    MMM-CalendarExt3 24hr time
    6 Posts 2 Posters 944 Views 2 Watching
      siujd2001
      I’m having some difficulty getting the module to show 24hr time instead of 12. Raspberry Pi 4 set to 24 hour time, and config.js is set with locale: “en-US” and timeformat: 24. Other modules show 24hr time, but Google calendar doesn’t. When viewing calendar.google.com, 24hr time is shown.
      Any insights?
        siujd2001 @sdetweil
        Thank you.
        I used the following in the Ext3 section and it seemed to work:
        locale: “en-GB”,
        eventTimeOptions: {timeStyle: ‘short’},
          sdetweil @siujd2001
          @siujd2001 can you show the ext3 config?
            siujd2001 @sdetweil
            I also have MMM-Config installed if that makes a difference.
            /* Config Sample
             * see https://docs.magicmirror.builders/configuration/introduction.html
             * and https://docs.magicmirror.builders/modules/configuration.html
             * You can use environment variables using a `config.js.template` file instead of `config.js`
             * which will be converted to `config.js` while starting. For more information
             * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
            let config = {
            	address: "localhost",	// Address to listen on, can be:
            	port: 8080,
            	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
            	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
            	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
            	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
            	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
            	language: "en",
            	locale: "en-US",
            	timeFormat: 24,
            	units: "metric",
            			module: "alert",
            			module: "updatenotification",
            			position: "top_bar"
            			module: "clock",
            			position: "top_left"
            			module: 'MMM-2Day-NOAA-Forecast',
            			position: 'top_right',
            			  lat: LAT,
            			  lon: LONG,
            			  units: 'imperial',
            			  fontSize: '32px',
            			  interval: 10 * 60 * 1000
            			module: "MMM-OnThisDayWikiApi",
            			position: "top_center", // All available positions // <= this works in landscape
            //			position: "middle_left",  // trying for vertical mode
            			config: {  // See below for configurable options, this is optional
            			  reloadInterval: 10000
            			module: "calendar", /* default/calendar module configuration */
            //			position: "top_left",
                			  broadcastPastEvents: true, // <= IMPORTANT to see past events
                    		      url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
                    		      name: "us_holiday", // <= RECOMMENDED to assign name
                    		      color: "orange" // <= RECOMMENDED to assign color
            			      url: "CALENDAR",
                                          color: "purple"
            			module: "MMM-CalendarExt3",
            //			position: "bottom_bar",
            			position: "lower_third",  // <= works in landscape mode
            //			position: "upper_third",  // trying for vertical mode
            			title: "",
            			  mode: "month",
            			  instanceId: "basicCalendar",
            			  locale: 'en-US',
            			  maxEventLines: 5,
            			  firstDayOfWeek: 0,
            			  calendarSet: ['us_holiday', 'CALENDAR'],
            			  eventTransformer: (event) => {
            			    if (event.title.search("STB") > -1) event.color = "blue";
            			    else if (event.title.search("St. B") > -1) event.color = "blue";
            			    else if (event.title.search("FMCHS") > -1) event.color = "green";
            			    else if (event.title.search("B-Day") > -1) event.color = "red";
            //			    else if (event.description.search("Birthday") > -1) event.color = "red";
            //			    else if (event.getDescription()?.toLowerCase().includes("birthday")) event.setColor(CalendarApp.EventColor.red);
            			    return event;
            			module: "MMM-Dad-Jokes",
            			position: "top_center",  // <= this works in landscape mode
            //			position: "middle_right",  // <= trying for vertical mode
            //			color: "red",
            			  updateInterval: 15000
            			module: 'MMM-Pir',
              			position: 'top_left',
                			  debug: false,
                			  Display: {
            //     			    timeout: 2 * 60 * 1000,
            			    timeout: 60 * 1000,
                  			    animate: true,
            //     			    style: 1,
            			    stile: 2,
                  			    colorFrom: "#FF0000",
                  			    colorTo: "#00FF00",
            //     			    mode: 1,
            			    mode: 2,
                  			    counter: true,
                  			    lastPresence: true,
                  			    lastPresenceTimeFormat: "LL H:mm",
            			    availability: false,
            //     			    availability: true,
                  			    autoDimmer: false,
                  		 	    xrandrForceRotation: "normal",
                  			    wrandrForceRotation: "normal",
                  			    wrandrForceMode: null,
                  			    waylandDisplayName: "wayland-0",
                  			    relayGPIOPin: 0
                			Pir: {
                  			  mode: 0,
            //     			  gpio: 21
            			  gpio: 4
                			Motion: {
                  			  deviceId: 0,
                  			  captureIntervalTime: 1000,
                  			  scoreThreshold: 100
                			Cron: {
                  			  ON: [],
                  			  OFF: []
                			Touch: {
                  			mode: 3
                			Governor: {
                  			  sleeping: 4,
                  			  working: 2
                			Sounds: {
                  			  on: "open.mp3",
                  			  off: "close.mp3"
              sdetweil @siujd2001
              @siujd2001 you need to set the eventTimeOptions in ext3
                siujd2001 @sdetweil
                Thank you.
                locale: “en-GB”,
                  sdetweil @siujd2001
                  @siujd2001 awesome
