    Default Calendar stuck on loading
    55 Posts 2 Posters 16.8k Views 2 Watching
      rushmuzik @sdetweil
      @sdetweil I’ve searched all over google but I still haven’t found a viable solution.
      Do you think a previous socket.io version would fix the problem? my current version is 4.8.1
        sdetweil @rushmuzik
        @rushmuzik no idea yet
        R 1 Reply Last reply
          rushmuzik @sdetweil
          @sdetweil The socket.io GIT lists this as a possible solution to the bad request error however I’m not quite sure where to put it.
          Installation: npm i http-proxy
          const httpProxy = require(“http-proxy”);
          httpProxy
          .createProxyServer({
          target: “http://localhost:3000”,
          ws: true,
          .listen(80);
            sdetweil @rushmuzik
            @rushmuzik me either. socket.io is setup in server.js
              rushmuzik @sdetweil
              @sdetweil I’m suspecting it might be an update to the socket.io in the recent 2.29 release which I’m using. I suspect 2.28 or prior my not have this issue
                sdetweil @rushmuzik
                @rushmuzik 2.29 uses socket.io 4.8 where 2.28 uses 4.7.5
                you could install 4.7.5
                cd~/MagicMirror
                npm remove  socket.io
                npm install socket.io@4.7.5
                i have company today so it will tomorrow really before i can test
                  rushmuzik @sdetweil
                  @sdetweil I reverted back to socket.io@4.7.2 that was used on MagicMirror@2.26.0 and that fixed the issue! I tried socket.io@4.7.5 but that didnt work. So I went back to @4.7.2 and that fixed it. It might just be a compatibility issue with Firefox ESR. Mystery Solved! Thanks for all your help!
                    sdetweil @rushmuzik
                    @rushmuzik awesome!!! thanks for the feedback
                      rushmuzik @sdetweil
                      @sdetweil Thanks for all you do to help the MM community!
                        sdetweil @rushmuzik
                        @rushmuzik that change to socket.io@4.7.2 didn’t help my pi0w MM with firefox (running on next release or 2.29.0)
                          @rushmuzik
                          I had to change the code to add an increased timeout for fetch…
                          which required node 20.18.1
                          then the 4.8 socket.io worked with the surf browser
                          couldn’t get firefox to work
                            rushmuzik @sdetweil
                            @sdetweil For some mysterios reason it worked for me for 10 good minutes then crashed. I still don’t know what caused it to work that period. How is the overal experience with Surf Browser? Would you recommend I use that instead?
                              sdetweil @rushmuzik
                              @rushmuzik my surf based system has bern running for 3 days without trouble
                                rushmuzik @sdetweil
                                @sdetweil I have two followup questions.
                                1. How do I install that surf based system.
                                2. Do you know how I can nun Node@20.17.0 or greater on a pie zero?
                                  sdetweil @rushmuzik
                                  @rushmuzik
                                  surf is installed via apt
                                  sudo apt install surf
                                  on armv6l installing node is a pain
                                  quickest way is to run my installer again, as it is set to install 20.18.1
                                  rename your MagicMirror folder out of the way first as the installer wont install over an existing MagicMirror setup
                                  OR wait til jan 1 and run the upgrade script, which will install the new version with longer timeout and node 20.18.1
                                    rushmuzik @sdetweil
                                    @sdetweil I was able to install node 20.18.1. Just trying to figure out the code to increase the fetch timeout.
                                    S 2 Replies Last reply
                                      sdetweil @rushmuzik
                                      @rushmuzik in the next release on Wednesday
                                        sdetweil @rushmuzik
                                        @rushmuzik you could get the develop branch
                                        see
                                        https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                                        fetch timeout is increased to 30 seconds
                                          @rushmuzik new release today
                                          • 3 / 3
