    MMM-Calendar showing multi day event with start day not current day
    15 Posts 2 Posters 2.8k Views 2 Watching
      sdetweil @bergmannfrank
      @bergmannfrank set the option to true
      false and split false means we show start and only start
      showEnd: true means we show start AND END on the same event (timeformat : "absolute:)
      split means we show 1 of, 2 of, 3 of on the current and forward days
      showOngoing(default true)/hideOngoing:(default false) means we show an in progress event going TODAY
      ONLY for timeFormat: “relative” (ends in xxx days/hours)
      calendar has lots of options for lots of peoples needs, set what you need
        bergmannfrank @sdetweil
        @sdetweil Sorry, but there is no showOngoing in the docs, only a hideOngoing. This parameter is default false - and I don’t want to change it because it effects all kinds of events.
        And as I mentioned, I don’t like to get my calendar which has a lot of multidays event spammed with a bunch of entries.
        I appreciate your help. It seems the config options don’t fit my special needs at this point.
          @bergmannfrank how did you update? wipe sd and start new, or use my upgrade script to upgrade MM??
          if my script,
          can you look at the ~/MagicMirror/installers/upgrade.log file
          go to the end and search backwards for
          upgrading from version
          I want to know which version you were last running. .
          I just checked this release, next in flight, and with my cal fixes, all show event start date for a multi-day event which is currently running… in timeFormat:“absolute”
            @sdetweil My old installation crushed and I started with a fresh SD card and a different Pi than before.
            I don’t remember the version but it must be a least four-ish years old. My last backup was in November 2020.
              @bergmannfrank ok, we are at 2.29, - 16 (4 years, 4 releases) makes it about 2.13
              I’ll try to look later
                @sdetweil Thanks again!
                May be this helps in your search:
                https://github.com/MagicMirrorOrg/MagicMirror/pull/2895
                https://github.com/MagicMirrorOrg/MagicMirror/issues/2685
                S 3 Replies Last reply Reply Quote 0
                  @bergmannfrank does help… that code section has changed…
                  I am working on cal fixes for next release… let me look at what needs to be done
                    @bergmannfrank ok, lets try my test cal fixes
                    git fetch origin pull/3587/head:withfixes
                    git checkout withfixes
                    npm install
                    then run MagicMirror
                    let me know
                      @bergmannfrank
                      Any chance you can test this?
                        @bergmannfrank can you test this?
