    Default Calendar stuck on loading
    55 Posts 2 Posters 12.6k Views 2 Watching
      sdetweil @rushmuzik
      @rushmuzik you only have 1, so no issue…
      pm2 --help
      has lots of options
        rushmuzik @sdetweil
        @sdetweil ok. Where would you suggest I go from here? COuld it be the Firefox ESR causing the issue?
          sdetweil @rushmuzik
          @rushmuzik I don’t know yet… I posted a potential fix for you to try, based on the error shown
            rushmuzik @sdetweil
            @sdetweil Yes, I saw that. I tried it. It did’t work.
            I wonder if something in here might help
              sdetweil @rushmuzik
              @rushmuzik no idea…
              trying to get ff installed
                @rushmuzik well i can recreate it. its a bug in firefox. trying to find a workaround, 3 so far dont
                  rushmuzik @sdetweil
                  @sdetweil OK so I’m not crazy! Good to know! It amazes me how much you know!
                    sdetweil @rushmuzik
                    @rushmuzik just learned about this today, and google has a lot of info. wading thru it is time consuming.
                      rushmuzik @sdetweil
                      @sdetweil Absolutely. I appreciate all the attention you’ve given to this so far. You have been a big help to the community.
                        rushmuzik @sdetweil
                        @sdetweil I’ve searched all over google but I still haven’t found a viable solution.
                        Do you think a previous socket.io version would fix the problem? my current version is 4.8.1
                          sdetweil @rushmuzik
                          @rushmuzik no idea yet
                            rushmuzik @sdetweil
                            @sdetweil The socket.io GIT lists this as a possible solution to the bad request error however I’m not quite sure where to put it.
                            Installation: npm i http-proxy
                            const httpProxy = require(“http-proxy”);
                            httpProxy
                            .createProxyServer({
                            target: “http://localhost:3000”,
                            ws: true,
                            .listen(80);
                              sdetweil @rushmuzik
                              @rushmuzik me either. socket.io is setup in server.js
                                rushmuzik @sdetweil
                                @sdetweil I’m suspecting it might be an update to the socket.io in the recent 2.29 release which I’m using. I suspect 2.28 or prior my not have this issue
                                  sdetweil @rushmuzik
                                  @rushmuzik 2.29 uses socket.io 4.8 where 2.28 uses 4.7.5
                                  you could install 4.7.5
                                  cd~/MagicMirror
                                  npm remove  socket.io
                                  npm install socket.io@4.7.5
                                  i have company today so it will tomorrow really before i can test
                                    rushmuzik @sdetweil
                                    @sdetweil I reverted back to socket.io@4.7.2 that was used on MagicMirror@2.26.0 and that fixed the issue! I tried socket.io@4.7.5 but that didnt work. So I went back to @4.7.2 and that fixed it. It might just be a compatibility issue with Firefox ESR. Mystery Solved! Thanks for all your help!
                                      sdetweil @rushmuzik
                                      @rushmuzik awesome!!! thanks for the feedback
                                        rushmuzik @sdetweil
                                        @sdetweil Thanks for all you do to help the MM community!
                                          sdetweil @rushmuzik
                                          @rushmuzik that change to socket.io@4.7.2 didn’t help my pi0w MM with firefox (running on next release or 2.29.0)
                                            @rushmuzik
                                            I had to change the code to add an increased timeout for fetch…
                                            which required node 20.18.1
                                            then the 4.8 socket.io worked with the surf browser
                                            couldn’t get firefox to work
                                            • 2 / 3
