    Multiple URL Querys to fill JSON
    10 Posts 3 Posters 884 Views 3 Watching
    • htilburgsH Offline
      htilburgs
      I hope I describe it correct and you understand what I mean.
      I’m writing a new module which has to display the information from 2 different URL’s.
      When I query them seperate than everythink works OK.
      But I want to do query from URL-1 to JSON (MHW-P1) and URL-2 to JSON (MHW-WM).
      Is this possible and how?
      This is what I’ve came up with, but it doesn’t work.
      node_helper.js
      // P1 Meter section
      getMHW_P1: function(urlP1) {
              // Make a GET request using the Fetch API for the P1 Meter
              fetch(urlP1)
                .then(response_P1 => {
                  if (!response_P1.ok) {
                    console.error('MMM-MyHomeWizard: Network response was not ok');
                  return response_P1.json();
                .then(result_P1 => {
                  // Process the retrieved user data
                  console.log(result_P1); // Remove trailing slashes to display data in Console for testing
                  this.sendSocketNotification('MHWP1_RESULT', result_P1);
                .catch(error => {
                  console.error('Error:', error);
        socketNotificationReceived: function(notification, payload_P1) {
                  if (notification === 'GET_MHWP1') {
                  this.getMHW_P1(payload_P1);
        // Water Meter Section
        getMHW_WM: function(urlWM) {
              // Make a GET request using the Fetch API for the Water Meter
              fetch(urlWM)
                .then(response_WM => {
                  if (!response_WM.ok) {
                  return response_WM.json();
                .then(result_WM => {
                  console.log(result_WM); // Remove trailing slashes to display data in Console for testing
                  this.sendSocketNotification('MHWWM_RESULT', result_WM);
                .catch(error => {
        socketNotificationReceived: function(notification, payload_WM) {
                  if (notification === 'GET_MHWWM') {
                  this.getMHW_WM(payload_WM);
      MMM-MyModules.js
      // <-- P1 Meter Section -->
      	// This processes your data P1 Meter
      	processMHW_P1: function(data_P1) {
      		this.MHW_P1 = data_P1;
      		console.log(JSON.stringify(this.MHW_P1)); // uncomment to see if you're getting data (in dev console)
      		this.loaded = true;
      	// this tells module when to update
      	scheduleUpdate: function() {
      		setInterval(() => {
      		    	this.getMHW_P1();
      			this.getMHW_WM();
      		}, this.config.updateInterval);
      		this.getMHW_P1();
      		this.getMHW_WM();
      		var self = this;
      	// this asks node_helper for data
      	getMHW_P1: function() {
      		this.sendSocketNotification('GET_MHWP1', this.urlP1);
      	// this gets data from node_helper
      	socketNotificationReceived: function(notification_P1, payload_P1) {
      		if (notification_P1 === "MHWP1_RESULT") {
      		// this notification doesn't come back on error..
      		this.processMHW_P1(payload_P1);
      		this.updateDom(this.config.initialLoadDelay);
      //<-- Water Meter Section -->
      	// This processes your data Water Meter
      	processMHW_WM: function(data_WM) {
      		this.MHW_WM = data_WM;
      		console.log(JSON.stringify(this.MHW_WM)); // uncomment to see if you're getting data (in dev console)
      		this.loaded = true;
      /*	// this tells module when to update
      		setInterval(() => {
      		    	this.getMHW_WM();
      		this.getMHW_WM();
      		var self = this;
      	getMHW_WM: function() {
      		this.sendSocketNotification('GET_MHWWM', this.urlWM);
      	socketNotificationReceived: function(notification_WM, payload_WM) {
      		if (notification_WM === "MHWWM_RESULT") {
      		this.processMHW_WM(payload_WM);
      I hope somebody can help me with this.
      I'm not a programmer, but I try to do my best ;-)
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        htilburgs @sdetweil
        @sdetweil Wow, it works!
        Just checking, it has to be done in node_helper and the MMM-Module?
          sdetweil @htilburgs
          @htilburgs you cant have two socketNotificationReceived() functions
          only 1, but it gets both notifications
          if notification=== "type1"
               call this function
          else   if notification=== "type2"
               call that function
          htilburgsH 1 Reply Last reply Reply Quote 0
            htilburgs @sdetweil
            @sdetweil I’ve changed it into this, but still only result from the WaterMeter and not the P1 meter
            		if (notification === "MHWP1_RESULT") {
            		this.processMHW_P1(payload);
            		else if (notification === "MHWWM_RESULT") {
            		this.processMHW_WM(payload);
              sdetweil @htilburgs
              @htilburgs I meant in the node_helper… you have 2 there as well
                htilburgs @sdetweil
                  sdetweil @htilburgs
                  @htilburgs the sendSocketNotification(xyz,foo) ------->socketNotificationReceived(notification, payload)
                  in both directions…
                  only one received on each side… if there are multiple, then the last one seen is used.
                    htilburgs @sdetweil
                    @sdetweil Thnx, you helped me a lot!!
                      MMRIZE
                      This is not a direct answer to the question, but just for your reference.
                      The fetch API can be executed directly in the browser, not just in a Node.js environment. You can call the fetch API directly in MMM-MyModule.js without needing node_helper.js.
                      Additionally, since the fetch API works asynchronously, you can manage the responses of two fetch calls as follows:
                      • If you need to use the response that arrives first, use Promise.race() or Promise.any().
                      • If you need to wait for both responses to arrive before proceeding, use Promise.all().
                      Using these methods can help you manage data synchronization more efficiently.
                      S htilburgsH 2 Replies Last reply Reply Quote 1
                        sdetweil @MMRIZE
                        @MMRIZE quite true, since fetch is now part of electron.
                          htilburgs @MMRIZE
                          @MMRIZE Thanks for your reaction.
