    Installation Error
    6 Posts 2 Posters 961 Views 2 Watching
    • V Offline
      vandam3b
      Hi, I am trying to install MagicMirror again last time I used was about a year ago. Cleared my Sd card and reinstalled everything. I used sdetweil install instructions but received the following error. Any help is appreciated. Thank you
      npm error code EBADENGINE
      npm error engine Unsupported engine
      npm error engine Not compatible with your version of node/npm: magicmirror@2.29.0
      npm error notsup Not compatible with your version of node/npm: magicmirror@2.29.0
      npm error notsup Required: {“node”:“>=20.9.0 <21 || 22”}
      npm error notsup Actual: {“npm”:“10.9.0”,“node”:“v23.2.0”}
      npm error A complete log of this run can be found in: /home/vandam3b/.npm/_logs/2024-11-21T02_25_53_357Z-debug-0.log
      Unable to install dependencies!
      Here is the log info:
      install starting - Wed Nov 20 21:12:35 EST 2024
      installing on aarch64 processor system
      the os is PRETTY_NAME=“Debian GNU/Linux 12 (bookworm)” NAME=“Debian GNU/Linux” VERSION_ID=“12” VERSION=“12 (bookworm)” VERSION_CODENAME=bookworm ID=debian HOME_URL=“https://www.debian.org/” SUPPORT_URL=“https://www.debian.org/support” BUG_REPORT_URL=“https://bugs.debian.org/”
      total used free shared buff/cache available
      Mem: 907 523 111 21 354 383
      Swap: 511 305 206
      Updating packages …
      Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 https://deb.nodesource.com/node_23.x nodistro InRelease Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease Reading package lists…
      apt-get update completed ok
      Building dependency tree…
      Reading state information…
      Suggested packages:
      doc-base
      The following NEW packages will be installed:
      pv
      0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
      Need to get 58.6 kB of archives.
      After this operation, 146 kB of additional disk space will be used.
      Get:1 http://deb.debian.org/debian bookworm/main arm64 pv arm64 1.6.20-1 [58.6 kB]
      Fetched 58.6 kB in 0s (552 kB/s)
      Selecting previously unselected package pv.
      (Reading database …
      (Reading database … 5%
      (Reading database … 10%
      (Reading database … 15%
      (Reading database … 20%
      (Reading database … 25%
      (Reading database … 30%
      (Reading database … 35%
      (Reading database … 40%
      (Reading database … 45%
      (Reading database … 50%
      (Reading database … 55%
      (Reading database … 60%
      (Reading database … 65%
      (Reading database … 70%
      (Reading database … 75%
      (Reading database … 80%
      (Reading database … 85%
      (Reading database … 90%
      (Reading database … 95%
      (Reading database … 100%
      (Reading database … 134502 files and directories currently installed.)
      Preparing to unpack …/archives/pv_1.6.20-1_arm64.deb …
      Unpacking pv (1.6.20-1) …
      Setting up pv (1.6.20-1) …
      Processing triggers for man-db (2.11.2-2) …
      apt-get upgrade started
      apt-get upgrade result =rc=0 Reading package lists…
      Calculating upgrade…
      Installing helper tools …
      curl is already the newest version (7.88.1-10+deb12u8).
      wget is already the newest version (1.21.3-1+b1).
      wget set to manually installed.
      git is already the newest version (1:2.39.5-0+deb12u1).
      build-essential is already the newest version (12.9).
      unzip is already the newest version (6.0-28).
      (node:4088) ExperimentalWarning: CommonJS module /usr/lib/node_modules/npm/node_modules/debug/src/node.js is loading ES Module /usr/lib/node_modules/npm/node_modules/supports-color/index.js using require().
      Support for loading ES Module in require() is an experimental feature and might change at any time
      (Use node --trace-warnings ... to show where the warning was created)
      added 1 package in 5s
      installing on bookworm
      Cloning MagicMirror …
      Cloning MagicMirror Done!
      Installing dependencies …
      install starting - Wed Nov 20 21:22:19 EST 2024
      Mem: 907 508 161 15 317 398
      Swap: 511 350 161
      Updating packages …
      pv is already the newest version (1.6.20-1).
      It seems like MagicMirror is already installed.
      To prevent overwriting, the installer will be aborted.
      Please rename the ~/MagicMirror folder and try again.
      install starting - Wed Nov 20 21:25:12 EST 2024
      Mem: 907 509 31 8 436 398
      Swap: 511 337 174
      Updating packages …
        sdetweil @vandam3b
        @vandam3b said in Installation Error:
        yes, we support Node 20.9+ and node 22… not node 21
        the doc says check the release notes for the official versions
        next release will support node 23
        you can hack it… edit the package.json and change the engines from || 22 to || 23
        maybe it will run ok… did for me during some tests
        if you had used the automated install, it would have installed node 20.9
        • V Offline
          vandam3b @sdetweil
          @sdetweil Thank you for getting back to me. I will delete MM folder and do automated install. Where would I find those directions? Thank you
            sdetweil @vandam3b
            @vandam3b you have to start over with a new sd card flash
            the (my) scripts don’t uninstall an existing node, just install or upgrade a downlevel
            the doc links to my scripts… 1st alternative
            anyhow see
            the documentation is linked above in the header
            • V Offline
              vandam3b @sdetweil
              @sdetweil I will do that. Thank you very much.
              • V Offline
                vandam3b @vandam3b
                @vandam3b Thank you very much, it worked.
