    Cannot get MMM-EmbedURL to show any sites
    14 Posts 3 Posters 2.3k Views 3 Watching
      sdetweil @wishmaster270
      @wishmaster270 said in Cannot get MMM-EmbedURL to show any sites:
      Are you sure you set the security settings of electron?
      no… I viewed that as optional if doing webview…(electron javascript content) but I am viewing an html page. (altho hosted by MM)
      If do use the build in electron browser to view the mirror you can use Webview instead
      my config
        module: "MMM-EmbedURL",
        header: "Embed-URL",
          updateInterval: 120,
          attributes: [
              "frameborder=0",
          embed: [
              "http://localhost:8090/modules/MMM-Config/review/",
              "https://cnn.com"
      • U Offline
        unaccomplished @sdetweil
        @sdetweil said in Cannot get MMM-EmbedURL to show any sites:
        @unaccomplished can you look at the messages where you start MagicMirror
        pm2 logs --lines=50
        It seems this is the most relevant error in the log:
        /home/MagicMirrorPi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
        Here are my error logs:
        /home/MagicMirrorPi/.pm2/logs/MagicMirror-error.log last 50 lines:
        0|MagicMir | [2100:1204/174503.791282:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2100:1204/174503.791659:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2100:1204/174503.791914:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2100:1204/174503.792304:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2100:1204/174503.792571:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2100:1204/174503.794953:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2100:1204/174503.795270:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2100:1204/174503.797663:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2100:1204/174503.799569:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2100:1204/174503.801781:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2100:1204/174503.805922:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2100:1204/174503.809880:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2100:1204/174503.810094:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2100:1204/174503.810464:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2100:1204/174503.810645:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2100:1204/174503.810893:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2100:1204/174503.811059:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2100:1204/174503.811276:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2100:1204/174503.811427:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | /home/MagicMirrorPi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
        0|MagicMir | [2024-12-04 17:52:52.959] [WARN]  No /home/MagicMirrorPi/MagicMirror/js/../modules/WallberryTheme/WB-clock/WallberryTheme/WB-clock.js found for module: WB-clock.
        0|MagicMir | [2024-12-04 17:52:52.966] [WARN]  No /home/MagicMirrorPi/MagicMirror/js/../modules/WallberryTheme/WB-weather/WallberryTheme/WB-weather.js found for module: WB-weather.
        0|MagicMir | [2061:1204/175303.171404:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.171830:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.172059:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.173512:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.173776:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.173859:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.174003:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.174110:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.174246:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.174329:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.174452:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.174522:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.174643:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.174716:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.175789:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.177938:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.178289:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.178399:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.178547:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.178626:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.182442:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.183828:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.184097:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.184177:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.184326:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.184401:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.184533:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMir | [2061:1204/175303.184607:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        The two wrapper errors and the two Wallberry warnings have been perpetual, but don’t seem to affect anything. If you have any insight on these, I’d appreciate it.
        I also noted this from the out-put log:
        0|MagicMir | ### OTHER:    timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
        0|MagicMir | [2024-12-04 17:53:26.965] [LOG]   Electron's cache successfully cleared.
        and later in the same log:
        0|MagicMir | [2024-12-04 17:53:34.199] [INFO]  Checking git for module: MMM-EmbedURL
        0|MagicMir | [2024-12-04 17:53:34.289] [LOG]   resizing done!
        I don’t think these are errors, at least not in the context provided.
        • U Offline
          unaccomplished @wishmaster270
          @unaccomplished
          just tried your config in my setup and everything worked as expected.
          The question is…where are the differences in your and mine setup.
          As a first try you can replace embedElementType: "webview," with embedElementType: "iframe,".
          If the embeded pages does not block embedding iframe should work and you do not weaken any security settings of the electron browser.
          Additionally you can replace "frameborder=0", with "frameborder=1",. You should see two boxes at least then. Even if the sites could not be embedded.
          @sdetweil Are you sure you set the security settings of electron? Without them electron will not support webview and will not display anything.
          I updated the config as requested, once without, and then with “iframe”.
                                 position: "upper_third",
                                         embedElementType: "iframe",
                                         attributes: [
                                                 "frameborder=1",
                                         embed: [
                                                 "http://10.0.0.51:50081/ui3.htm?t=live&cam=Doorbell&maximize=1",
                                                 "https://www.youtube.com/embed/dIHr96KqfDI",
          Without switching to iframe, the frameborder made no difference. Now with iframe, I have two blank boxes appearing.
          S U 2 Replies Last reply Reply Quote 0
            sdetweil @unaccomplished
            @unaccomplished I agree, not the errors I was seeing…
            so @wishmaster270 will have to help more
              @unaccomplished your code markers MUST start in column 1.
              U 1 Reply Last reply Reply Quote 0
              • U Offline
                Sorry, is it a formatting error in my comments, or in my config file?
                  @wishmaster270 Mine was a user error
                  I had MMM-Pages enabled, and EmbedURL was not on any page… oops…
                  the MM page embedded and cnn did not…
                  • U Offline
                    unaccomplished @unaccomplished
                    @wishmaster270
                    Just went back in and realized these were commented out in my config.
                    ignoreXOriginHeader: true,
                    ignoreContentSecurityPolicy: true,
                    I added them back in, and success! Now to find a way to config the page to not need a login, but its huge progress. Thanks!
                      @unaccomplished its where the cursor is when you click the </> button
                      must be on the start of the line
                      U 1 Reply Last reply Reply Quote 1
                      • U Offline
                        Got it. Thank you for your continued help!
