    Default Calendar stuck on loading
    55 Posts 2 Posters 15.1k Views 2 Watching
      sdetweil @rushmuzik
      @rushmuzik thanks will review
        @rushmuzik OK i tested on my desktop ubuntu, and on pi4 with latest PI os (bookworm) 64bit.
        I do not see that
        what machine are you on? can u show the startup info section
        this output comes after Launching application
        [2024-12-19 08:19:24.759] [INFO]  System information:
        ### SYSTEM:   manufacturer: ; model: ; virtual: false
        ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.51+rpt-rpi-v8
        ### VERSIONS: electron: 31.7.3; used node: 20.18.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2
        ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
        S R 2 Replies Last reply Reply Quote 0
          @rushmuzik
          given the error you showed, can you try list change
          edit MagicMirror/js/server.js
          and down at the bottom
          	this.close = function () {
          		return new Promise((resolve) => {
          			for (const socket of serverSockets.values()) {
          				socket.close();   //<--- add this line
          				socket.destroy();
          save and restart MagicMirror
            rushmuzik @sdetweil
            @sdetweil This is what I’m using. with Firefox ESR as the browser because Chromium and regular firefox are no longer supported on a Pi zero. Also, I’m using an API to connect to my Tempest weather station and that works fine. In addition all the other default modules work as they should except for calendar.
              sdetweil @rushmuzik
              @rushmuzik pi zero. ok… let me set that up
                rushmuzik @sdetweil
                @sdetweil These are the steps I followed to set it up
                https://www.davidgagne.net/2024/05/30/how-to-get-magicmirror-to-run-on-a-raspberry-pi-zero-w-rev-1-1/
                  sdetweil @rushmuzik
                  @rushmuzik ok, but because you said yes on step 2 to pm2
                  you don’t need step 8 as it causes a duplicate app definition, which will cause TWO to start
                  pm2 status
                  will show you the apps defined
                    rushmuzik @sdetweil
                    @sdetweil How do I fix that? Is there a way to undo? This is what I see in pm2 status
                      sdetweil @rushmuzik
                      @rushmuzik you only have 1, so no issue…
                      pm2 --help
                      has lots of options
                        rushmuzik @sdetweil
                        @sdetweil ok. Where would you suggest I go from here? COuld it be the Firefox ESR causing the issue?
                          sdetweil @rushmuzik
                          @rushmuzik I don’t know yet… I posted a potential fix for you to try, based on the error shown
                            rushmuzik @sdetweil
                            @sdetweil Yes, I saw that. I tried it. It did’t work.
                            I wonder if something in here might help
                              sdetweil @rushmuzik
                              @rushmuzik no idea…
                              trying to get ff installed
                                @rushmuzik well i can recreate it. its a bug in firefox. trying to find a workaround, 3 so far dont
                                  rushmuzik @sdetweil
                                  @sdetweil OK so I’m not crazy! Good to know! It amazes me how much you know!
                                    sdetweil @rushmuzik
                                    @rushmuzik just learned about this today, and google has a lot of info. wading thru it is time consuming.
                                      rushmuzik @sdetweil
                                      @sdetweil Absolutely. I appreciate all the attention you’ve given to this so far. You have been a big help to the community.
                                        rushmuzik @sdetweil
                                        @sdetweil I’ve searched all over google but I still haven’t found a viable solution.
                                        Do you think a previous socket.io version would fix the problem? my current version is 4.8.1
                                          sdetweil @rushmuzik
                                          @rushmuzik no idea yet
                                            rushmuzik @sdetweil
                                            @sdetweil The socket.io GIT lists this as a possible solution to the bad request error however I’m not quite sure where to put it.
                                            Installation: npm i http-proxy
                                            const httpProxy = require(“http-proxy”);
                                            httpProxy
                                            .createProxyServer({
                                            target: “http://localhost:3000”,
                                            ws: true,
                                            .listen(80);
                                            • 2 / 3
