    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
      czabel @MMRIZE
      @MMRIZE
      I probably don’t understand enough about how this system works to help much, but isn’t every calendar entry a separate event, which is why the eventTransformer works to change the individual icons? How is it that this icon spills over into the Legend entry, and not just the specific calendar entries?
      In any case, what about adding a new config option to hideLegendIcons that forcibly removes the CSS tag, or something like that?
        MMRIZE @czabel
        @czabel
        You can simply append this code to your css/custom.css
        .CX3 .legend.useSymbol .symbol {
          display: none;
        • G
          gonzonia
          Recently I noticed my Calendars disappear after a few hours. I’m not sure when it started. If I VNC into my mirror and refresh or restart the mirror they come back only to stop appearing a few hours later. I see no errors in the log.
          I’m using
          MMM-CalendarExt3 and MMM-CalendarExt3Agenda in conjunction with MMM-Scenes, the instances that are only on specific scenes are the ones that disappear. I have another instance of MMM-CalendarExt3Agenda that is on all the scenes and that one seems to stay, so I’m wondering if it’s an MMM-Scenes issue.
          Edit: I’m also using MMM-Pir. I’m wondering if that might be doing something.
            sdetweil @gonzonia
            @gonzonia mmm-pir is supposed to put the mirror to sleep if there is no movement
            And Scenes make logical pages. Like MMM-pages, or carousel
            So you have multiple things making content hide
            • G
              gonzonia @sdetweil
              @sdetweil I know. It used to all work great. I don’t think Scenes has updated in a while.
              MMM-CalendarExt3 and MMM-pir have both had updates though.
              To clarify, when I say disappear, I mean that they are no longer on the screen.Not just that the data is empty. The headers, dates, etc. All not visible. I’ve just restarted recently, I’ll try to look at the page source next time it happens.
              G S 2 Replies Last reply Reply Quote 0
              • G
                gonzonia @gonzonia
                Also, I’m using the xrandr mode for mmm-pir since I’m in Raspbian 11 and when I use dpms it doesn’t wake the screen for some reason.
                  sdetweil @gonzonia
                  @gonzonia when a module is hidden , nothing shows
                    Ragged4310
                    My wife takes appointments for her business, so she has a lot of events each day she works. I want to be able to merge back-to-back events and show the start time of the first event and the end time of the last event to reduce the number of entries on the calendar.
                    Ideally, I would like something that could account for gaps between appointments as well since she will still be at work. Ie) I can set the transformer to combine all events that are <= 2 hours apart, and it will show me the start time of the first event and the end time of the last event. I know it’s asking for a lot, and it’s probably not even possible, but I wanted to ask.
                      MMRIZE @Ragged4310
                      @Ragged4310
                      Could you show me the example of the events?
                        Ragged4310 @MMRIZE
                        @MMRIZE said in MMM-CalendarExt3:
                        @Ragged4310
                        alt text
                        I would like to consolidate the events with the little yellow massage person if its possible since she is gone for the whole time and it hogs up the event space. I tried using chatgpt and perplexity, but everytime they gave me something the calendar would not load.
                        For Dec 11 she has 3 appointments back to back, instead of it taking up 3 lines I would prefer if I could get it to show 2:00PM - 7:00PM for one event.
                        For Dec 23, she currently only has 2 appointments and there’s a small gap. Since the gap is < 2 hours I would like if I could consolidate that as well so it would show 10:00AM - 2:00PM.
                        I don’t know the event transformer too well, so I’m not sure if it can handle something like that.
                        Edit- Another thing I thought of… if it is possible to merge…
                        Is there a way to store how many events were merged? I’ll use the Dec 11 for the example again. If I can merge all 3 events into one, could I have it stored in a variable where I can display (3) at the end of the event to indicate there were 3 events?
                          MMRIZE @Ragged4310
                          @Ragged4310
                          Now I c. I’ll try, wait a little.
                            MMRIZE @Ragged4310
                            @Ragged4310
                            Instead of eventTransformer, we’ll use eventPayload because, this conversion should be applied to whole events, not a single event.
