    Multiple URL Querys to fill JSON
    10 Posts 3 Posters 885 Views 3 Watching
      sdetweil @htilburgs
      @htilburgs the sendSocketNotification(xyz,foo) ------->socketNotificationReceived(notification, payload)
      in both directions…
      only one received on each side… if there are multiple, then the last one seen is used.
      htilburgsH 1 Reply Last reply Reply Quote 0
      • htilburgsH Offline
        htilburgs @sdetweil
        @sdetweil Thnx, you helped me a lot!!
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
          MMRIZE
          This is not a direct answer to the question, but just for your reference.
          The fetch API can be executed directly in the browser, not just in a Node.js environment. You can call the fetch API directly in MMM-MyModule.js without needing node_helper.js.
          Additionally, since the fetch API works asynchronously, you can manage the responses of two fetch calls as follows:
          • If you need to use the response that arrives first, use Promise.race() or Promise.any().
          • If you need to wait for both responses to arrive before proceeding, use Promise.all().
          Using these methods can help you manage data synchronization more efficiently.
          S htilburgsH 2 Replies Last reply Reply Quote 1
            sdetweil @MMRIZE
            @MMRIZE quite true, since fetch is now part of electron.
              htilburgs @MMRIZE
              @MMRIZE Thanks for your reaction.
