    custom.css ......body???
    42 Posts 3 Posters 9.9k Views 3 Watching
      piki
      I don’t understand
        sdetweil @piki
        @piki you can set the language for MagicMirror in config.js
          var config = {
            address: "0.0.0.0",
             port: 8090,
            basePath: "/",
            language: "en",     <----- here
            serverOnly: "local",
            locale: "en-US",   <--- and here
            modules: [   <---- after here is module configuration
          piki
          so I have it now…the clock shows me in “sk” language but the weather in “en”…???
          language: "sk",
          locale: "sk-SK",
          timeFormat: 24,
          units: "metric",
          		module: "clock",
          		position: "bottom_left"
          		module: "weather",
          		position: "bottom_right",
          			weatherProvider: "openmeteo",
          			type: "current",
          			lat: 48.7164,
          			lon: 21.2611,
          			units: "metric",
          			showForecast: true,
          			forecastLayout: "horizontal",
          			showSun: true,
          			lang: "sk",
            sdetweil @piki
            @piki right… there are two problems
            1. it should follow the system config - but doesn’t
            2. user should be able to override that - but can’t
              piki
              is it not possible?
                sdetweil @piki
                @piki today, no
                  piki
                  I changed the bold font in main.css, but in the clock it only changed the date and day to bold, the clock itself remained thin… where could the problem be?
                    sdetweil @piki
                    @piki need more CSS work… every little element needs style… most do NOT inherit from their parent, or their particular thing doesn’t have the same style in effect…
                      piki
                      Can I find the specific clock element somewhere or do I have to write it down?
                      S R 2 Replies Last reply Reply Quote 0
                        sdetweil @piki
                        @piki sorry, I don’t know… I use the developers window when I need to fiddle with css
                          raf @piki
                          @piki
                          .clock .time {
                          font-size: 150px;
                          color: yellow;
                          .clock .date {
                          font-size: 40px;
                          color: red;
                          • 3 / 3
