    MMM-Calendar showing multi day event with start day not current day
    15 Posts 2 Posters 2.8k Views 2 Watching
      sdetweil @bergmannfrank
      @bergmannfrank if you use the parm to split multiday
        bergmannfrank @sdetweil
        @sdetweil Thanks, but I don’t want to split multiday events. The list of events gets spammed with a bunch of entries.
        Or is it possible to show only the actual split entry and hide the other ones in the future?
          @bergmannfrank you can try showOngoing:true
          check the spelling
            @sdetweil There is a “hideOngoing”-option, which is default false. I can’t see how this effects sliced multiday events. In my config I didn’t change the parameter.
            Seems this bug in older versions was a great feature to me. ;) And now it’s fixed and I don’t like it.
            Thanks for your ideas.
              @bergmannfrank set the option to true
              false and split false means we show start and only start
              showEnd: true means we show start AND END on the same event (timeformat : "absolute:)
              split means we show 1 of, 2 of, 3 of on the current and forward days
              showOngoing(default true)/hideOngoing:(default false) means we show an in progress event going TODAY
              ONLY for timeFormat: “relative” (ends in xxx days/hours)
              calendar has lots of options for lots of peoples needs, set what you need
                @sdetweil Sorry, but there is no showOngoing in the docs, only a hideOngoing. This parameter is default false - and I don’t want to change it because it effects all kinds of events.
                And as I mentioned, I don’t like to get my calendar which has a lot of multidays event spammed with a bunch of entries.
                I appreciate your help. It seems the config options don’t fit my special needs at this point.
                  @bergmannfrank how did you update? wipe sd and start new, or use my upgrade script to upgrade MM??
                  if my script,
                  can you look at the ~/MagicMirror/installers/upgrade.log file
                  go to the end and search backwards for
                  upgrading from version
                  I want to know which version you were last running. .
                  I just checked this release, next in flight, and with my cal fixes, all show event start date for a multi-day event which is currently running… in timeFormat:“absolute”
                    @sdetweil My old installation crushed and I started with a fresh SD card and a different Pi than before.
                    I don’t remember the version but it must be a least four-ish years old. My last backup was in November 2020.
                      @bergmannfrank ok, we are at 2.29, - 16 (4 years, 4 releases) makes it about 2.13
                      I’ll try to look later
                        @sdetweil Thanks again!
                        May be this helps in your search:
                        https://github.com/MagicMirrorOrg/MagicMirror/pull/2895
                        https://github.com/MagicMirrorOrg/MagicMirror/issues/2685
                        S 3 Replies Last reply Reply Quote 0
