    Troubleshooting Positions
    13 Posts 2 Posters 2.0k Views 2 Watching
      roaminMirror @roaminMirror
      @roaminMirror Thank you for your reply. What are the 5 files that I will need to edit to have the positions be recoginized and allowed in the positions.js file? I found that editing it manually it will, as you mentioned, recreate itself in the original manner. I am assuming it is gathering it’s array from another location butI am not sure what file is creating that positions.js file with this const modulePositions=[“fullscreen_below”]e with the array .
      The only position that is working is Fullscreen_Below for some reason. Sorry I am just not understanding.
        sdetweil @roaminMirror
        @roaminMirror can you show me ~/MagicMirror/index.html
        that is the file i read for the regions
        it should not be changed unless you ate adding new regions
        also post the contents of ~/MagicMirror/js/positions.js
          @roaminMirror see the doc on module position
          see the note
            roaminMirror @sdetweil
            I haven’t made any changes to the index.html file. The config.js is unchanged as well as the positions.js file.
            <!doctype html>
            <html>
              <head>
                <title>MagicMirror²</title>
                <meta name="google" content="notranslate" />
                <meta http-equiv="Content-type" content="text/html; charset=utf-8" />
                <meta name="apple-mobile-web-app-capable" content="yes" />
                <meta name="apple-mobile-web-app-status-bar-style" content="black" />
                <meta name="format-detection" content="telephone=no" />
                <meta name="mobile-web-app-capable" content="yes" />
                <link rel="icon" href="data:;base64,iVBORw0KGgo=" />
                <link rel="stylesheet" type="text/css" href="css/main.css" />
                <link rel="stylesheet" type="text/css" href="fonts/roboto.css" />
                <link rel="stylesheet" type="text/css" href="vendor/node_modules/animate.css/animate.min.css" />
                <!-- custom.css is loaded by the loader.js to make sure it's loaded after the module css files. -->
                <script type="text/javascript">
                  window.mmVersion = "#VERSION#";
                </script>
              </head>
              <body>
                <div class="region fullscreen below"><div class="container"></div></div>
                <div class="region top bar">
                  <div class="top_bar"><div class="container"></div></div>
                  <div class="region top center"><div class="container"><clock /></div></div>
                  <div class="region top right"><div class="container"></div></div>
                </div>
                <div class="region upper third"><div class="container"></div></div>
                <div class="region middle center"><div class="container"></div></div>
                <div class="region lower third">
                  <div class="container"><br /></div>
                </div>
                <div class="region bottom bar">
                  <div class="region bottom left"><div class="container"></div></div>
                  <div class="region bottom center"><div class="container"></div></div>
                  <div class="region bottom right"><div class="container"></div></div>
                </div>
                <div class="region fullscreen above"><div class="container"></div></div>
                <script type="text/javascript" src="socket.io/socket.io.js"></script>
                <script type="text/javascript" src="vendor/node_modules/nunjucks/browser/nunjucks.min.js"></script>
                <script type="text/javascript" src="js/defaults.js"></script>
                <script type="text/javascript" src="#CONFIG_FILE#"></script>
                <script type="text/javascript" src="vendor/vendor.js"></script>
                <script type="text/javascript" src="modules/default/defaultmodules.js"></script>
                <script type="text/javascript" src="modules/default/utils.js"></script>
                <script type="text/javascript" src="js/logger.js"></script>
                <script type="text/javascript" src="translations/translations.js"></script>
                <script type="text/javascript" src="js/translator.js"></script>
                <script type="text/javascript" src="js/class.js"></script>
                <script type="text/javascript" src="js/module.js"></script>
                <script type="text/javascript" src="js/loader.js"></script>
                <script type="text/javascript" src="js/socketclient.js"></script>
                <script type="text/javascript" src="js/animateCSS.js"></script>
                <script type="text/javascript" src="js/positions.js"></script>
                <script type="text/javascript" src="js/main.js"></script>
              </body>
            </html>
            ![positions.png](/assets/uploads/files/1735328208567-positions.png)
              @roaminMirror cant attach files, only their text as a paste
                @roaminMirror are you running on Windows?
                  Yes I am running on windows for the time being until I am ready to move it to a RPI.
                  The positions.js file is
                  const modulePositions=["fullscreen_below"]
                  If I attempt to change it and then start the server with npm run start it will revert back to the above code.
                    @roaminMirror interesting… I don’t see this problem on windows…
                    anyhow
                    edit js/utils.js
                    at the end is the function
                    getModulePositions () {
                    		// if not already discovered
                    		if (modulePositions.length === 0) {
                    			// get the lines of the index.html
                    			const lines = fs.readFileSync(indexFileName).toString().split(os.EOL);
                    change that last line to
                                           const lines = fs.readFileSync(indexFileName).toString().split('\n');
                      @roaminMirror I was able to recreate this on windows…
                      opened issue #3662 and submitted fix #3663
                      change to ‘\n’ as I proposed
                        roaminMirror
                        That was what was needed! Thank you for helping out with that!
                        • R roaminMirror has marked this topic as solved on
                          @roaminMirror great… fixed in next release (Wednesday)