                            Insert this property into your config section of CX3 in config/config.js
                            /* `MMM-CalendarExt3` config section in config/config.js */
                            eventPayload: (payload) => {
                            	const fulldays = payload.filter(ev => ev.fullDayEvent === true)
                            	const singleEvents = payload.filter(ev => ev.fullDayEvent === false).sort((a, b) => a.startDate - b.startDate || a.endDate - b.endDate)
                            	const EventsArranged = singleEvents.reduce((acc, ev) => {
                            		const dateObj = new Date(+ev.startDate)
                            		const key = `${ev.title}-${new Date(dateObj).toLocaleDateString('en-CA')}`
                            		if (!acc.has(key)) {
                            			acc.set(key, [ev])
                            		} else {
                            			acc.get(key).push(ev)
                            		return acc
                            	}, new Map())
                            	const collapsed = Array.from(EventsArranged.entries()).map(([ key, value ]) => {
                            		const newEvent = { ...value[ 0 ] }
                            		if (value.length > 1) {
                            			newEvent.title = newEvent.title + ` <sub class="collapsed">${value.length}</sub>`
                            			newEvent.endDate = Math.max(...value.map(ev => ev.endDate))
                            			newEvent.startDate = Math.min(...value.map(ev => ev.startDate))
                            		return newEvent
                            	return [ ...fulldays, ...collapsed ]
                            And to beautify, add some CSS code into css/custom.css
                            /* css/custom.css */
                            .CX3 .title sub::after,
                            #CX3_POPOVER .title sub::after {
                              content: "]";
                            .CX3 .title sub::before,
                            #CX3_POPOVER .title sub::before {
                              content: "[";
                            It will work like;
                            BEFORE
                            AFTER
                            • This code will not affect the fullday events.
                            • Not considered every aspect, like inter-day events or untested errors.
                              Ragged4310 @MMRIZE
                              @MMRIZE Thanks for the reply! I haven’t had too much time to play around with it just yet. Would I be completely replacing the event transformer with the payload, or would I be using both? If I’m using both, does the order matter?
                              I currently use the transformer to set the icons and transform the title. Does your code only account for stuff that has the same name? With my wife’s schedule, her bookings are all something like this:
                              Jane Doe: 60 - Deep Tissue Massage
                              Jane Doe: 60 - Reflexology
                              Break
                              Jane Doe: 30 - Reiki
                              etc., but I transform it to hide her client’s names on our calendar since it’s visible to whoever is in the house.
                                      eventTransformer: (ev) => {
                                        const formatTime = (date) => new Intl.DateTimeFormat("en-US", {
                                          hour: "numeric",
                                          minute: "numeric",
                                          hour12: true,
                                        }).format(new Date(date));
                                        const startTime = formatTime(ev.startDate);
                                        const endTime = formatTime(ev.endDate);
                                        if (!ev.originalTitle) {
                                          ev.originalTitle = ev.title;
                                        const titleParts = ev.originalTitle.split(":");
                                        const eventTitle = titleParts.length > 1 ? titleParts[1].trim() : ev.originalTitle;
                                        // Set default icon
                                        ev.symbol = ["fluent:vehicle-car-profile-ltr-clock-16-filled"];
                                        // Check if the event is not an all-day event
                                        if (!ev.isFullday) {
                                          ev.title = `${startTime} ${eventTitle}`;
                                        } else {
                                          ev.title = eventTitle;
                                        // Rest of your existing conditions
                                        if (ev.originalTitle.toLowerCase().includes('work')) {
                                          ev.symbol = ["material-symbols:work-history-outline-sharp"];
                                          ev.title = `${startTime} - ${endTime}`;
                                        if (ev.calendarName === "Family" && ev.originalTitle.toLowerCase().includes('windcreek')) {
                                          ev.symbol = ["mdi:casino"];
                                        if (ev.calendarName === "Family" && ev.originalTitle.toLowerCase().includes('board')) {
                                          ev.symbol = ["mdi:cards-playing-spade-multiple"];
                                        if (ev.calendarName === "Abigail") {
                                          if (ev.originalTitle.match(/kung fu|tai chi/i)) {
                                            ev.symbol = ["icon-park-solid:kungfu"];
                                          } else if (ev.originalTitle.match(/massage|reiki|trade|break|reflexology|deep|initial visit/i)) {
                                            ev.symbol = ["tabler:massage"];
                                        } else if (ev.calendarName === "Sebastian") {
                                        } else if (ev.calendarName == "Birthday") {
                                          ev.symbol = ["mingcute:cake-fill"];
                                        } else if (ev.calendarName == "Appointment") {
                                          ev.symbol = ["lsicon:work-order-appointment-outline"];
                                        } else if (ev.calendarName == "Holiday") {
                                          ev.symbol = ["openmoji:flag-us-outlying-islands"];
                                        return ev;
                              Instead of checking the title directly, could I use some a contains check to see if it contains the character ‘:’ or ‘-’? I’ll be playing around with this tomorrow once I have some free time available.
