the gateway component is no longer used
                sillen
                Hey evryone I fixed the problem with alot of reinstalling and then removing the gateway module
                • S sillen has marked this topic as solved on
