    ELI5 how notifications between modules work and how and where to create them
    13 Posts 2 Posters 3.9k Views 2 Watching
      reverendz
      I have been reading through multiple forum posts and it seems like when someone gets the answer, they don’t break it down in a way that’s understandable.
      I’m trying to add a button to a module like this:
      https://github.com/shbatm/MMM-OnScreenMenu/issues
      And use the button to call a keyboard like this:
      https://forum.magicmirror.builders/topic/12526/mmm-keyboard-a-virtual-touch-keyboard
      I don’t understand where I’m supposed to put the notification and how it’s supposed to get called.
      Apologies if this has been answered clearly, but I need a step by step break down because I’m just not getting it.
      I need to understand:
      • Where specifically to add the notification .
      • How it’s supposed to be formatted. Does it need to be a new function or something if it’s going into a module.js?
      • Does the other module need to be modified too?
      I’m a newbie and managed to get multiple modules working, but I can’t seem to understand how to send notifications/call other modules.
      I’d really like to use an on screen button module to call a keyboard and do some text entry, but having a heck of a time figuring this all out.
      Thanks!
      S 4 Replies Last reply Reply Quote 0
        sdetweil @reverendz
        @reverendz so you have to create a button html/Dom object, as part of the response to getDom(), to be shown on the screen
        Then you need to attach some handler/function to react when the button is pushed.
        In the routine, you would add one line of code to call
        this.sendNotification(Code, parms) as required by the keyboard module,
        to tell the module supplying the keyboard to pop it up
        I assume the keyboard will pop down, and send you back a notification with the text entered
        (Not my modules, I just helped solve some problem)
        This module reuses an existing routine
        https://github.com/sdetweil/new-MP3Player
        This one calls a new routine
        https://github.com/sdetweil/MMM-MyVideoPlayer
          sdetweil @reverendz
          @reverendz the how they work part
          The sender calls
          this.sendNotification(x,y)
          Where x is the notification code some receiving module has published to accomplish the function you want
          And y is whatever parameters that notification code might require
          ALL modules running will receive a call at their notificationReceived(x,y) function
          Any module receiving the message that understands what to do with code x, can handle it
          At some time later one of the running modules will call this.sendNotification(q,z). With a response and ALL modules running will hear it.
            sdetweil @reverendz
            @reverendz did you have time to look at this? If do, did you make progress?
              sdetweil @reverendz
              @reverendz did you resolve this?
                reverendz @sdetweil
                Hi, I’m frankly a bit embarrassed to reply.
                I’m a newbie to all this, so while I’m able to get the modules working and have a passable custom.css, when I read things like:
                “In the routine, you would add one line of code to call
                to tell the module supplying the keyboard to pop it up”
                I have no idea what that means practically.
                If I had an example, breaking it down like “edit this specific file and add this bit” and could play around with it, I’d get it. But reading that description, I’m totally lost.
                  sdetweil @reverendz
                  @reverendz sendNotification can only be done in the browser side file, module_name.js
                  here is MMM-MotionDetector.js using code to watch camera feed. when motion is detected it informs its node_helper (in case the screen is off), this.sendSocketNotification()
                  AND it informs all the other modules
                  this.sendNotification()
                  in both cases the function takes two parameters
                  first is a string which means something, can be any string of any length, called notification in example code
                  second is any kind of data. also understood by whoever understands the notification code string,
                  called payload in example code
                    reverendz @sdetweil
                    Thank you! That’s very helpful.
                    I wound up writing a very basic module to send a notification and it worked.
                    I’m still not sure how to integrate it into an existing module, but I am starting to understand it better.
                      sdetweil @reverendz
                      @reverendz what module do you want to update?
                        sdetweil @reverendz
                        @reverendz I ‘assume’ you want to have a something to trigger capturing some data to be input from the module (to cause the keyboard to pop up)
                        so, a button on the screen… this below is JUST the button content, all the other module content has to be created similarly
                        the button needs a function to handle when the button is pressed (onClick, or just click)
                            getDom(){
                             let wrapper = documentCreateElement("div")
                                 // create a button object
                                 let button_element = documentCreateElement("button")
                                 // identify the button
                                 button_element.id="openEditor"
                                 let self = this // this -> module object
                                 // connect button onclick to some routine
                                 button_element.addEventListener("click",self.someFunction(this))  // on button click, this -> button object, need to call function in module object
                                 // add the button object to the div we are sending back to MM , so it will be displayed
                                 wrapper.appendChild(button_element)
                             return wrapper
                        someFunction(button){
                            if(button.id=='openEditor")
                               this.sendNotification(openEditor,... whatever parms)
                          reverendz @sdetweil
                          It was working, then I changed a couple things and I can’t get it working again :|
                          So ideally, I’d like to understand notifications so that I can use an on screen menu to open a keyboard like this.
                          https://github.com/lavolp3/MMM-Keyboard
                          I’ve tried to modify pre-existing modules like these:
                          https://github.com/tjat84/MMM-SystemOptions/
                          https://github.com/Jopyth/MMM-Buttons
                          My idea is this: right now, I’ve got my Magic Mirror syncing with my calendar and it’s working pretty well with vdirsyncer.
                          I’d like to use an on-screen button or something in the EXT3 Calendar module to open a form with a keyboard.
                          I’d then write event details to the local calendar and then sync back to the cloud calendar.
                          Generally, it’d be nice to understand how to create buttons to do other functions as shown in https://github.com/shbatm/MMM-OnScreenMenu. The ability show/hide modules and even scroll to a different page using Carousel or Pages would be awesome too.
                          But I can’t seem to get past step one: send a notification to open the on screen keyboard. So far, I’ve gotten it working exactly once. Then I made a change and it’s failing.
                          I’m doing
                          npm start dev and I can see the notification is being sent. However, the keyboard isn’t responding even though I didn’t modify it at all.
                          Really appreciate the help, I’m real new to all this so just getting it set up with working modules was a win.
                            sdetweil @reverendz
                            @reverendz in the developers window (sources tab) you can see the keyboard module source too…
                            and put a stop on its notificationReceived() function
                            put a stop on your this.sendNotification() function line
                            when it stops, use the mouse to hover over the word this… does it look like module info??
                            there are lots of tricky items to deal with… especially if you have pages running… some modules won’t respond if they are ‘hidden’ by MMM-Pages
                            so, best is to start bare minimum…
                            YOU WILL have to create another module to do all this…
                            I can see using the button to CREATE… doing edit/delete will be harder trying to get to the data in another module. altho you can use JQuery pretty well,
                            how to get it invoked on that cal entry will be fun… (maybe monkeypatch module???)
                            there is NO MAGIC here, its all grunt work.
                            welcome to the fun of learning while developing…
                            i’ve got a hardware development kit that has left me completely blank wall for about 6 months now…
                            so I KNOW the feeling…
                              @reverendz i dont want to discourage you from getting this working
                              you might look at another collection of modules that aim to do the same. see
                              https://forum.magicmirror.builders/topic/18011/touchscreen-family-dashboard
