    Default Calendar stuck on loading
    55 Posts 2 Posters 15.1k Views 2 Watching
      rushmuzik @sdetweil
      @sdetweil This is what I’m using. with Firefox ESR as the browser because Chromium and regular firefox are no longer supported on a Pi zero. Also, I’m using an API to connect to my Tempest weather station and that works fine. In addition all the other default modules work as they should except for calendar.
        sdetweil @rushmuzik
        @rushmuzik pi zero. ok… let me set that up
          rushmuzik @sdetweil
          @sdetweil These are the steps I followed to set it up
          https://www.davidgagne.net/2024/05/30/how-to-get-magicmirror-to-run-on-a-raspberry-pi-zero-w-rev-1-1/
            sdetweil @rushmuzik
            @rushmuzik ok, but because you said yes on step 2 to pm2
            you don’t need step 8 as it causes a duplicate app definition, which will cause TWO to start
            pm2 status
            will show you the apps defined
              rushmuzik @sdetweil
              @sdetweil How do I fix that? Is there a way to undo? This is what I see in pm2 status
                sdetweil @rushmuzik
                @rushmuzik you only have 1, so no issue…
                pm2 --help
                has lots of options
                  rushmuzik @sdetweil
                  @sdetweil ok. Where would you suggest I go from here? COuld it be the Firefox ESR causing the issue?
                    sdetweil @rushmuzik
                    @rushmuzik I don’t know yet… I posted a potential fix for you to try, based on the error shown
                      rushmuzik @sdetweil
                      @sdetweil Yes, I saw that. I tried it. It did’t work.
                      I wonder if something in here might help
                        sdetweil @rushmuzik
                        @rushmuzik no idea…
                        trying to get ff installed
                          @rushmuzik well i can recreate it. its a bug in firefox. trying to find a workaround, 3 so far dont
                            rushmuzik @sdetweil
                            @sdetweil OK so I’m not crazy! Good to know! It amazes me how much you know!
                              sdetweil @rushmuzik
                              @rushmuzik just learned about this today, and google has a lot of info. wading thru it is time consuming.
                                rushmuzik @sdetweil
                                @sdetweil Absolutely. I appreciate all the attention you’ve given to this so far. You have been a big help to the community.
                                  rushmuzik @sdetweil
                                  @sdetweil I’ve searched all over google but I still haven’t found a viable solution.
                                  Do you think a previous socket.io version would fix the problem? my current version is 4.8.1
                                    sdetweil @rushmuzik
                                    @rushmuzik no idea yet
                                      rushmuzik @sdetweil
                                      @sdetweil The socket.io GIT lists this as a possible solution to the bad request error however I’m not quite sure where to put it.
                                      Installation: npm i http-proxy
                                      const httpProxy = require(“http-proxy”);
                                      httpProxy
                                      .createProxyServer({
                                      target: “http://localhost:3000”,
                                      ws: true,
                                      .listen(80);
                                        sdetweil @rushmuzik
                                        @rushmuzik me either. socket.io is setup in server.js
                                          rushmuzik @sdetweil
                                          @sdetweil I’m suspecting it might be an update to the socket.io in the recent 2.29 release which I’m using. I suspect 2.28 or prior my not have this issue
                                            sdetweil @rushmuzik
                                            @rushmuzik 2.29 uses socket.io 4.8 where 2.28 uses 4.7.5
                                            you could install 4.7.5
                                            cd~/MagicMirror
                                            npm remove  socket.io
                                            npm install socket.io@4.7.5
                                            i have company today so it will tomorrow really before i can test
                                            • 2 / 3
