    Default Calendar stuck on loading
    55 Posts 2 Posters 16.2k Views 2 Watching
      sdetweil @rushmuzik
      @rushmuzik 2.29 uses socket.io 4.8 where 2.28 uses 4.7.5
      you could install 4.7.5
      cd~/MagicMirror
      npm remove  socket.io
      npm install socket.io@4.7.5
      i have company today so it will tomorrow really before i can test
        rushmuzik @sdetweil
        @sdetweil I reverted back to socket.io@4.7.2 that was used on MagicMirror@2.26.0 and that fixed the issue! I tried socket.io@4.7.5 but that didnt work. So I went back to @4.7.2 and that fixed it. It might just be a compatibility issue with Firefox ESR. Mystery Solved! Thanks for all your help!
          sdetweil @rushmuzik
          @rushmuzik awesome!!! thanks for the feedback
            rushmuzik @sdetweil
            @sdetweil Thanks for all you do to help the MM community!
              sdetweil @rushmuzik
              @rushmuzik that change to socket.io@4.7.2 didn’t help my pi0w MM with firefox (running on next release or 2.29.0)
                @rushmuzik
                I had to change the code to add an increased timeout for fetch…
                which required node 20.18.1
                then the 4.8 socket.io worked with the surf browser
                couldn’t get firefox to work
                  rushmuzik @sdetweil
                  @sdetweil For some mysterios reason it worked for me for 10 good minutes then crashed. I still don’t know what caused it to work that period. How is the overal experience with Surf Browser? Would you recommend I use that instead?
                    sdetweil @rushmuzik
                    @rushmuzik my surf based system has bern running for 3 days without trouble
                      rushmuzik @sdetweil
                      @sdetweil I have two followup questions.
                      1. How do I install that surf based system.
                      2. Do you know how I can nun Node@20.17.0 or greater on a pie zero?
                        sdetweil @rushmuzik
                        @rushmuzik
                        surf is installed via apt
                        sudo apt install surf
                        on armv6l installing node is a pain
                        quickest way is to run my installer again, as it is set to install 20.18.1
                        rename your MagicMirror folder out of the way first as the installer wont install over an existing MagicMirror setup
                        OR wait til jan 1 and run the upgrade script, which will install the new version with longer timeout and node 20.18.1
                          rushmuzik @sdetweil
                          @sdetweil I was able to install node 20.18.1. Just trying to figure out the code to increase the fetch timeout.
                            sdetweil @rushmuzik
                            @rushmuzik in the next release on Wednesday
                              sdetweil @rushmuzik
                              @rushmuzik you could get the develop branch
                              see
                              https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                              fetch timeout is increased to 30 seconds
                                @rushmuzik new release today
                                • 3 / 3
