    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
      MMRIZE @czabel
      @czabel
      	module: "MMM-CalendarExt3",
      	position: "bottom_bar",
      		eventTransformer: (ev) => {
      			if (ev.title.includes("Volleyball")) {
      				ev.symbol = ["fas fa-fw fa-volleyball"]
      			return ev
      Due to most weird format of the default calendar symbol descriptor, you should write something like ["fas fa-volleyball"]
      About the height of the event cell, I think you have modified some CSS or eventHeight property in the config.
        czabel @MMRIZE
        @MMRIZE Thank you for the eventTransformer fix - is there some ruleset I can find for other icons, or just prefix everything with “fas”?
        As for the other, you are right that I have edited the eventHeight, in order to grow the size of the whole calendar. Is there a better way to do this? Perhaps I should be using only the maxEventLines to grow the size of things? Or I guess I could use the CSS to force a minimum height for each .cell. What would you say is the preferred or “correct” method?
        I now have two slightly different issues.
        First, using the custom CSS to fully color-in my partial day events seems to override the icon. I tried commenting out the top selector, but these events still have no icon. Is there a correct way to do this - to have all my events colored in but also have icons?
        Second, I have added a second calendar to see how that all works, but these new events are the same color, and the legend does not differentiate them. I am wondering if it is because my Google account owns both of these calendars, or if you have any other ideas as to why this won’t work? They are separate and distinct .ics URLs.
        Here’s my CX3 config code, with .ics URLs omitted:
        language: "en",
        	locale: "en-US",
        	timeFormat: 24,
        	units: "imperial",
        			module: "MMM-Carousel",
        				mode: "slides",
        				transitionInterval: 0,
        				slideTransitionSpeed: 100,
        				homeSlide: 0,
        				showPageIndicators: true,
        				showPageControls: true,
        				ignoreModules: ["clock", "MMM-AccuWeatherForecastDeluxe"],
        				slides: {
        					main: ["MMM-CalendarExt3"],
        					"Slide 2": ["MMM-CalendarExt3Journal"],
        					"Slide 3": ["calendar"],
        			module: "clock",
        				displayType: "both",
        				secondsColor: "#FF0000"
        				broadcastPastEvents: true,
        						symbol: "calendar-check",
        						url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
        						useSymbol: false,
        						url: "SECRET.ics",
        						color: "orange"
        						useSymbol: false,
        						url: "SECRET.ics",
        						color: "blue"
        			module: "MMM-CalendarExt3Journal",
        			position: "upper_third",
        				height: '30vh',
        				width: '80%',
        				staticWeek: true,
        				staticTime: true,
        				hourLength: 12,
        				beginHour: 8,
        				calendarSet: ['Dad', 'Son'],
        			title: "",
        				height: '40vh',
        				mode: "week",
        				weekIndex: 0,
        				weeksInView: 5,
        				instanceId: "basicCalendar",
        				maxEventLines: 9,
        				fontSize: '20px',
        				firstDayOfWeek: 0,
        				displayLegend: true,
        				useWeather: false,
        				customHeader: true,
        					return ev
        			module: "MMM-AccuWeatherForecastDeluxe",
        			classes: "default everyone",
        				apikey: "SECRET",
        				locationKey: "SECRET",
        				updateInterval: 60,
        				relativeColors: true,
        				hourlyForecastLayout: "table",
        				hourlyForecastInterval: 1,
        				maxHourliesToShow: 9,
        				showDailyForecast: false,
        				iconset: "5c",
        				listenerOnly: true,
        				showCurrentConditions: false,
        				showExtraCurrentConditions: false,
        				showSummary: false,
        				showHourlyForecast: false,
        				showDailyForecast: true,
        				dailyForecastLayout: "table",
        				ignoreToday: true,
        				maxDailiesToShow: 5,
        				iconset: "5c",
        				label_high: "",
        				label_low: "",
        And this is the entirety of my custom.css:
        .CX3 .event.singleday .headline:not(.useSymbol)::before,
        .CX3 .event.singleday .headline.useSymbol .symbol.noSymbol::before {
          display: none;
        .CX3 .event.singleday {
          background-color: var(--calendarColor);
          mix-blend-mode: difference;
          border-radius: 4px;
          color: var(--oppositeColor);
        .CX3 .event:not(.fullday) .headline .time {
        .CX3 .cellContainer .cell:nth-child(1) .cw {
        	display: none;
        Thank you for your time!
        I appreciate the help!
          MMRIZE @czabel
          @czabel said in MMM-CalendarExt3:
          “fa-solid” will work too, instead of “fas”. I think you may did some typo mistake somewhere.
          Generally, eventHeight and maxEventLines could control the height of the view, Anyway you may need additional CSS modification to beautify the view.
          Original
          APPLIED
          		eventHeight: "30px",
          		fontSize: "22px",
          I guess you may also incline fontSize. That property will be applied to all the elements . So all text would be bigger. but not the padding or margin or other attributes of the element. That’s why your view looked so weird. So you have to adjust other things with CSS to harmonize your view.
            czabel @MMRIZE
            @MMRIZE
            Great, thanks. I’ve changed it to use only the maxEventLines and it all looks fine.
            Do you have any insight as to how to change my CSS to get the icons to show up for every event? As I mentioned, my current setup makes my non-fullday events colored in, but this deletes the icon. The icon is still there for the real fullday events. I’d like to keep the icon, if at all possible. Thank you!
            • A
              adamaid
              Hey everyone!
              I’m using a Samsung Frame 32" 2022 to display my MagicMirror page.