                              • G
                                gonzonia @sdetweil
                                @sdetweil Just to close the loop on this. I updated MMM-Pir (there was another update soon after I posted) and switched to the updated MMM-Scenes2 and everything seems stable now.
                                  sdetweil @gonzonia
                                  @gonzonia awesome
                                    MMRIZE @Ragged4310
                                    @Ragged4310
                                    According to the conditions you provided, the previous code cannot be used. Clear definition of the conditions is essential to come up with an appropriate solution.
                                    First, we need to clearly define the events that need to be collapsed. Based on your description, it seems they are in the form of “Person’s Name - Task.” Are you looking to group them by “Person’s Name”? However, it also seems that you do not want the “Person’s Name” to be exposed. In that case, how should they be displayed? For example, would you like them to be labeled sequentially as “Reservation 1,” “Reservation 2,” and so on?
                                    Please provide more details about the AS-IS and TO-BE states.
                                    Alternatively, assigning additional properties to the events to be grouped might also be a good approach. For instance, you could write the person’s name (e.g., Jane Doe) in the location or description field, and only include the task (e.g., Deep Tissue Massage) in the event title. Then, you could group events with the same description together.
                                      Ragged4310 @MMRIZE
                                      @Ragged4310
                                      AS IS:
                                      My Google Calendar currently looks like the examples below. I transform event names containing keywords related to my wife’s services into a format that shows only the start and end time of each service, along with a small icon indicating it’s related to her work (massage therapy) on CX3.
                                      Example Events:
                                      Jane Smith: 60 - Custom Massage
                                      Event Time: 12:30pm - 2:00pm
                                      Description: Name of service / client’s phone number / client’s email
                                      John Doe: 90 - Custom Massage
                                      Event Time: 2:00pm - 4:00pm
                                      Mike Example: 120 - Deep Tissue Massage
                                      Event Time: 4:00pm - 6:30pm
                                      Johnny Smith: 30 - Deep Tissue Massage
                                      Event Time: 10:00pm - 10:30pm
                                      TO BE:
                                      I’d prefer if the title in CX3 could show the time range of merged events only, along with the colored icon I’ve assigned for keywords (e.g., massage, reiki, trade, break, etc.) using ev.originalTitle.match.
                                      Example Output:
                                      12:30pm - 6:30pm [3]
                                      10:00pm - 10:30pm
                                      The 12:30 represents the start of the first service, and 6:30 represents the end of the last service. The [3] indicates the total number of collapsed events.
                                      The final event, 10:00pm - 10:30pm, would ideally remain separate due to the large gap. However, if separating it is too complex, it’s fine to merge all events into one block.
                                      The only consistent attribute across these events is the location. All events are synced from her booking software into her Google Calendar.
                                      I cannot group by Person’s Name because each client appears only once per day (I realize I could have used different names for clarity in the examples).
                                      I understand this request may be complex, and if a solution isn’t feasible, I can continue with my current setup. However, it would be great to have this functionality implemented as described.
                                      S M 3 Replies Last reply Reply Quote 0
                                        sdetweil @Ragged4310
                                        @Ragged4310 said in MMM-CalendarExt3:
                                        its just code, if you can do it in your head, then code can do it…
                                          MMRIZE @Ragged4310
                                          @Ragged4310
                                          Sure, that’s doable. There’s no reason why it shouldn’t be possible.
                                          This kind of work is domain analysis, which is basically my real-world job.
                                          However, it’s not exactly simple. By simple, I mean it’ll take more than the usual 10 minutes I’d spend diving into this hobby project that genuinely interests me.
                                          And honestly, my rate is quite high. :D (Just kidding.)
                                          Let’s clarify a few things first.
