    custom.css ......body???
    42 Posts 3 Posters 11.5k Views 3 Watching
      sdetweil @piki
      @piki you can set the language for MagicMirror in config.js
        var config = {
          address: "0.0.0.0",
           port: 8090,
          basePath: "/",
          language: "en",     <----- here
          serverOnly: "local",
          locale: "en-US",   <--- and here
          modules: [   <---- after here is module configuration
        piki
        so I have it now…the clock shows me in “sk” language but the weather in “en”…???
        language: "sk",
        locale: "sk-SK",
        timeFormat: 24,
        units: "metric",
        		module: "clock",
        		position: "bottom_left"
        		module: "weather",
        		position: "bottom_right",
        			weatherProvider: "openmeteo",
        			type: "current",
        			lat: 48.7164,
        			lon: 21.2611,
        			units: "metric",
        			showForecast: true,
        			forecastLayout: "horizontal",
        			showSun: true,
        			lang: "sk",
          sdetweil @piki
          @piki right… there are two problems
          1. it should follow the system config - but doesn’t
          2. user should be able to override that - but can’t
            piki
            is it not possible?
              sdetweil @piki
              @piki today, no
                piki
                I changed the bold font in main.css, but in the clock it only changed the date and day to bold, the clock itself remained thin… where could the problem be?
                  sdetweil @piki
                  @piki need more CSS work… every little element needs style… most do NOT inherit from their parent, or their particular thing doesn’t have the same style in effect…
                    piki
                    Can I find the specific clock element somewhere or do I have to write it down?
                    S R 2 Replies Last reply
                      sdetweil @piki
                      @piki sorry, I don’t know… I use the developers window when I need to fiddle with css
                        raf @piki
                        @piki
                        .clock .time {
                        font-size: 150px;
                        color: yellow;
                        .clock .date {
                        font-size: 40px;
                        color: red;
                        • 3 / 3