              I’m trying to avoid using a Raspberry Pi etc. so just serving MM as a web page from a local server, then using the “Internet” app on the TV UI to view the page.
              This approach works fine for other modules (including MMM-CalendarExt2 and the default Calendar) but not for MMM-CalendarExt3. Instead of showing a calendar it just shows the header (i.e. “October”) and nothing else. I’ve verified that the calendar renders OK on other devices (e.g. iPhone).
              Any ideas on what could be causing this? Unfortunately it isn’t easy to debug as there is no console available on the Internet TV app, and MMM-LogExt just prevents the page from loading at all on the TV.
              Thanks!
              Adam
                sdetweil @adamaid
                @adamaid MMM-CalendarExt3 uses the very latest javascript idioms,
                which most TV browsers have not been upgraded to support…
                here is a table of what browser version supports what
                https://caniuse.com/?search=ECMAScript
                my Samsung 82 in used to run MM, but since a couple years ago it is downlevel
                  MMRIZE @czabel
                  @czabel
                  I’m in holidays this week. I’ll show you next week.
                    czabel @MMRIZE
                    @MMRIZE No rush at all, enjoy your holiday! I’ll keep fiddling, but I’ve never been good with CSS :D
                      Rakutsi
                      Hello.
                      Have been using MMM-CalendarExt2 for some years now and changed to MMM-CalendarExt3 today.
                      The thing was that my birthday events that i have in my my calender, i would like to say a the age of the person. The Calendar module you can use displayRepeatingCountTitle and repeatingCountTitle to show the years from when you put the event in the calendar. For example i tried put my birthday on the year i was born and put repeat every year on same day and it did show number.
                      Was wondering if this funktion work in MMM-CalendarExt3?
                        sdetweil @Rakutsi
                        @Rakutsi no… the stuff shown on the screen isn’t broadcast to the other modules…
                        but you could add an ext3 eventTransformer to add it back on (if you know bd, and some pattern in the event subject)
                          Rakutsi @sdetweil
                          @sdetweil thanks then i know.
                          well i dont know how to use the eventFilter for that, is there any example then i could try?
                          I am not the best at those kind of things. Mostly copy paste and trial and error.
                            sdetweil @Rakutsi
                            @Rakutsi see the doc and the ext3 wiki (at the module github page)
                              Rakutsi @sdetweil
                              this was the solution i came up with.
                              eventTransformer: (event) => {
                                  const currentYear = new Date().getFullYear();
                                  const age = currentYear - event.firstYear;
                                  event.title = `${event.title} (${age} year)`;
                                  return event;
                              Chatgpt is my friend.
                                sdetweil @Rakutsi
                                @Rakutsi awesome!
                                  MMRIZE @czabel
                                  Sorry for the late reply. I was on vacation.
                                  Append these codes to your custom.css
                                  /* custom.css */
                                  .CX3 .event.singleday .headline.useSymbol .symbol {
                                    czabel @MMRIZE
                                    @MMRIZE said in MMM-CalendarExt3:
                                    … Sorry for the late reply…
                                    No problem at all, I appreciate the time you spend helping on here.
                                    With that CSS adjustment, the events in the calendar look perfect now, thank you.
                                    But I have a new problem that seems to have just shown up: the volleyball icon that I’m using in the eventTransformer is now being applied to the Legend somehow:
                                    You can see the events are great (volleyball has the icon, other events are the default)
                                    This is especially odd because in the base calendar config, I specify useSymbol: false for the “Dad” calendar, but this element is somehow getting the .useSymbol class.
                                    Oh, I just found in a search another user that has this issue, link here
                                      MMRIZE @czabel
                                      @czabel
                                      Well, that is not the bug, however you might be uncomfortable.
                                      It is designed to get the symbol from the first(internally structured) event of the calendar group.
                                      Because the default calendar module will broadcast only the events themselves, not the meta-information from the calendar to which the event belonged, So there is no easy way to distinguish the default symbol of the specific calendar.
                                      To be honest, getting the default symbol from config of ONLY the default calendar module might be easy, but this module is designed to take events from any other possible modules, so I cannot assume all the user will get the events from the default calendar module only.
                                      Not so easy. Has somebody any idea?
                                        czabel @MMRIZE
                                        @MMRIZE
                                        I probably don’t understand enough about how this system works to help much, but isn’t every calendar entry a separate event, which is why the eventTransformer works to change the individual icons? How is it that this icon spills over into the Legend entry, and not just the specific calendar entries?
                                        In any case, what about adding a new config option to hideLegendIcons that forcibly removes the CSS tag, or something like that?
                                          MMRIZE @czabel
                                          @czabel
                                          You can simply append this code to your css/custom.css
                                          .CX3 .legend.useSymbol .symbol {
                                            display: none;
                                          • G
                                            gonzonia
                                            Recently I noticed my Calendars disappear after a few hours. I’m not sure when it started. If I VNC into my mirror and refresh or restart the mirror they come back only to stop appearing a few hours later. I see no errors in the log.
                                            I’m using
                                            MMM-CalendarExt3 and MMM-CalendarExt3Agenda in conjunction with MMM-Scenes, the instances that are only on specific scenes are the ones that disappear. I have another instance of MMM-CalendarExt3Agenda that is on all the scenes and that one seems to stay, so I’m wondering if it’s an MMM-Scenes issue.
                                            Edit: I’m also using MMM-Pir. I’m wondering if that might be doing something.
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 34
                                            • 35
                                            • 29 / 35
