    Troubleshooting Positions
    13 Posts 2 Posters 2.0k Views 2 Watching
      sdetweil @roaminMirror
      @roaminMirror if you look at the messages from npm start you should see an error maybe
      one of the ideas was to make the positions extendable/customizable…
      currently you have to edit 5 files.
      SO, I added code to read the index.html file, which has the positions/regions used defined, in the server side where I can read a file
      BUT I need to pass that info to the browser side code that checks it…
      SO, I WRITE the list of positions to a file js/positions.js
      someone else reported that they got a permission denied on this write…
      (cause they had used sudo to install MM… oops)
      it also fails on synology nas drives under docker, if the storage is created by a synology user , and accessed from the docker user(1000)
      you can erase that file, js/positions.js
      and it will be recreated
      I added a new message to the next release about this permissions problem, instead of crashing
        roaminMirror @roaminMirror
        @roaminMirror Thank you for your reply. What are the 5 files that I will need to edit to have the positions be recoginized and allowed in the positions.js file? I found that editing it manually it will, as you mentioned, recreate itself in the original manner. I am assuming it is gathering it’s array from another location butI am not sure what file is creating that positions.js file with this const modulePositions=[“fullscreen_below”]e with the array .
        The only position that is working is Fullscreen_Below for some reason. Sorry I am just not understanding.
          @roaminMirror can you show me ~/MagicMirror/index.html
          that is the file i read for the regions
          it should not be changed unless you ate adding new regions
          also post the contents of ~/MagicMirror/js/positions.js
            @roaminMirror see the doc on module position
            see the note
              roaminMirror @sdetweil
              I haven’t made any changes to the index.html file. The config.js is unchanged as well as the positions.js file.
              <!doctype html>
              <html>
                <head>
                  <title>MagicMirror²</title>
                  <meta name="google" content="notranslate" />
                  <meta http-equiv="Content-type" content="text/html; charset=utf-8" />
                  <meta name="apple-mobile-web-app-capable" content="yes" />
                  <meta name="apple-mobile-web-app-status-bar-style" content="black" />
                  <meta name="format-detection" content="telephone=no" />
                  <meta name="mobile-web-app-capable" content="yes" />
                  <link rel="icon" href="data:;base64,iVBORw0KGgo=" />
                  <link rel="stylesheet" type="text/css" href="css/main.css" />
                  <link rel="stylesheet" type="text/css" href="fonts/roboto.css" />
                  <link rel="stylesheet" type="text/css" href="vendor/node_modules/animate.css/animate.min.css" />
                  <!-- custom.css is loaded by the loader.js to make sure it's loaded after the module css files. -->
                  <script type="text/javascript">
                    window.mmVersion = "#VERSION#";
                  </script>
                </head>
                <body>
                  <div class="region fullscreen below"><div class="container"></div></div>
                  <div class="region top bar">
                    <div class="top_bar"><div class="container"></div></div>
                    <div class="region top center"><div class="container"><clock /></div></div>
                    <div class="region top right"><div class="container"></div></div>
                  </div>
                  <div class="region upper third"><div class="container"></div></div>
                  <div class="region middle center"><div class="container"></div></div>
                  <div class="region lower third">
                    <div class="container"><br /></div>
                  </div>
                  <div class="region bottom bar">
                    <div class="region bottom left"><div class="container"></div></div>
                    <div class="region bottom center"><div class="container"></div></div>
                    <div class="region bottom right"><div class="container"></div></div>
                  </div>
                  <div class="region fullscreen above"><div class="container"></div></div>
                  <script type="text/javascript" src="socket.io/socket.io.js"></script>
                  <script type="text/javascript" src="vendor/node_modules/nunjucks/browser/nunjucks.min.js"></script>
                  <script type="text/javascript" src="js/defaults.js"></script>
                  <script type="text/javascript" src="#CONFIG_FILE#"></script>
                  <script type="text/javascript" src="vendor/vendor.js"></script>
                  <script type="text/javascript" src="modules/default/defaultmodules.js"></script>
                  <script type="text/javascript" src="modules/default/utils.js"></script>
                  <script type="text/javascript" src="js/logger.js"></script>
                  <script type="text/javascript" src="translations/translations.js"></script>
                  <script type="text/javascript" src="js/translator.js"></script>
                  <script type="text/javascript" src="js/class.js"></script>
                  <script type="text/javascript" src="js/module.js"></script>
                  <script type="text/javascript" src="js/loader.js"></script>
                  <script type="text/javascript" src="js/socketclient.js"></script>
                  <script type="text/javascript" src="js/animateCSS.js"></script>
                  <script type="text/javascript" src="js/positions.js"></script>
                  <script type="text/javascript" src="js/main.js"></script>
                </body>
              </html>
              ![positions.png](/assets/uploads/files/1735328208567-positions.png)
                @roaminMirror cant attach files, only their text as a paste
                  @roaminMirror are you running on Windows?
                    Yes I am running on windows for the time being until I am ready to move it to a RPI.
                    The positions.js file is
                    const modulePositions=["fullscreen_below"]
                    If I attempt to change it and then start the server with npm run start it will revert back to the above code.
                      @roaminMirror interesting… I don’t see this problem on windows…
                      anyhow
                      edit js/utils.js
                      at the end is the function
                      getModulePositions () {
                      		// if not already discovered
                      		if (modulePositions.length === 0) {
                      			// get the lines of the index.html
                      			const lines = fs.readFileSync(indexFileName).toString().split(os.EOL);
                      change that last line to
                                             const lines = fs.readFileSync(indexFileName).toString().split('\n');
                        @roaminMirror I was able to recreate this on windows…
                        opened issue #3662 and submitted fix #3663
                        change to ‘\n’ as I proposed
                          roaminMirror
                          That was what was needed! Thank you for helping out with that!
                          • R roaminMirror has marked this topic as solved on
                            @roaminMirror great… fixed in next release (Wednesday)