                                          • CX3 is usually useful for viewing events from multiple calendars at once, so you’re probably using other types of calendars (e.g., personal meetings, family schedules) together. For this task, let’s assume that the target “customer reservation” events are in a separate, independent calendar. For convenience, I’ll call this calendar “Reservation” from now on.
                                          • Given the nature of calendars, I assume that there won’t be any overlapping events in the Reservation calendar. Additionally, I’ll assume there are no full-day events or events that span midnight.
                                          With these assumptions, I’ll give it a shot sometime tomorrow when I have some free time. I can’t make any promises, so please don’t get your hopes up too high.
                                            MMRIZE @Ragged4310
                                            @Ragged4310
                                            See the green events
                                            eventPayload in CX3 config;
                                            /* CX3 config section in `config/config.js` */
                                            	const targetCalendar = "Reservation"
                                            	const divideGap = 1000 * 60 * 60 * 1
                                            	const locale = 'en-US'
                                            	const timeStyle = { timeStyle: 'short' }
                                            	const condition = (ev) => { return (ev.calendarName === targetCalendar && ev.fullDayEvent === false) }
                                            	const target = payload.filter(condition).sort((a, b) => a.endDate - b.endDate)
                                            	const result = payload.filter(e => !condition(e))
                                            	const dateStr = (dateValue) => Intl.DateTimeFormat(locale, timeStyle).format(new Date(+dateValue))
                                            	const collapse = (template, ev) => {
                                            		if (!template?.["title"]) template = { ...ev, collapseCount: 0, description: '', location: '' }
                                            		template.collapseCount++
                                            		template.startDate = String(Math.min(+template.startDate, +ev.startDate))
                                            		template.endDate = String(Math.max(+template.endDate, +ev.endDate))
                                            		template.title = `${dateStr(template.startDate)} - ${dateStr(template.endDate)}`
                                            		if (template.collapseCount > 1) template.title += ` <span class="count">${template.collapseCount}</span>`
                                            		template.description += `<div class="collapsedEvent">
                                            			<p class="title">${ev.title}</p>
                                            			<p class="period">${dateStr(ev.startDate)} - ${dateStr(ev.endDate)}</p>`
                                            		if (ev.description) template.description += `<p class="description">${ev.description}</p>`
                                            		if (ev.location) template.description += `<p class="location">${ev.location}</p>`
                                            		template.description += '</div>'
                                            		return template
                                            	const dateKey = (dateValue) => new Date(+dateValue).toLocaleDateString('en-CA')
                                            	let collapsedEvent = {}
                                            	for (const ev of target) {
                                            		const currentKey = dateKey(ev.startDate)
                                            		if (!collapsedEvent?.[ 'title' ]) {
                                            			collapsedEvent = collapse(collapsedEvent, ev)
                                            			continue
                                            		const collapsedKey = dateKey(collapsedEvent.startDate)
                                            		if (collapsedKey !== currentKey || +ev.startDate - +collapsedEvent.endDate > divideGap) {
                                            			result.push(collapsedEvent)
                                            			collapsedEvent = collapse({}, ev)
                                            		} else {
                                            	if (collapsedEvent?.[ 'title' ]) result.push(collapsedEvent)
                                            	return result
                                            You can modify targetCalendar, divideGap, locale ande timeStyle for your purpose.
                                            To beautify;
                                            .CX3 .event.calendar_Reservation .headline .time {
                                              display: none;
                                            #CX3_POPOVER .title .count,
                                            .CX3 .calendar_Reservation .title .count {
                                              font-weight: bold;
                                              color: gray;
                                            #CX3_POPOVER .title .count::before,
                                            .CX3 .calendar_Reservation .title .count::before {
                                              content: "[";
                                            #CX3_POPOVER .title .count::after,
                                            .CX3 .calendar_Reservation .title .count::after {
                                              content: "]";
                                            #CX3_POPOVER .description .collapsedEvent {
                                              line-height: 115%;
                                              border-bottom: 2px solid silver;
                                              p {
                                                margin-top: 0;
                                                margin-bottom: 0;
                                              .title {
                                                font-weight: bold;
                                              .period {
                                                text-align: right;
                                              .description {
                                                font-style: italic;
                                                white-space: pre;
                                                padding-left: 20px;
                                              .location {
                                                font-style: italic;
                                                text-align: right;
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 34
                                            • 35
                                            • 29 / 35
